Leads and plugs 180 bucks for vt commodore?
Submitted: Wednesday, Aug 19, 2009 at 19:57
ThreadID: 71618 Views:3439 Replies:2 FollowUps:7
Im so bleep , some may think its petty, but I got a vt converted to gas and it was 2250, so 500 with the rebate and then he says today that it needs new plugs and leads for $180 for the gas conversion guarantee to be valid. I just googled it and seems the new leads are common with gas conversions but is 180 a rip off or what? Now the budget is blown out and I am thinking I should have got a cheaper conversion around 2 grand but this guy sounded good on the phone, blah blah. Oh well, lets hope it gos well. Its a BRC system for what its worth, he was gonna put an impco in for 500 more but I have a impco on the patrol and dont like it really.
thanks
Reply By: DCTriton - Wednesday, Aug 19, 2009 at 20:27
If they are iridium plugs, you're probably looking at around $80 - $90 for a set of six, couple that with good quality leads and I can see where you could suddenly arrive at $180...
AnswerID: 379610
Follow Up By: oldpop - Wednesday, Aug 19, 2009 at 20:32
Iriduim plugs wont work with gas causes backfires
Oldpop
FollowupID: 646984
Follow Up By: justin71 - Wednesday, Aug 19, 2009 at 20:33
thanks for the reply, what are iridium plugs? My wife reckons they should include the plugs in the conversion.
FollowupID: 646985
Follow Up By: Member - Toyocrusa (NSW) - Wednesday, Aug 19, 2009 at 20:43
Hi Iridium plug have an iridium tipped centre electrode which lasts a lot longer than the steel one. I have them running in my V8 commodore ute on gas with no problems regarding backfiring. I felt they would withstand higher combustion temperatures that can occur with gas. Have a look at the NGK Spark Plug site. It will explain them to you. Regards,Bob.
FollowupID: 646991
Follow Up By: Member -Hunjy (NSW) - Wednesday, Aug 19, 2009 at 21:27
Just got my LPG serviced on my 4.5l 105 and the new leads and plugs were $250.00. So $180.00 sounds good.
Mal
FollowupID: 646996
Follow Up By: justin71 - Wednesday, Aug 19, 2009 at 22:21
thanks for the info guys,
FollowupID: 647009
Follow Up By: DCTriton - Wednesday, Aug 19, 2009 at 22:37
Oldpop, NGK make an iridium spark plug specially designed for use with LPG and as others have mentioned, I have used standard iridium plugs with LPG and no backfires... Iridium plugs ability to generate a very pure spark helps to efficiently ignite the increased density of LPG/air mixture in the combustion chamber...
FollowupID: 647014
Reply By: Andrew-rodeo - Wednesday, Aug 19, 2009 at 21:31
$180 sounds fair for plugs and leads. around $27 for plugs $80 for a good set of leads plus an hour to do them, you need to move the alternator out of the way. And i personally I would have gone with the Impco kit.
Cheers Andrew
AnswerID: 379621
Follow Up By: justin71 - Wednesday, Aug 19, 2009 at 22:22
thanks for info andrew, couldnt afford another 500 bucks and its a 2nd car
FollowupID: 647011
