Kia Sportage
Submitted: Wednesday, Aug 12, 2009 at 19:47
ThreadID: 71451 Views:2566 Replies:5 FollowUps:1
What would be the best way to see if the front hubs are engaging on a Kia Sportage?
Reply By: Member - Shane D (QLD) - Wednesday, Aug 12, 2009 at 20:38
Jack up one front wheel and see if it turns by hand (in 4wd), if "locked" then so is the hub, do the same on the other side, should get the same result, make sure you are on level ground and handbrake on.
Shane
AnswerID: 378714
Reply By: Best Off Road - Wednesday, Aug 12, 2009 at 20:40
Mate,
This is not a go at you, but if you want a decent answer, ask a decent question.
What model is it?
Is your's constant or part-time 4wd?
Does it have manual or auto hubs
Under what conditions do you think it is not engaging 4wd?
Etc, etc...
This is a most friendly forum and you'll get good advice if you give people a chance to answer.
I hope this helps, and I stress it's not a dig at you.
Jim.
AnswerID: 378715
Reply By: PerthStorm - Wednesday, Aug 12, 2009 at 21:13
hi
it is a 2002 sportage with auto locking hubs, I cant give too much info on it as I am asking for my dad.
I heard the vacuum locking hubs have a lot of problems and since my dad got stuck in sand the other day I was wondering if this may have been the problem
AnswerID: 378721
Follow Up By: Roughasguts - Wednesday, Aug 12, 2009 at 22:02
Pretty simple really put the rear wheels on a driveway or hard surface and the front wheels on gravel or grass.
Then put the hand brake on and plant you foot! see if you get front wheel spin.
It only needs to grip a bit to make a mark on the soft stuff, and give you an idea of the front hubs engaging.
FollowupID: 646088
Reply By: Member - Kiwi Kia - Wednesday, Aug 12, 2009 at 22:30
I have a 2000 Sportage and it does not have vacuum operated hubs. They are automatic and have a torque engauging system. Don't know if your 2002 vehicle is the same.
KK
AnswerID: 378740
Reply By: Member - Timbo - Thursday, Aug 13, 2009 at 12:31
PerthStorm, the most common way to check that the 4WD system is working is to drive it onto a level but unsealed surface (ie. grass, gravel, dirt, etc.), engage 4WD (including locking hubs, etc.) and turn near full lock. Start driving slowly and once you've driven about 1 car length, push the clutch in (or select N in an auto). If 4WD is working, the car should stop immediately.
If this is inconclusive, keep driving slowly while still holding the steering at near fulllock. If 4WD is working, the inside rear wheel should be trying to turn faster than if it was just rolling along - on gravel you'll be able to hear it slipping (if you have the window down) or else get an observer to watch it.
Otherwise you could just get under the car (while it's stopped of course!) and see if you can rotate the front shafts (just inside the front wheels) by hand - if the hubs are unlocked, you should be able to turn the shafts by hand, but you won't be able to turn them if the hubs are locked.
AnswerID: 378806
