3way electrolux caravan fridge
Submitted: Tuesday, Aug 11, 2009 at 22:37
ThreadID: 71427 Views:3178 Replies:1 FollowUps:1
Works ok on gas but fails on 240volts, seems ok on 12volt whilst towing,
any help out there, please??
Reply By: Roughasguts - Tuesday, Aug 11, 2009 at 23:03
Probably your 240 volt heater element.
It's seperate from the 12 volt one.
Cheers.
AnswerID: 378593
Follow Up By: Tenpounder (SA) - Wednesday, Aug 12, 2009 at 08:45
Hi. I was told the 240v element is more likely to fail than the 12 v one.
Either is simple to replace, if you can get to the back of the fridge easily. Obviously, you need to check the 240v supply to the fridge before you invest in repairs.
If you are tempted to run the fridge off 12v via a power supply, just remember the fridge will draw up to 15 A at 12 V (12 A continuous) if it like mine.
FollowupID: 645996
