Lift, Panhard Rod & Fuel Economy
Submitted: Tuesday, Sep 09, 2003 at 23:38
CC
I am planning to buy a new set of heavy duty Dobinsons springs which according to Dobinsons should give my Surf a modest 20mm lift.
For that amount of lift, do I have to worry about changing the Panhard Rod ?
Also, with the lift which is going to increase the angle of the drive shafts, should I expect any increase in drivetrain noise and vibration, and also an increase in
fuel consumption ?
Any experience will be appreciated. Cheers.
CC
Reply By: Member - Scooby (WA) - Wednesday, Sep 10, 2003 at 16:25
CC,
My previous vehicle was a Surf. I had a 50mm lift with heavy duty springs in the rear and the torsion bars wound up. I had no problems, did not change the panhard rod, no vibration, no change in
fuel consumption. Was a bit firm when not loaded.
ScoobyHilux Dualcab, 3 litre diesel
30678
Follow Up By: CC - Wednesday, Sep 10, 2003 at 17:42
Scooby,
Thanks for the info. It makes me more confident to go ahead with the changes.
Cheers.
CC.
21713
Reply By: Member - Scooby (WA) - Thursday, Sep 11, 2003 at 09:39
CC,
I forgot to mention in my previous post. If I was going to upgrade the
suspension in a Surf again I would not use h/d springs, the ride is too hard without a load.
I would go medium duty and Polyairs. Much more comfort and adjustment available by varying the air pressure in the Polyairs.
30754
