HDJ78R troopy
Submitted: Wednesday, Aug 12, 2009 at 17:27
WorkingNavara
Hi all,
I am close to buying a troopy but have a couple problems to sort before hand.
1. Currently 11 seater setup - I want to change to 5
seat setup like the RV troopy. The dealer has said that I will need to get an engineers certificate to do this to make it legal for rego and insurance.
2. Finding the seats...?? Could be difficult .
3. Are the RV model front seats the same as the non RV model to access the rear from the front doors?
Thanks for the help..
Marco
Reply By: Geoff (Newcastle, NSW) - Wednesday, Aug 12, 2009 at 17:37
1. The dealer has said that I will need to get an engineers certificate to do this to make it legal for rego and insurance.
Correct.
Very true, it's hard enough finding a whole RV on the secondhand market let alone just the seats.
No, different. The 5 seater RV's have bucket seats in the front. The passengers side bucket slides further forward than the drivers to give rear
seat access.
Hope that helps,
Geoff
| Geoff,
378682
Follow Up By: WorkingNavara - Wednesday, Aug 12, 2009 at 18:11
Thanks Geoff for your confirmation.
Might be a case of keep looking for the RV..
646046
Follow Up By: get outmore - Friday, Aug 14, 2009 at 22:39
mmmmmm the only RV I have seen DID have a fancy
seat that swivelled or something to allow access
- was a while back but yes was completly different
646455
Follow Up By: Geoff (Newcastle, NSW) - Saturday, Aug 15, 2009 at 08:23
"the only RV I have seen DID have a fancy
seat that swivelled or something to allow access"
And it would have had a leaf sprung front end as
well as a normally aspirated 1HZ engine.
The very early RV's still had the 2 - 1 front seats like the poverty pack 11 seater troopy's.
The later one's have two front buckets.
Geoff
| Geoff,
646469
Reply By: Troopy(SA) - Wednesday, Aug 12, 2009 at 18:43
Hi Marco,
I did what you are looking at doing - my troopy was an 11 seater.
I took out the side facing rear seats myself and found a suitable back
seat at the wreckers - it was the back
seat (2 seater) from a SWB pajero.
I then took it to a
seat installer to get installed - they did the install and certificate (this is in SA), the main issue when getting the certificate was how the seatbelts were installed.
I suggest contacting a car
seat conversion/installation business to get advice - I can give you details for the company I used if you are in
Adelaide
378696
Follow Up By: WorkingNavara - Thursday, Aug 13, 2009 at 19:16
Troopy,
I have found an aftermarket installer who will do the job for $1500 - new bench
seat installed with child restraints and engineer cert.
So it looks like a go for the troopy. Problem is the front seats still but will eventually get around this one.
Marco
646227
Reply By: Atta Boy Luther - Wednesday, Aug 12, 2009 at 19:19
Lots of
places do after market seating . For just over a thousand bucks they will supply the 3 seater and install lap sash retractable belts on the side and lap only in the middle and certified as
well . My bench
seat folds up behind the front seats and i have the entire back like in a 3 seater if i want . Get rid of the front seats and put in a pair of height adjustable from the wreckers . These will have to be complied as
well .
378704
Reply By: greyemu - Wednesday, Aug 12, 2009 at 20:23
Working navara
I had a 75 troopie which was registerd as a 11 seater. I went to a mechanic who could issue blue slips, he issued me with a certificate to say that it had changed to a 5 seater. It cost me $38.00 back in 2004. I hope this helps.
Regards greyemu
378710
Reply By: Member - Trevor the driller - Friday, Aug 14, 2009 at 20:27
G/day WN I have a current model troopy which I converted from 5 to 2 seats. Make us a offer. Trevor
379028
Follow Up By: WorkingNavara - Friday, Aug 14, 2009 at 21:00
Trevor,
Thanks. Thought finding the seats was going to be really hard.
Can I ask what number would not offend you?
Marco
646429
