Air Lockers: Pros & Cons of diff types.
Submitted: Saturday, Aug 08, 2009 at 15:49
ThreadID: 71330 Views:7014 Replies:9 FollowUps:17
Looking at putting air diff lockers on the front of a new landcruiser ute. Thinking about Detroit verses O/L. Any comments or suggestions?
Sue
Reply By: Member - Duncs - Saturday, Aug 08, 2009 at 17:50
Sue,
My previous vehicle was fitted with front and rear ARB air locks. In my opinion they are amazing. When used properly they are incredibly versatile and forgiving. The trick is in having the air available all the time.
As soon as I went into a 4wd situation I would activate the compressor. From that time on if I wanted the diff lock I simply flicked a switch and the diff was locked, hit the switch again and the diff was open. I could lock either or both diffs almost instantly and this allowed the versatility I spoke of earlier.
There was one place I visited frequently where I needed/used both diff locks. I approached the obstacle at an acute angle and needed an open diff in the front to make the turn. Once lined up to the obstacle I engaged both diff locks until the front wheels were over the obstacle. Once again I needed an open diff to make the turn on the exit. So as I cleared the obstacle I opened the front diff and pulled on full lock then hit the button again to help get up the step. This also pulled the front wheels strait and lined the vehicle up on the track open both diffs and away we go. This al took about 10 seconds.
Maybe Detroit lockers would allow you to do the same thing without flicking the buttons but I believe from the experience of others that they are not as quiet and comfortable in day to day use. Unless this is a strictly off road/competition vehicle you don't want diff locks 100% of the time.
Duncs
AnswerID: 378154
Follow Up By: Member - Josh (VIC) - Saturday, Aug 08, 2009 at 20:07
I agree Duncs. ARB front and rear in the cruiser have been amazing. And as you say being able to turn them on and off as needed is great. Would not put anything else in personally.
Josh
FollowupID: 645533
Follow Up By: Dennis Ellery - Saturday, Aug 08, 2009 at 20:30
Keep it original if you can - Toyota will warrant thier lockers if you take them with a new vehicle purchase - 3 year warranty and they are electric too.
I have them fitted to a V8 troopy - best thing since sliced bread.
FollowupID: 645542
Follow Up By: Mrbrush - Saturday, Aug 08, 2009 at 20:44
I put a lockright auto locker in the front of my vehicle only because I got it cheap and it was never used.
I t has made a huge difference with traction in 4WD and although you can feel the steering is a little heavier but is hardly noticeable.For what I do that is plenty.
I don`t want to create a big issue over this but I can`t work out what benefit you would get with an air locker in front when it makes it very hard to steer.
Although I would never go an auto locker in the rear .
FollowupID: 645544
Follow Up By: Member - Doug T (NT) - Saturday, Aug 08, 2009 at 22:21
Mrbrush
Why not the rear, I have Detoits both ends, the thing you have to realise is that in 2wd you have better traction if you suddenly hit some slippery stuff , 2 wheels driving instead of one, it's there working all the time , for one thing they shouldn't be called Diff Locks, actually they are diff Unlockers because they Unlock under normal driving conditions ,
FollowupID: 645555
Follow Up By: Member - Ian H (NSW) - Saturday, Aug 08, 2009 at 22:22
I agree with him. Except maybe the most extreme off roading.
FollowupID: 645557
Follow Up By: Member - Josh (VIC) - Saturday, Aug 08, 2009 at 22:23
Mrbrush,
We have been in the situation were the track was slippery on a corner, then just around the corner is a step up. Front locker off for steering to get around the corner then put it on as you start on the step up to give extra traction while rear end is still in mud. Also on steep hills, muddy or just really loose gravel can flick it on to get more traction then turn off when steering is needed. Turn it back on when wheels loose traction again. Also in deep wheel ruts can flick on and off to help climb out of them if needed but still maintain steering. There is an art to using front air lockers properly and if not used properly can make a tricky situation even harder.
