Caravan door earth strap
Submitted: Tuesday, Aug 18, 2009 at 17:50
Member - barry F (NSW)
Hello all, Could someone tell me why there is an earth strap connected to caravan doors & the door frame. Must be a reason, although they always seem to be broken. Thanks & Cheers
Reply By: Member - Keith C (NSW) - Tuesday, Aug 18, 2009 at 18:37
G/day Barry, I don't know the reason, but van doors are not earthed without this because of their plastic hinges and locks,hence an earth strap to the van body .Probably to comply with some Aust .,standard in the mobile home industry.Regards Keith C
379494
Reply By: The Geriatric Gypsies - Tuesday, Aug 18, 2009 at 19:02
to try and stop static electricity
steve
379498
Reply By: Dremus - Tuesday, Aug 18, 2009 at 19:02
It would be to earth the door to the van.
I would say it will be a gas regulation as there are LPG appliances in the van and in the case of a leak, an unearthed door could build up a static charge and arc across to the body igniting the the gas filled van.
Just my thought.
379499
Reply By: Member - Axle - Tuesday, Aug 18, 2009 at 19:11
G/ Day Barry, Your earth straps are broken!, I can't see any on
mine, So after the last post i think we need a kick up the cyber!!...lol.
Cheers Axle.
379503
Reply By: Fred G NSW - Tuesday, Aug 18, 2009 at 19:20
Funny you should bring that up barry....I replaced
mine yesterday after finding
mine broken also....could'nt find any of that flexible stuff though and just raplaced it with light multi core for now. All to do with the LPG and static Elec. I would presume....I don't want to find out the hard way LOL
Fred.
379504
Reply By: DIO - Tuesday, Aug 18, 2009 at 20:29
STATIC ELECTRICITY.
379517
Reply By: PradOz - Wednesday, Aug 19, 2009 at 14:25
any chance of a photo of what you are talking about. none on
mine, probably coz i have metal hinges? cheers
379570
Follow Up By: Member - barry F (NSW) - Wednesday, Aug 19, 2009 at 15:32
I dunno how to do the photo bit!! But seeing you have metal hinges I think it would be the same as an earth strap.
The existing earth strap is only about 50mm long, one end attached to the door, the other end attached to the door frame. The hinges on
mine are plastic. Cheers
646945
