GQ Nissan and Tow Ball Weight
Submitted: Friday, Aug 07, 2009 at 19:06
ThreadID: 71313 Views:5672 Replies:7 FollowUps:4
A mate who has a GQ was told today that the max TBW is 200 KGs and that any weight put in the back of the vehicle decreases the TBW. So how do they work this out...you put 200 KGs in the back what does the TBW come do to?
One more question for those who tow with GQs what do you tow?
Reply By: Tenpounder (SA) - Friday, Aug 07, 2009 at 19:35
Hi there.
First, there is a max GVM ( vehicle mass) for the GQ. Then, there is a max rear axle loading within that GVM.
So the load on the back axle will be what's in the GQ itself, plus the Towbar Load (TBW).
So what your mate was told is that the more you put in the vehicle, the less you can hang off the back.
What your mate should have been told is that the available TBW is the total rear axle permitted load, minus the weight inside the vehicle.
But the main point is that, if your mate uses the full allowed 200kg on the ball, then this will limit the amount of gear he can chuck in the back of the Patrol.
AnswerID: 378050
Reply By: Member - Shane D (QLD) - Friday, Aug 07, 2009 at 19:37
Nah, the other way around.
IF you put 200 kg's on a towball, thats 200kg's LESS you can put IN the back of the patrol.
Just say you can legally put 750 kgs in a Patrol (I don't know what it can actually carry), You MUST allow for whatever towball weight is going on as well, so if you have 200kg tawball weight, that will come off the 750 kg you can carry, you now can only carry 550kgs + 200 kgs totalling 750.
If you put 100 kgs on the roof that will also come out of 750, so, 100 on the roof + 200 on the towball, permits you only to be able to put in 450kg's in the back.
Shane
AnswerID: 378051
Follow Up By: Member - Axle - Friday, Aug 07, 2009 at 19:54
A couple of fat blokes like me and your on the limit!!...lol,
Axle.
FollowupID: 645401
Reply By: Member - barry F (NSW) - Friday, Aug 07, 2009 at 19:39
The tow ball weight is simply the weight that is placed on the tow ball when you hitch your trailer or van up. The trailer or van should be loaded at the time of weighing.
The only way to correctly establish the TBW is to weight it. I would think that putting 200 Kg behind the rear axle would influence the TBW, but not by much. You need to weigh it. Hope that helps. Cheers.
AnswerID: 378052
Follow Up By: Tenpounder (SA) - Friday, Aug 07, 2009 at 19:45
Barry. I think you are talking about weight behind the axle of the van or trailer, and its effect on the TBW. I was talking about weight in the Patrol over or behind the back axle, in addition to the TBW imposed by the van
FollowupID: 645399
Reply By: Member - Mike (SA) - Friday, Aug 07, 2009 at 19:58
Hi guys I own a RB30. I have just had to reseacrch this!
The good oil is as follows
Legal towing with brakes 2500kgs
ball mass fully laden at GVM 140gks
reduce GVM by 80kgs, ball mass 20kgs
reduce GVM by 150kgs, ball mass 250kgs.
Hope this helps,
regards
Mike
PS source for info RACQ and Caravanj Trade and Industiries Association
Too little time in the bush!
VKS 737 Mobile 0230
AnswerID: 378056
Follow Up By: Member - Mike (SA) - Friday, Aug 07, 2009 at 19:59
Typo correction reduce by 80kgs ball mass 200kgs! regards, Mike
VKS 737 Mobile 0230
FollowupID: 645402
Reply By: KennyBWilson - Friday, Aug 07, 2009 at 20:26
What make is your towbar , whne i first got my GQ many years ago it had a tongue type
AnswerID: 378066
Follow Up By: Member - Mike (SA) - Friday, Aug 07, 2009 at 22:15
uncertain, it came with the vehicle 420,000kms ago - I have always assumed it is Nissan - it is tongue type and I have a Trigg hitch. I have had since new!
Mike
VKS 737 Mobile 0230
FollowupID: 645425
Reply By: Isuzumu - Friday, Aug 07, 2009 at 21:04
Thanks for the replies everyone, let him know what he is up against.
I told him to check with his insurance company to see what they have under their policy. I had to check with my insurance to see what the Isuzu's could as they do not have compliance plates for towing and was told that they can tow the same as that year Jackaroo. But the tow bar on my Wizard is for a Jackaroo 1996 2500kg and 250kg tbw that is not going to happen vehicle only weights 2000kgs
AnswerID: 378076
Reply By: Trevor R (QLD) - Saturday, Aug 08, 2009 at 16:39
I pulled the Supreme with my GQ when I had it. It had no troubles pulling up Blackbutt range......surprisingly heehee. I could just go full noise at the corners up there where in the GU I have to slow down but it still did it easy if you ask me.
Others have guided you sensibly with weight issues so I won't repeat what is already said.
Cheers, Trevor.
AnswerID: 378152