Josh
FollowupID: 645558
Follow Up By: Member - Doug T (NT) - Saturday, Aug 08, 2009 at 22:29
Josh
See there's another issue, you have to keep flicking the switch all the time art or no art when the going gets tough as far I'm concerned you need both hands on the wheel , with Auto's it's there all the time ,and as I stated elsewhere in this post, steering is not an issue ,
FollowupID: 645561
Follow Up By: Member - Josh (VIC) - Saturday, Aug 08, 2009 at 23:17
I don't flick the switch all the time. At best maybe 2-3 times in a really tricky situation. I'm talking crawling place, tight spot ect. Otherwise after checking the depth flick the switch and its on before entering. I guess it is personal preference and personally never had a problem with them. With the kms we have done I would rather have to flick a switch occasionally than have slightly heavier steering(as mentioned by mrbrush) on the road. I know it is minimal but over a long distance it has to make a difference to fatigue. Do they cause more wear in the front. A mate had trouble with his engaging when cornering, felt heavy with a small shudder. I've never used them so I don't know if this is a problem or not. As I said it seems to be personal preference as with most things 4wd, tyre size, tread, lift, turbo, toyota, nissan. If it works for you then it is the right choice.
Josh
FollowupID: 645567
Follow Up By: Mrbrush - Saturday, Aug 08, 2009 at 23:22
Doug,
Yes, That`s correct they should be called auto unlockers, But it just does`nt sound right I guess.
Just imagine going to a 4x4 store and asking for Unlockers, They would look at you and say, What The !
Honestly I have never experienced an auto unlocker in the rear.
My personal reason why I probably would`nt get one it the rear,is more so for the cornering issues they can have on the bitumen.I actually saw a hilux turn a corner a few days ago at work. He was only going slow as he was entering a carpark. One rear wheel was screaching like mad.
I also know a fellow worker with a locker in the rear and he says sometimes it clunks big time during cornering.
But I have read that the detroits are the smoothest in these situations.
FollowupID: 645568
Follow Up By: Mrbrush - Saturday, Aug 08, 2009 at 23:40
Josh.
The slightly heavier steering is only felt when the front hubs are locked in and 4wd engaged for when you actually need 4wd.
Driving on sand is very helpful as you have steering and extra traction permanently.
On the road you disengage 4wd and the hubs its all back to normal steering cause the wheels are free rolling. no fatigue.
FollowupID: 645570
Follow Up By: Member - Josh (VIC) - Saturday, Aug 08, 2009 at 23:45
As I said I have never used them so don't know alot about them. The 80 series is constant 4wd. Would that be different?
FollowupID: 645572
Follow Up By: Mrbrush - Sunday, Aug 09, 2009 at 00:03
OK, Im not familiar with how the constant 4wd setups work.
But I think it would be different situation.
FollowupID: 645573
Follow Up By: Sunnyheads05 - Monday, Aug 10, 2009 at 14:25
Thankyou everyone for so much valuable comment. We did consider factory fitted but the told us we had to have front and back and that wasnt what hubby wanted. It seems there is a fair bit of personal preference here, but hubby is liking the idea of no hoses or bits to get snaged with the Detroit Auto Lockers. Talking to the local distributor, it seems that the noise issues have been rectified but would need to verify that with someone who has had them fitted more recently. For what we will be doing, which is normal travel with a small percentage of towing an off road van, we think this will probably meet our needs.
Thanks for the assistance.
Sue
FollowupID: 645768
Reply By: Geoff (Newcastle, NSW) - Saturday, Aug 08, 2009 at 18:11
Hi Sue,
Have you thought about ordering them direct from Toyota?
Since you appear to be buying new from this statement, "a new landcruiser ute" it might be worth exploring the factory option.
They are electically actuated and come with the full factory warranty.
I'm kicking myself I didn't do this when I ordered my Troopy 3 years ago.
I have a rear ARB ready to go into my 78 Series.
Geoff
Geoff,
AnswerID: 378158
Follow Up By: austastar - Monday, Aug 10, 2009 at 11:06
I think the diff housings are different with the Mr. T. lockers fitted.
Thus the non locker diff housing will not take a Mr. T. locker but ARB make one to fit.
FollowupID: 645742
Reply By: Member - Doug T (NT) - Saturday, Aug 08, 2009 at 22:24
I would suggest Detroit Lockers both ends, no air compressor needed, no air lines to get torn away,and reguardless of what some say steering is probably better than air lockers because they will unlock if power is reduced , I had no steering problems across the SD dunes .
