GU Patrol Towing Comparisons
Submitted: Friday, Aug 14, 2009 at 22:26
ThreadID: 71514 Views:4087 Replies:9 FollowUps:1
Hello, Can anyone tell me why Nissan restricts the 2004 GU 3.0TD to 2500kg towing upper limit and the 4.2 & petrol to 3500 kg??
What is the big deal? The constuction of these vehicles are the same apart from the donk & gearbox? One would think with the way technology is these days with quality & strength of materials that there would be little to no difference.
It makes you wonder why the New 4cyl Diesel Nissan Utes can tow much more also.
Please correct me if I am wrong with anything,
Cheers DA
Reply By: Dave(NSW) - Friday, Aug 14, 2009 at 22:33
I think you will find the manual has a higher limit than an automatic in the 3lts.
GU RULES!!
AnswerID: 379046
Reply By: Serendipity of Mandurah (WA) - Friday, Aug 14, 2009 at 22:59
I would say the 2500kg limit is the appropriate limit but with later caravans being heavier customers wanted more and Nissan went back to their engineers and got them to sharpen their pencils to what is the absolute limit for the vehicle.
A bit annoying if you have one badged for 2500kg. You could get an engineer approval to up the tow limit.
David
AnswerID: 379048
Reply By: olcoolone - Friday, Aug 14, 2009 at 23:00
Might have something to do with engines exploding!
AnswerID: 379049
Follow Up By: Member - Ed. C. (QLD) - Friday, Aug 14, 2009 at 23:24
More to do with the auto trans, I suspect..
Confucius say.....
FollowupID: 646459
Reply By: mowing - Saturday, Aug 15, 2009 at 01:05
You will find that the 4.2 TD ute has the 2.5 t tow capacity as well in manual form. The coil sprung version had a sliding scale of tow capacity depending on what was put in the back.
Rgds
Mark
AnswerID: 379057
Reply By: Member - DAZA (QLD) - Saturday, Aug 15, 2009 at 08:23
G/Day All
We have the Nissan 2008 3ltr Auto, in the book it says maximum 2500kg for towing, after having our van weighed fully loaded we are just under, the maximum, we don't have any trouble towing what we have got at the moment, but if we upgraded to a larger van I would have second thoughts, about getting the new nissan when it arrives next year.
AnswerID: 379069
Reply By: Robin Miller - Saturday, Aug 15, 2009 at 08:52
Other things to factor are engine braking and diffs and brakes and there construction.
All 4.2 have the smaller rear diffs whereas the 4800's and 3lts have a mixture ,the manuals have larger diffs , then we come to the brakes the 4800 have larger brakes.
The auto 4800 also has the newer 5 speed 2 stage gearbox , which partly makes up for having the same diff as 3 lt auto.
The manual 4800 is only one with both larger brakes and rear diff
The 4.2 has significantly more engine retardation combined with being a manual partly offsetting is smaller rear diff.
AnswerID: 379074
Reply By: Member - Graham H (QLD) - Saturday, Aug 15, 2009 at 14:46
I was under the impression that the whole drive train in the 3.0 Auto was lighter therefore restricted the capacity.
Rather funny considering you really hear about autos blowing up but a lot about motors beating them to it
LOL
AnswerID: 379117
Reply By: JR - Saturday, Aug 15, 2009 at 17:02
Its the gear box, Autos are rated lower than manuals
All vehicles really have the sliding scale for towball down force - you cannot fill her up with gear then ignore the 100kg downforce from the caravan!!
GVM - vehicle max full (including downforce of trailer)
GCM - (light vehicles dont strictly have this but do have max towing capacity so its the same) max weight of vehicle and trailer ie GVM + max tow capacity
JR
AnswerID: 379124
Reply By: 4wd 4 Life - Monday, Aug 17, 2009 at 16:37
The 3ltr model also has less engine braking resistance than the 4.2 d and smaller diameter disk rotors than the petrol 4.8
AnswerID: 379346
