David .re payment options
Submitted: Monday, Aug 10, 2009 at 20:25
Member - BUNDY BOY (WA)
hay there David
trying to buy 2 sand flags but when i hit checkout .....then next ...keeps telling me to enter post code and country ....in
shopping cart area .....and the details are there ....have tried to change them and try again but with no joy....let me know what u think plz ..
Cheers Bundy
Reply By: Bonz (Vic) - Thoughtfully- Monday, Aug 10, 2009 at 20:32
Bundy I have passed this onto David
378425
Reply By: ExplorOz - David & Michelle - Monday, Aug 10, 2009 at 20:38
I will check this out in a few secs - I have just installed by accident a major change to the back end code - I cannot revert to where I was I have to push forward and resolve all issues as they arrise. I will test this one in a minute and let you know.
David
378427
Reply By: ExplorOz - David & Michelle - Monday, Aug 10, 2009 at 20:58
Bundy,
problem now sorted - sorry for the error and thanks a lot for letting us know - it was causing all
shop orders to not work.
DM
378433
Follow Up By: Member - BUNDY BOY (WA) - Monday, Aug 10, 2009 at 21:05
AA Thanks david
Bundy
645819
Follow Up By: Member No 1- Tuesday, Aug 11, 2009 at 08:03
same old story....thought you would have learnt by now David...."if it aint broke dont fix it"
by saying that, after i clicked on "post follow up" in this thread to post the above line it would normally take me to the login screen ( i never login automatically,
well ever since i started using firefox anyway cos i cant get it to work and now just live with it)...
well any way it used to take me to the login screen...all i got this time was java script i think its called. tried it in another thread and same thing happened. I needed to login via the icon.
645851
Follow Up By: ExplorOz - David & Michelle - Tuesday, Aug 11, 2009 at 18:47
Fixed now No. 1 - I will make the next change shortly that will open up the Login panel at the top of the page when you click on the POst Reply or Followup links.
Why are your cookies not working - have you tried to clear all cookies and start again?
I will write a little routine shortly to allow you to clear all ExplorOz cookies - should have done this ages ago. Let me get it working and I will tell you how to run it.
DM
645920
Follow Up By: ExplorOz - David & Michelle - Tuesday, Aug 11, 2009 at 20:04
No 1.
I have just added a Cookie reset system in the Login drop down system at the top of the page. So when you are next visiting and not logged on try hitting the
Logon Icon or
Logon text message in the top line of the system and you will see in the RHS panel a button called Reset Cookies - click this and answer OK - this guys will force remove all cookies set on your computer for ExplorOz so should hopefully fix the Auto
Logon issue for you - Once you have cleared the cookies
logon right on the same screen and select the Remember Me and let me know how it goes.
DM
645928
Follow Up By: Member No 1- Wednesday, Aug 12, 2009 at 08:14
geeee
you didnt have to go to all that trouble for me David
anyway thanks, i'll give it try and see if it works....i pressed the reset button and got the message that it deleted 4 EO cookies...gunna give it a try now
645989
Follow Up By: Member No 1- Wednesday, Aug 12, 2009 at 08:21
oh
well.....looks like i'll need to live with it a bit longer
signed and checked the remember me box and pressed enter
shut down and clicked the email reply to this and it still needs me to login before i can reply....the 1st bit is fixed though....blooody firefox grrrrr!
645993
Follow Up By: Member No 1- Wednesday, Aug 12, 2009 at 08:27
IE lets me login auto.....
dont waste any more time on it david...its something this end (ME most likely) not your end
blooody firefox.....grrrrrrr
645994
Follow Up By: ExplorOz - David & Michelle - Wednesday, Aug 12, 2009 at 10:32
Interesting - I use Firefox the most of all - it is fast and relaible coupled with Firebug (development debugger) it is really good. Weird that your FF will not remember your settings. Tell me when you go to the login page does it remember your member id? This will tell us if the cookie is being removed.
Also once you have logged on go to Tools - Page Info - Security and look for a cookie with the name like Hv91scbq%2fIg%3d - it will be from the site exploroz.com - click it to highlight it and then have a look in the info panel at the end of the page and have a look at the Expires setting - it should be a year. Does this exists? What does the Expires value say?
DM
646005
Follow Up By: Member No 1- Thursday, Aug 13, 2009 at 06:12
it says end of session
646119
Follow Up By: ExplorOz - David & Michelle - Thursday, Aug 13, 2009 at 10:32
Ok then you have a config setting that is causing this to expire. Go to Tools - Options - Privacy - Cookie Exceptions : in this list I suspect you will find www.exploroz.com with a setting of Allow for Session - Remove the site from the list or change it to Allow. If it is not shown then add it so in the Address box type www.exploroz.com and the click Allow. Once this is done it should be solved.
Give it a whirl and let me know how you get on.
DM
646145
Follow Up By: Member No 1- Thursday, Aug 13, 2009 at 13:54
ah ah...your a genius David....
added EO and checked allow and all works ok now
thanks a million
646179
Follow Up By: Member No 1- Thursday, Aug 13, 2009 at 13:56
still got me beat as to why i couldnt get it working....i've been doing it manuaaly for so long i have forgotten what i tried and or didnt do
646180
Follow Up By: ExplorOz - David & Michelle - Thursday, Aug 13, 2009 at 16:18
Glad it is sort now - I suspect at one time you were promted as to what to do with the cookie and at the time you selected the Expire at Session end - it remembers this for ever so you would have to manually change it back to get it to work - as you now have.
Happy to help.
DM
646198
