ARB Canopy Parts
Submitted: Monday, Aug 10, 2009 at 21:02
ThreadID: 71394 Views:14182 Replies:3 FollowUps:4
I am trying to locate the window manufacturer that makes those fold open style of windows seen on vehicle canopies such as ARB or Flexiglass. Mine is a ARB on a 2002 Rodeo so it could also be a 2002 canopy. The windows and locks are the same on mine and the current flexiglass canopy but the current ARB ones are different. Canopy manufacturers dont actually have parts service. If the current model canopy has parts that suit you are in luck otherwise unlucky.
I am trying to get some replacement locking tabs that stop the side window locks from spinning on their axis. While the current flexiglass locks are the same the tabs are different. The windows have not been sealing properly and moisture has entered the window frame slits that locate these tabs and rust has all but consumed them. These canopy people buy the windows by the crate load but I am unable to find the source.
THese side windows have stubby T handle locks and seem to have been around for years. Canopy window or lock suppliers, any ideas ?.....thanks Peter
Reply By: itsdave - Monday, Aug 10, 2009 at 22:31
Try your local ARB supplier. I needed parts for my ARB canopy and they were only to willing to help.
Cheers Dave
AnswerID: 378453
Follow Up By: kwk56pt - Tuesday, Aug 11, 2009 at 01:29
Provided the parts you require are the same as the parts used on their current crop of canopies no worries, parts from a superseded model, less pleasing. I was told the new type locks would fit with the supplied adapters but when I went to fit them I found that was not the case.
FollowupID: 645843
Follow Up By: itsdave - Tuesday, Aug 11, 2009 at 09:15
I actually went to ARB in Hendra, Brisbane for the parts I needed, handles and locks. They fitted them for me and didn't charge for either parts or fitting. I think this particular ARB is where they make and assemble the canopies, may be worth a phone call to them.
My canopy is of the older style
Cheers again
Dave
FollowupID: 645863
Follow Up By: kwk56pt - Tuesday, Aug 11, 2009 at 11:13
Thanks Dave I will contact ARB in Hendra Brisbane to see if they can help, its worth a try by the sound of it.
FollowupID: 645873
Reply By: Member - ross m (WA) - Tuesday, Aug 11, 2009 at 01:39
"Canopy manufacturers dont actually have parts service"
Thanks for that,I was considering buying a canopy one day.
As to your problem Industrial Rubber in Welshpool WA have a large range of these type of locks
http://www.indrub.com.au/hardware.html
AnswerID: 378467
Reply By: Member - Donks1 (NSW) - Tuesday, Aug 11, 2009 at 10:42
You can contact ARB through their web site
ARB Contact
I did this for my canopy, and got a phone call to confirm exact parts I needed.
They checked stock and gave me the part numbers so I could order from the local distributor. Picked them up a few days later.
Donks1
AnswerID: 378492
Follow Up By: kwk56pt - Tuesday, Aug 11, 2009 at 11:09
I rang that number under ARB contact this morning. They say the locks are american made by a company called creations which are no longer in business. They were aware the tabs rust and suggested to me that other customers had been able to fabricate replacements for them from sheet metal.
FollowupID: 645871