AnswerID: 378193
Follow Up By: Sunnyheads05 - Monday, Aug 10, 2009 at 14:27
We are thinking this is the way to go Doug, athough hubby is not keen on front and back. Thanks for the comments.
Sue
FollowupID: 645770
Reply By: viz - Saturday, Aug 08, 2009 at 23:53
Will Detroit lockers work on AWD vehicles? - I have heard that a mod is needed for the transfer case.
viz
AnswerID: 378204
Follow Up By: Member - Timbo - Monday, Aug 10, 2009 at 13:47
It ll depend on the AWD. Simply, they just have an extra diff in the centre so you would either have a factory diff lock on the centre (eg. Toyota LC80/LC100/Prado) or you would may need some modification to the centre diff to maximise the advantages of the Detroit Lockers.
FollowupID: 645764
Follow Up By: Member - Doug T (NT) - Monday, Aug 10, 2009 at 16:40
Viz
Yes they do but the front has to have the one called Trutrac , also made by Detroit, the Trutrac is not as aggressive as the full No-Spin Detroit.
Check this website HERE
FollowupID: 645777
Reply By: Wherehegon - Sunday, Aug 09, 2009 at 13:08
Hi Sue if buying new, ""lockers on the front of a new landcruiser ute"" get them factory fitted by Toyota, I think if you priced them up from Toyota and then from ARB etc you will find Toyota a cheaper option and be covered under warranty for 3 years and I have used the factory lockers in an 80 series sahara and they work just fine. regards Steve
AnswerID: 378245
Reply By: Member - Duncs - Monday, Aug 10, 2009 at 16:07
Sue,
This will be my final comment. If all you are doing is normal travel with the occasional towing of an off road van then do you really need any locker.
I have survived the last 7 years without any form of diff lock. As I said in my previous reply my last vehicle had them but the GU doesn't and we have done a fair bit of travel in this car including towing a camper trailer in some tuff country.
All diff locks are reasonably expensive, money could possibly be better spent elsewhere.
Duncs
AnswerID: 378381
Reply By: gbc - Monday, Aug 10, 2009 at 16:12
Auto lockers are generally not recommended for constant 4wd vehicles, although I have heard of people using them. I had a 4wd systems 'lokka' in the front of my last vehicle 2003 hilux for 230 000 kms. Best $500 I ever spent imho. Turned it from a fairly everage vehicle to a fairly capable one.
AnswerID: 378382
Reply By: Member - Doug T (NT) - Monday, Aug 10, 2009 at 16:51
Sue
I read your reply's , If your Landcruiser is the later models then you won't have any problems with sheering the 6 little axle nut studs as I did , the later model has a larger size stud , I fixed mine by adding 3 small spot welds about 3 years ago and I've had no more problems, the angle grinder will onto it soon as I plan on replacing the bearings , DO NOT allow my comments here to deter you, as said yours has larger studs, As for quietness you don't know they're there working for you 100%, your driving habits need to alter just a little, like gentle on the pedal when doing a U turn etc , very rarely and when you least expect it you will experience a kick, once again it will not do any harm, a Detroit won't break, yes you'll pay more than a cheap Lokka brand but I've always been a believer in buy a product once, one that will NOT let you down, Just a few days ago I read where someone's compressor had let them down in the SD, I'd bet my bottom dollar it was a cheap chinese brand , if they had an ARB unit they would not had the need to post about it..Enjoy your 4x4 .
Doug
AnswerID: 378390
Reply By: That Troopy Bloke (SA) - Monday, Aug 10, 2009 at 22:00
"yes you'll pay more than a cheap Lokka brand but I've always been a believer in buy a product once, one that will NOT let you down, Just a few days ago I read where someone's compressor had let them down in the SD, I'd bet my bottom dollar it was a cheap chinese brand , if they had an ARB unit they would not had the need to post about it.."
Well, that hasn't been my experience, Doug.
Last week my ARB compressor died...still within the warranty period.
Similarly my Garmin....only a couple of months out of warranty.
My "cheap Lokka" however, is still going gangbusters.
I love my Lokka :-)
So it seems that 'name' brands fail too.....
Glenn
AnswerID: 378447
