Passenger or Light Truck Tyres ?
Submitted: Monday, Aug 17, 2009 at 12:25
ThreadID: 71569 Views:8433 Replies:11 FollowUps:10
G'day Guys,
Hoping for some words of wisdom.
We have a 120 series Prado which is due for new tyres, currently have original Grandtreks, 265/65R17.
No one makes a Light Truck tyre in this size so if we go LT we will have to go 265/70R17 which means we have to get a new spare as well. Plus the potential legal / insurance issues with larger tyres.
We will be doing some max. GVM caravan touring over the next few years. 90% on road with 10% light / medium car only off-road.
Due to the size issue we are heading towards passenger Bridgestone D694's in 265/65R17.
For what we are after, do you believe the extra $'s associated with getting LT tyres is worth it ?
Any feedback, greatly appreciated.
Jezz.
Reply By: Member - Fred B (NT) - Monday, Aug 17, 2009 at 12:43
Hi Jezz,
Have a look here at bridgestones site:
D694 comparison chart
D694 comes in a number of configurations and loadings in the 265/R17 without having to go to the 270 size (also in different cofigs). Can get confusing, I tell you.
I am in the same position as you and have to replace 6 tyres soon.
regards
Fred B
VKS 737: Mobile/Selcall 1334
AnswerID: 379315
Reply By: Member - Doug T (NT) - Monday, Aug 17, 2009 at 13:14
Jezz
I run Yokohama's , they are really good , They are available in your size too,
Yokohama Geolandar A/T-S
Image Could Not Be Found
As you can see they are LT
AnswerID: 379318
Reply By: MrBitchi (QLD) - Monday, Aug 17, 2009 at 13:29
For your stated use the passenger tyres will be fine. The LT's really come into their own on dirt roads and corrugations. If you decide to tow on dirt roads like the Birdsville track for example then LT would be the way to go.
AnswerID: 379321
Follow Up By: Tenpounder (SA) - Monday, Aug 17, 2009 at 13:45
I agree with you John (see below) my move to LTs was about gibber and other sharp stones, not about loading. The Passenger tyres are probably rated well above the vehicle's rear axle loading anyway!!
FollowupID: 646696
Reply By: Tenpounder (SA) - Monday, Aug 17, 2009 at 13:38
I am a Coopers person from way back (no, don't bother!) and I wanted to go to LTs, but I could get the right size (mine is a 95 Series Prado with 16in wheels) so I went to a slightly narrower tyre with a higher ration (in your case, going from 265/65R17 to 245/70R17) which gives you a rolling radius of 777 mm compared to the original 776 mm. The reduced width is 20 mm, which may or may not worry you.
The width reduction has not presented any problems that I am aware of (handled the soft Simpson last year just fine).
I would not be surprised if other brands offer a similar option
Just a thought. Hope it helps.
AnswerID: 379323
Follow Up By: Tenpounder (SA) - Monday, Aug 17, 2009 at 13:40
Sorry, "I could NOT get the right size " Incidentally, the Coopers in your size are HT LTs, not ATR tyres like I went for.
FollowupID: 646695
Follow Up By: Member - Doug T (NT) - Monday, Aug 17, 2009 at 16:11
Are you on a commission or something..
FollowupID: 646714
Reply By: George_M - Monday, Aug 17, 2009 at 13:52
BFG now make an 265/65R 17 AT.
Have a look at this site.
If you need to buy new tyres I'd recommend you go with AT construction.
Changing to a different size, typically 265/70R is an option, depending upon where you live. This size is legal in Victoria (and some other States), but not in NSW or Qld.
George
Come any closer and I'll rip your throat out!
AnswerID: 379326
Follow Up By: Tenpounder (SA) - Monday, Aug 17, 2009 at 14:03
Fair enough, but the question was about construction (Passenger versus LT) rather than tread pattern (AT versus HT). I couldn't find any reference to LT in the link. Gets complicated, doesn't it?
FollowupID: 646700
Reply By: Wherehegon - Monday, Aug 17, 2009 at 14:44
On both my prados I went A/T's. Firstly ours does go off road, but secondly is the handling difference and you will also get a lot more klms from the tyres. We live in an area where there isnt a straight road in the joint and found the original tyres chewing out on the outer edges due to the side movement of the tyres when cornering left to right. We put Bf's A/T's on the first prado and we did roughly for memory 50 thou on them and still looked like they would have got at least another 30 easily. We also had them on our hilux. Im not saying here go for Bf's but I would go A/T's. I didnt get LT's (75's) this time on current prado as I found them way too strong in the side walls (may sound silly) but I want them to bag well on the sand and for rocks which I found the BF's in 75 series didnt, I could drop them to 18psi and you would think I hadnt let any air from them.. I had no insurance issues with NRMA with the bigger tyres and it was noted on my policy that they were 75's instead of the factory fitted 70's. And yes been an all wheel drive if you decide to go the bigger size you will need to get the 5th one just incase. Also if going bigger size will your wheel cover (genuine Toyota) fit back over the bigger tyre ?? ours wouldnt on the old prado with the fibroglass/plastic what ever there made from, but we had an exploroz cover on it anyway so got a bigger size to suit. Regards steve M
AnswerID: 379334
Reply By: Member - Doug T (NT) - Monday, Aug 17, 2009 at 15:35
Jezz
Here you go
AnswerID: 379342
Follow Up By: Tenpounder (SA) - Monday, Aug 17, 2009 at 16:05
Sorry, Doug, but that video clip has absolutely NOTHING to do with the question. The thread asks about LT rating construction versus HT, for a rig that will spend most of its time towing a heavy van on bitumen.
