Wanted to borrow for a few weeks 80 series rear bumper.
Submitted: Sunday, Aug 09, 2009 at 20:36
Flywest
If anyone in WA
Perth environs has a 80 series rear bumper laying round I'd love to beg, borrow, steal or rent it for a few weeks to use as a template to measure against, while I make a rear whell swing away carrier for our 80 series wagon.
Sorry my puter won;t let me post a wanted add in trader section for some crazy reason, so I put it here.
Many thanks in advance.
Reply By: Member - Phil B (WA) - Sunday, Aug 09, 2009 at 22:51
Flywest
It actual comes in 2 peices -
well my GXL one did. The left and right sides and are both 'plastic.'
Are you making a single wheel or dual bumper?
378320
Follow Up By: Member - Phil B (WA) - Sunday, Aug 09, 2009 at 22:53
Oops pieces
645699
Follow Up By: Flywest - Monday, Aug 10, 2009 at 01:23
Trying to make a dual one with new heavier bumper incorporated.
Was lucky enough to get 2 matching L & R swing away carriers off exploroz trader section, and have my length of C channel steel - just need a template in a old bumper bar to copy as a template and for critical measurements like brackets bolt hole locations etc.
Least thats the plan.
645706
Reply By: new boy - Monday, Aug 10, 2009 at 10:15
Find out who does the conversions from wagon to try back I have been told from a mate whose had it done that they have rear panels ,lights ,bumper bars ect stacked up and are only to please to give away.
Sorry I cant give you a name but must be in the yellow pages.
378345
Reply By: Flywest - Monday, Aug 10, 2009 at 16:40
Thanks for that advice - I tracked down TL Engineering in WA who do the conversions - but the 8o series is too old for them - they only do new vehicles so have no 80 sereies ones laying around.
The 4wd wreckers have one I can buy for $660........yeah - as if.
Looks like I'll have to rip the original off our vehicle and just drive round a couple weeks without one while I make the new one.
Least I know what to sell the old one for when I'm finnished! LOL.
Thanks indeed everyone.
378388
Follow Up By: Hairs & Fysh (NSW) - Monday, Aug 10, 2009 at 17:01
What do they mean ' the 8o series is too old for them'
There are plenty of the old girls still running around. :)
Be sure to post pics when you have finished it. I've been thinking about having one made.
645780
Reply By: Flywest - Tuesday, Aug 11, 2009 at 00:32
Wondering if maybe I've bot off more than I can chew...
The steel C channel I bought, is 150 x 75 x 7 mm thick - it seems wy too heavy for this application but thats all the steel joint could sell me in that configuration of 150 x 75 C channel.
Not sure that I can successfully heat and bend 7 mm thick steel even with the oxy torch, and cutting this stuff even with the drop saw etc isn't going to be easy.
Have mig arc and oxy set so really no excuse for not getting it right - its the steel engineering area I lack expertise in.
Do I just cut right thru the C channel at the appropriare angles then reposition at the right angles & weld back together, or just cut & remove the 2 x 45 degree 'V's out of top & bottom 75mm flanges and try to heat and bend the 150 section wth oxy until the top & bottom flange V's close up then weld those shut again, to radius the bends around to 90 degrees each side for the bumper returns?..
Not sure as yet which way to go...it's a lot heavier steel thanI originally intended.
That in itself would normally be a bad thing (weight and
fuel economy) etc except the lad jacked the back end up a couple or so inches, a while back with a
suspension lift of new springs and shocks to carry the extra weiight of his 175 liter long
ranger tank and 146 liter LPG
tank in the rear compartment.
It was a good idea, but overdone - even when loaded the back is still way too high and it oversteers a bit still - I'm hoping the heavy rear bumper and two spares etc will maybe lower those new springs a bit more - closer to what they originally were maybe.
I reckon completed this will weigh maybe 200 kilos all up with two spares mounted. That will mean 200kilos for bumper and carriers / spares, 175 kilos for diesel and 140 kilos for the lpg, total 515 kilos, over the back wheels/axle - maybe then it will sit back somewhere near level.
We shall see I guess.
Decided to loan the lad my truck for the week and I'll keep his to use his rear bumper!
Photo's to come.
378464
