deep cycle batteries
Hi all i can only fit 50 amp hour battery under the bonet of the hilux 2002 how long will the 50 amp battery run a 6o litre engle fride frezzer for with out starting the car thanks brad
Reply By: BubblesT - Sunday, Aug 23, 2009 at 20:21
no more than 8 hours depending on what the engels _Affordable_Storage_Drawers.aspx on freezer about 4.5amps. ph.
AnswerID: 380190
Reply By: Member - 1/2A - Sunday, Aug 23, 2009 at 20:58
You only can use 25 amp/hrs safely as you should not go below 50% of battery capacity if you want the battery to last.
AnswerID: 380194
Reply By: Member - ross m (WA) - Sunday, Aug 23, 2009 at 21:36
Did you mean to your "fride frezzer" as a fulltime freezer or just enough to keep things cold?
AnswerID: 380201
Follow Up By: Member - joc45 (WA) - Monday, Aug 24, 2009 at 20:08
Yes, if you don't need ice cream, then you don't need a freezer - you can cryovac your meat and it will keep weeks running as a fride, not a freezer.
FollowupID: 647643
Reply By: Member - Mike DID - Tuesday, Aug 25, 2009 at 09:28
Are you travelling in Tasmania in winter or Northern Territory in summer ?
AnswerID: 380397