Are you on a commission or something?
FollowupID: 646710
Follow Up By: Member - Doug T (NT) - Monday, Aug 17, 2009 at 16:09
Tenpounder
SO WHAT.... When I want you to Bark i'll rattle your chain.
He ask for tyre info, I GAVE IT TO HIM.....OK .
FollowupID: 646711
Follow Up By: Tenpounder (SA) - Monday, Aug 17, 2009 at 16:09
Oops I should have said "LT rating construction versus PT (as in passenger tyre)" instead of "LT rating construction versus HT".
FollowupID: 646712
Reply By: olcoolone - Monday, Aug 17, 2009 at 15:41
I don't think you will have "a potential legal / insurance issues with larger tyres".
You've been listening to the wrong people for to long.
Why not ask a tyre place?
AnswerID: 379343
Follow Up By: Member - Brenton W (SA) - Tuesday, Aug 18, 2009 at 00:20
Has anyone ever had there insurance denied because of there tyres being the wrong size, i couldnt get the right size tyres for my old rodeo once they were supposed to be 110 s but i could only get 107 s not sure wether the insurance company would have pushed the envelope if i had had an accident ??
any thoughts!!
FollowupID: 646773
Reply By: Ted G - Monday, Aug 17, 2009 at 16:46
HI Jez
I had to go through the same problem and finished up with 265/65/r17 Bridgestone 694 not light truck.
The reason were because mainly road use and towing, I have covered over 6000 ks towing since having them fitted.
So far better handling when I droped the pressure down to 35 psi instead of the 40 psi from the tyre dealer (can't read the specs on the door like all Toyota dealers after a service).
I have checked the speedo with a GPS and it is spot on up to 110 ks so it's better than the Grand craps that were originally fitted.
50,000 ks out of the Grand Craps with about 10,000 maybe left but changed before hand due to the current trip.
Cost $254 fitted balanced all up at KMart matched the price quoted by Bridgestone with rotation and Ballancing each 10,000 ks.
Didn't consider the LT for the extra $50 ea as I don't do heavy off road.
Hope this helps.
Ted
AnswerID: 379348
Reply By: Member - Mark (Tamworth NSW) - Monday, Aug 17, 2009 at 17:20
I fitted Bridgestone AT 694, LT 265/65/R17 to my Pajero 10 000km ago, too soon to say how they are going other than no problems towing a CT around 3000km of Central Oz dirt roads.
There was minimal difference in price between the LT and passenger construction and all my research said the LT tyres provide significantly better puncture resistance, superior wear, with only slightly worse ride (I can't tell the difference).
They don't have them listed on their web site though, I found out about them on this forum
I preferred them over the Cooper LT purely as I would of had to have gone up as you said to the 70s, which would mean replacing my good spare as well.
The LTs are made in Japan, Vs passenger in Australia. Some people claim the local product is superior, I can't comment.
Not getting into the tyre brand argument, went Bridgestone purely to keep the tyre diameter as per OME and been happy so far.
AnswerID: 379355
Follow Up By: Member - Tony Z (NSW) - Monday, Aug 17, 2009 at 18:24
Mark I just fitted a set (5) of 265/65/17 LT 694 AT to my Pajero, paid $300 ea fitted, to do a trip around the Centre. Took the Hwy Deullers off they had only done 8000k but kept them for when I get back (1 is going on the roof as a 2nd spare), my tyre man found me a set of sunrasia's with only a 5mm different ofset and hey they fit. Not to many 17" after market rims out there ROH will have 1 available soon.
FollowupID: 646739
Follow Up By: Member - Kroozer (WA) - Tuesday, Aug 18, 2009 at 00:02
Yep go the Bridgestone 694LT, mark my words these tyres will be the standard that all others are judged upon. They will honestly become a household name. No affiliation, no commision just a very very happy Dueler LT fan. Mark my words. I too have a 120 Prado, with the non LT 694s, and even these are the ducks nuts. Never will i ever try any other brand for AT ever again.
FollowupID: 646771
Reply By: gbc - Monday, Aug 17, 2009 at 18:55
Don't know which state you're in. Just got the racq mag in the post and Bridgestone centres have a 'spring' sale on. Your size isn't listed, but my 16" tyres appear to be about $100 ea under normal retail. Diff in price between 694 and 694 LT only appears to be $25 odd dollars. Might be worth a ring.
AnswerID: 379369
