Changing leaf springs -trailer
Submitted: Friday, Aug 14, 2009 at 20:02
ThreadID: 71506 Views:2894 Replies:4 FollowUps:0
Evening all, Had a rush of blood this afternoon and decided to put heavier leaf springs on the camping trailer. It all went well until I tried to knock out the pins that go through the hanger and springs. What a job!!
Ended up with burred ends on the pins so it will be off to the trailer place tomorrow to get replacement and spares. When I put it all back together I will be greasing up everything so next time it should be easier.
The process got me thinking that it is not something that you would want to do at the side of the track but people do. So what makes it easier to replace leaf spring suspension apart from greasing the pins etc.
Mark
Reply By: Serendipity of Mandurah (WA) - Friday, Aug 14, 2009 at 20:42
If you apply 'Penetrene' for a day first they come out easier - a lot easier.
David
AnswerID: 379030
Reply By: Member - Ed. C. (QLD) - Friday, Aug 14, 2009 at 21:19
It's the knurl (spline-lookin' thingy) on the pins which makes 'em difficult to knock out.. designed to be that way so they don't rotate and wear big holes in the hangers..
I use a _heavy duty_ G-clamp w/- an over-sized socket over the head of the bolt/pin (w/- nut screwed on level with the end of the pin), and they'll usually come out just by screwin'up the clamp.. sometimes need a gentle tap w/- a 'persuader'...
If your springs have nylon bushes, then these should not be greased.. grease attracts dust and accelerate the wear on the pins & bushes...
If you do decide to fit greasable pins (and grease 'em), then you'll need to be greasin' em every bl@@dy day if ya take it off road.. otherwise, like I said, dust will get in there & create a grinding paste, and you'll be replacin' em again within 12 months...
Last time I did mine I used some Molybond (122L) Dry Film Lubticant on the pins/bushes.. remains to be seen how this will hold up in the longer term...
Confucius say.....
AnswerID: 379037
Reply By: 4wd 4 Life - Friday, Aug 14, 2009 at 21:44
You should always keep a peice of brass rod in your breakdown kit also known as a brass drift long enough to hold and hit like a chisel and about 2cm in diameter.
This is also important for knocking in new wheel bearing cups without damaging them.
Brass is soft and won"t deform steel.
Hope this helps.
AnswerID: 379041
Reply By: mowing - Saturday, Aug 15, 2009 at 11:28
Thanks everyone for your replies, I have learnt more stuff from this great site.
Mark
AnswerID: 379089
