Tyre diameter difference 265/70/16 - 265/75/16
Submitted: Wednesday, Aug 12, 2009 at 21:40
vk1dx
One for the mathematicians.
Can anyone tell me how much height I am losing by putting on a 70 profile tyre as opposed to the current 75 profile?
Current size: 265/75/16,
Alternate size: 265/70/16
Reply By: Gone Bush (WA) - Wednesday, Aug 12, 2009 at 21:46
Reply By: Lex M (Brisbane) - Wednesday, Aug 12, 2009 at 21:47
Reply By: olcoolone - Wednesday, Aug 12, 2009 at 21:50
265/70x16 (773mm)
265/75x16 (805mm)
Give or take up to 5mm's depending on tyre brand and type.
You will loose between 10 to 15mm in height.
378733
Reply By: equinox - Wednesday, Aug 12, 2009 at 21:51
That would be about 13mm.
I went the reverse way that you are proposing.
378734
Follow Up By: vk1dx - Wednesday, Aug 12, 2009 at 21:57
Thanks Al. I need a slightly more offroad tyre for a trip next year. The ones ofeered are 70 profile. We do not really need the extra height as we don't tow nor do we climb over rocks. But I must admit I have climbed over a couple of trees. Couldn't pull them off the track so climbed over.
646087
Reply By: vk1dx - Wednesday, Aug 12, 2009 at 21:54
Thanks Gone Bush and Lex.
I drop 1" and go 3.5KPH slower. That won't be a problem as I am putting heavier springs in next week and they will go up 2" and the smaller tyres will only bring me back 1". This all works out better in the long run.
378735
Reply By: donk - Wednesday, Aug 12, 2009 at 22:09
You souldn't really need a web site to tell you as the difference is 5% of 265mm or approx 13mm in sidewall height
Regards Don
378738
Follow Up By: Moose - Thursday, Aug 13, 2009 at 08:40
OK - I give up. Where does the 5% come from?
646129
Follow Up By: MrBitchi (QLD) - Thursday, Aug 13, 2009 at 09:12
Moose, the 70/75 is the aspect ratio. What that means is the sidewall of the 265 tyre is 70 or 75% of the width of the tyre. Therefore a 70 series sidewall is 185mm tall (70% of 265) and a 75 series is 198mm tall (75% of 265)
646132
Follow Up By: Moose - Thursday, Aug 13, 2009 at 09:25
Thanks John but I knew what the numbers meant - I was trying to figure out the 5% bit. I can see that the resultant difference in this case is about 5%, but I don't see how multiplying the width by 5% will always provide the correct answer. Perhaps I've misread Don's answer, but that's how I interpreted it.
646134
Follow Up By: MrBitchi (QLD) - Thursday, Aug 13, 2009 at 09:50
Well in this case the difference between a 70 series and a 75 series is 5%. 5% of 265 is 13.25.... It's because its a ratio.
Same if you were to use an 85 series in the example. Then you'd have a sidewall height of 225mm which is 15% higher than a 70 series.
646139
Reply By: vk1dx - Wednesday, Aug 12, 2009 at 22:32
Thanks to all bar Don.
378741
Follow Up By: donk - Thursday, Aug 13, 2009 at 20:37
I dont understand your thnks to everyone bar don reply because when i posted my reply to your question i was not having a go at anyone i was only saying that you didn't need to go to a web site to work it out
The 70 & 75 is the height of the side wall expressed as a percentage of the width (265mm)
Regards Don
646261
Follow Up By: vk1dx - Thursday, Aug 13, 2009 at 20:59
Fair enough. I thought you were. That's the problem with the written word. Grammar and punctuation can make a phrase appear quite condescending. As did your lpost.
Thank you for
clearing that up.
646268
Follow Up By: donk - Thursday, Aug 13, 2009 at 21:17
No worries
Regards Don
646273
