Tyre sizes - pros/cons
Submitted: Sunday, Aug 09, 2009 at 08:31
Member - Rod N (QLD)
What are the advantages/disadvantages of 16 vs 17 inch tyres. A 245/75R16 and a 245/65R17 have 24mm difference in diameter, so they are basically the same size. Apart from requiring larger
wheels for larger brakes, why are 17 inch now being fitted by manufacturers?
Reply By: Member - Shane D (QLD) - Sunday, Aug 09, 2009 at 10:05
No reason other than bling mainly, having said that Prado's,Pajero's and most of the flashy Euro stuff, need 17's to fit the brake calipers, due, I think, to traction control, they apperently "need" massive disc's.
In the bush and in almost every 4WDriving scanario 16's are better, on bituman where high speed cornering is concered the 17's will win, but who has ever bought a (proper) 4wd because of it's cornering ability and high speed stability.
Shane
378226
Follow Up By: rossco - Sunday, Aug 09, 2009 at 10:34
Does anyone know if a 16 inch steel wheel from a GXL will fit on a 2006 VX T/D ifs landcruiser?
Some say there may be larger brake calipers on the VX and Saraha but others say they will fit with no problems.
Any help will be appreciated. Rossco
645597
Follow Up By: Krakka - Monday, Aug 10, 2009 at 06:09
Rossco, Iwould imagine that as long as the rim off of the GXL had IFS it would be suitable. As far as I know the only thing to watch out for is mixing rims between IFS and rigid front end.
Krakka
645708
Follow Up By: rossco - Monday, Aug 10, 2009 at 16:21
Thanks Krakka .
I might try a rim on before I buy just to make sure.
Regards Rossco
645776
Reply By: Member - Oldplodder (QLD) - Sunday, Aug 09, 2009 at 19:09
I would imagine that the 65 series might give lower
fuel consumption if the same make and type were used on each rim. Less rolling resistance.
Better handling and brake cooling with the 65 series for use on bitumen, which is where most 4wds are used these days.
378286
Reply By: RobAck - Sunday, Aug 09, 2009 at 19:44
17" provides a much better ride and handliing equation and with modern 4WD being engineered for these
wheels and tyres then expect it to be the norm.
The issue has nothing to do with appearance it is related to the engineering and handling benefits that arise from using taller tyres with slightly lower pofiles to enhance on-road handling and steering response. Remember this is where the majority of 4WD spend their life
Get used to it as the new Prado will come with 18 rims and tyres in the two top spec models
Having run a 120 Prado for the last five years I have no problem with 17 rims and tyres and we do around 20000 km off-bitumen each year
RobA
378294
Follow Up By: TerraFirma - Sunday, Aug 09, 2009 at 19:56
Yes and the new VX 200 series cruiser update models will have 18"
wheels.
645665
Reply By: Robin Miller - Sunday, Aug 09, 2009 at 20:09
The 16 rims allow an extra 1/2 inch of tyre deformation before the rims hit, this is very handy when your tyre pressures are lowered and translates to a longer tyre foot print and better traction.
378300
