Buying my first 4wd - slight change of plans
Submitted: Wednesday, Aug 12, 2009 at 19:57
ThreadID: 71453 Views:4221 Replies:3 FollowUps:6
Hi again, due to a slight change in my job, well quitting. I've decided to do some courier work. I will be going for a ute, preferably a tray top dual cab/space cab type thingo. I notice there are a few 4wd versions of the rodeo, triton, ford courier and ranger etc.
As usual, I need to stay under $15000, which engines should I stay away from and which ones are good value? Most of the 4wd utes around my price range are about 110-140,000kms
Thanks, Rick
Reply By: Best Off Road - Wednesday, Aug 12, 2009 at 20:56
Rick,
For courier work, and I'm assuming most of it is suburban, steer clear of a diesel. Courier work is all about making a quid and you'll get the cheapest dollar per km running a petrol powered vehicle on LPG.
For $15,000 I'd suggest going for one of the less popular utes as you'll get a younger, lower km vehicle. Avoid Hilux like the plague as they command a ridiculous price premium because they wear the Toyota badge. Nissan are a little cheaper, but I'd give them a wide berth as well.
Have a look at Tritons, Rodeos and Bravo/Courier. I went through the same process nearly two years ago and ended up with a Ford Courier.
Is it he best 4wd ute on the market? Probably not but it is a good serviceable ute, quite good off road and cheap as chipps to buy and run.
Very grunty (albeit a bit old tech) 4L V6.
Hope this helps.
Jim.
AnswerID: 378717
Follow Up By: jarz85 - Wednesday, Aug 12, 2009 at 21:20
Hypothetically, if i got a 2wd rodeo/triton etc they could go better offroad than a 2wd commodore? Even though they are 2wd they would have the same body/suspension etc? I mean for driving on dirt/stone roads not thru mud etc
FollowupID: 646081
Follow Up By: Stu & "Bob" - Thursday, Aug 13, 2009 at 08:00
A late 90's model 2WD tubo diesel rodeo would be the go, I think.
60 litre fuel tank, 700 odd km's between fills.
My .02
FollowupID: 646128
Follow Up By: The Lobster - Thursday, Aug 13, 2009 at 11:42
No. 2WD and 4WD vehicles don't have the same suspension setup. 2WDs have far less ground clearance than 4WDs. A 2WD rodeo may do better off road than a dunnydore, but it still won't get you very far. If you want to do off-road stuff you must get a 4x4, otherwise your friends with 4x4s will get sick of recovering you very, very quickly.
matt
FollowupID: 646152
Reply By: Madfisher - Wednesday, Aug 12, 2009 at 21:17
The Mazda/Couriers td seem to do heads at an early age so stay clear of those.
Cheers Pete
AnswerID: 378722
Follow Up By: jarz85 - Wednesday, Aug 12, 2009 at 21:19
Yea I wont be going for a diesel thats for sure :) Petrol then put it on to gas imo
FollowupID: 646080
Reply By: brushmarx - Thursday, Aug 13, 2009 at 10:07
Just for alternate thinking, what about one of these new Chinese Great Walls, or even Tata or Ssanyong ?
I haven't checked pricing, so they may be out of your nominated price range, but if you got a reasonably priced new cheepie brand, and as long as the warranty covered a replacement vehicle for servicing or breakdown, the warranty may make it a worthwhile option, and a newer technology engine may give better economy than an older model "quality" vehicle negating a gas conversion.
Ian
AnswerID: 378784
Follow Up By: brushmarx - Thursday, Aug 13, 2009 at 10:16
Forgot to add, with the Krudd tax incentives on capital purchases on new vehicles, it may also make the real purchase price better, but I am not an accountant, so you could check with experts.
FollowupID: 646143
Follow Up By: Member - Timbo - Thursday, Aug 13, 2009 at 12:42
That's right Jarz, there can be all sorts of tax advantages for buying a ute for work purposes (although I think many of these do not apply if it is a 4WD ute). It would pay you to check with a financial planner/adviser as it may well be mor economical to buy a new vehicle on a novated lease than hand over your own cash for a second hand one.
FollowupID: 646161
