Help with engel fridge please
Submitted: Monday, Aug 10, 2009 at 07:47
ThreadID: 71369 Views:4084 Replies:7 FollowUps:6
Hi all
We have a 40 ltr Engel that has just "died".
The power light still comes on and it sounds like the fridge is trying to start but can't.
Any suggestions? We live in Darwin.
Lyndon
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
Reply By: Member - Ian H (NSW) - Monday, Aug 10, 2009 at 07:53
This might sound like a silly question but are you sure it is getting a full 12 volts with no voltage drop? Has it been running normally connected to the same supply? Can you try another power source that is confirmed reliable/
Try the simple things first.
AnswerID: 378327
Follow Up By: Member - lyndon K (SA) - Monday, Aug 10, 2009 at 08:04
Hi Ian
It's on 240 at home, have not tried on 12 volt for a few weeks.
Cheers Lyndon
FollowupID: 645720
Follow Up By: Member - Ian H (NSW) - Monday, Aug 10, 2009 at 08:39
Hi Lyndon,
Sounds like a job for the tech guy but would be worth trying it on 12v to see what happens. Good luck with it.
FollowupID: 645725
Follow Up By: Member - Scoof (SA) - Monday, Aug 10, 2009 at 08:43
I had trouble with my Engel 40 L frig once it worked on 240 but not on 12volt it turned out the power lead was faulty.Had it now for over 10 years now no other problems. Hope yours it that simple.
Scoof . :-)
FollowupID: 645729
Follow Up By: vk1dx - Monday, Aug 10, 2009 at 08:50
We just had to replace our power lead. The fridge end came apart "inside" the plug. Excellent fridge but absolute rubbish plug. The wires broke off the "brass" connector inside the plug.
Maybe yours is coming apart and with only a small number of wire strands you are not getting the full voltage.
FollowupID: 645732
Follow Up By: Kevin P - Monday, Aug 10, 2009 at 08:59
Lyndon, try using a different lead, the one on your PC will work. then also replace your 10 amp fuse.
FollowupID: 645735
Follow Up By: Member - lyndon K (SA) - Monday, Aug 10, 2009 at 18:00
Thanks Kevin, but my laptop cord doesn't fit. No home PC.
Thanks for the idea though :)
FollowupID: 645787
Reply By: Serendipity of Mandurah (WA) - Monday, Aug 10, 2009 at 09:13
I had an engel years ago that had blown its 240v to 12 inverter. This engel had a real rough life and was 15yrs old when I got it second hand - and I had it for another 15years before selling it for a good profit. It would run fine on 12 v but not on 240v. To plug in the 240 it was completely dead. Paid for a new part to get fitted and it was fine forever. If your light is coming on that sounds different.
My waeco had a similar problem to yours. All lights on and sounds like it tries to start up but just not happening after that. Turned out to be the temperature sensor had packed it in - replaced under warranty.
My other waeco kept getting an error light - turned out to be the entire mother board - replaced under warranty. This same waeco also had a blown 5amp fuse at one stage - same deal - a lights one but no pump - replaced under warranty.
Lucky all these things keep happening while my waecos are under warranty. Unlike my other engel which probably won't blow up for 20years when it is not under warranty any more.
David
AnswerID: 378335
Reply By: bobsa - Monday, Aug 10, 2009 at 11:32
Hi lyndon,
if you need some advise, give LM Rees at Wynette st, Pennington a ring he is the engle man in SA , nice bloke very far to deal with.
If this is the grey electronic model you could be introuble, I do repair them, but have to send them to Lydnesy to get the electronics checked. if the compressor is gone normally the board is too and it become to expensive to repair.
I hope it is only a thermostat stopping it running, then will be an easy repair.
being on 240 and the indicator light is on makes me think the lead is ok, give it a try on 12 volt and see what happens.
goodluck, regards bob
AnswerID: 378352
Reply By: bobsa - Monday, Aug 10, 2009 at 11:34
sorry, did not see that you are in Darwin , I have not got any contacts in the trade in Darwin
bob
AnswerID: 378353
Reply By: Member - Doug T (NT) - Monday, Aug 10, 2009 at 11:54
Lyndon
Myself and Noel K recently went to BCF in Darwin and got one for the truck, I wonder if they have anyone there that could help ,
[Member - lyndon K (SA)] how come you still have (SA)...???? if you live in Darwin.
AnswerID: 378355
Reply By: Member - AJB (VIC) - Monday, Aug 10, 2009 at 17:59
My old 39 litre did the same thing about 4 years ago. I think is was the compressor and the local service agent repaired it for $500. It was about 12 years old then and has been fine since.
AnswerID: 378403
Reply By: Twintrail(W.A.) - Tuesday, Aug 11, 2009 at 00:10
hi llyndon.i had trouble with my engel ss 39lt in 2006 and had running repairs made on the road. took to the engel agent in darwin (hard to locate)but fixed for free under warranty.regards Pedro
AnswerID: 378462
