A variation on the Waeco fuse issue
Submitted: Monday, Aug 10, 2009 at 21:27
ThreadID: 71398 Views:4720 Replies:4 FollowUps:3
was changing the plugs to anderson plugs on my waeco fridge this afternoon and accidentally shorted the wires, this blue the 15v fuse in the line from the battery. now i have the fuse replace the fridge wont run on 12V, but runs fine on 240V
Questions:
Is it likely that i have blown a fuse in 12V circuit of the fridge? If so can this be replaced easily or is it a service agent job?
I have read the threads about the poly fuse but this is slightly different to these issues.
Reply By: dbish - Monday, Aug 10, 2009 at 21:37
If you removed the cigarete plug from the line you shouid have fitted an inline fuse to the cord as there was one in the original plug to protect the fridge.
AnswerID: 378441
Follow Up By: blueriderwa - Monday, Aug 10, 2009 at 21:43
ok so if there was no in line fuse is there one in the fridge or have i burned something else out in the fridge?
FollowupID: 645826
Follow Up By: Member - Tony Z (NSW) - Tuesday, Aug 11, 2009 at 20:25
You are correct dbish. replaced the fuse inside the cigarete plug just the other day got a couple extra just in case for when on the road also some 240v fuses as well
FollowupID: 645933
Reply By: blueriderwa - Monday, Aug 10, 2009 at 22:07
Sorry guys false alarm, i just went and checked something and it's all good.
Dave
AnswerID: 378450
Reply By: dbish - Monday, Aug 10, 2009 at 22:16
Just went @ looked @ my CF40 &looked through grills & cant see any fuse inside if it still works on 240V it dosnt sound terminal you may need to take it to a Waeco repair center. Also double check polarity The lead with raised strip down it is Negative.
AnswerID: 378452
Follow Up By: blueriderwa - Monday, Aug 10, 2009 at 22:26
Thanks mate,you know what ... you got it in one! just frightened the cr%^ out of the wife by taking the nissan from the carport to the shed to test it, she thought someone was stealing the car lol.
Anyway i dont know how i did it but i got the polarity around the wrong way on the fridge plug. Stuffed if i know cause i thought i'd checked that pretty well. Anyway thanks for your help.
Anyway my motto is :
"SORRY BUT I REFUSE TO STOP TRYING THINGS THAT I COULD GET WRONG JUST BECAUSE I COULD GET THEM WRONG!" I guess this is a good example.
i will put the inline fuses in tomorrow to help protect the fridges from damage anyway.
FollowupID: 645833
Reply By: dbish - Monday, Aug 10, 2009 at 22:42
Good result If you have never made a mistake You have probably have never done anything!!! cheers.
AnswerID: 378456
