Wednesday, Aug 12, 2009 at 19:14
Gronk
I tried earlier to post a response but took too long and was timed out and lost what I had done.
The more batteries in that are paralleled the more chance of problems and inefficiencies.
Larger batteries and smaller quantities are better.
Batteries in series are the most efficient so two 6Volts are more efficient than two twelve volt as they work together to reach a terminal voltage where two supposedly equal batteries fight each other for charge and one will win with the other suffering a charge deficiency which continues to compound eventually causing premature failure.
Most Asian sourced AGM batteries are low recombination batteries where Good AGM batteries that are high recombination are of USA origin.
This is reflected in the price as high recombination is expensive.
A high recombination battery is low resistance and although voltage limited can accept high amperage and charge faster to a higher voltage than low recombination batteries.
Low recombination batteries have a higher resistance and are limited in the recharge capacity that takes longer to charge and running time is money.
The sooner a battery is charged the sooner the alternator cuts load and the economy of the vehicle improves.
A high recombination battery with correctly sized cables is efficient to the point that the use of units like the Ranox and other wide ranging acceptance voltage smart chargers strangle the alternator where a battery is discharge to 50% due to their limited output amps and a smart charger should be able to use whatever the alternator has in reserve capacity.
The marine industry is one that the efficiency is critical and its one that we specialise in and our work is gleaned from referrals as we do not advertise.
People talk and everywhere a yacht docks fitted with Sterling or ProMariner equipment it usually means we get a request for information and in the last week we have had calls from Vanuatu,Noumea,
Cairns,
Townsville and Port
Nelson New Zealand.
It is now starting to happen in the land RV industry so it must mean something is working efficiently.
Ian
646057
