painting bull bar
Submitted: Sunday, Aug 23, 2009 at 20:28
craig oates
i was wanting to clean up my white bull bar, its got a lot small scraches and light rust spots. whats the best way to clean it up and best paint i want to paint it black. thanks
Reply By: Member - Ian H (NSW) - Sunday, Aug 23, 2009 at 20:33
Best way is to have it sandblasted then hot zinc sprayed followed by powdercoating but it is also the most expensive. Depends on how good you want it to look.
380192
Follow Up By: craig oates - Sunday, Aug 23, 2009 at 20:39
thanks ian that sounds like the way to go
647489
Follow Up By: Member - ross m (WA) - Sunday, Aug 23, 2009 at 21:49
You can reasonable results from coating it with a rust preventer and using spray cans.
This way makes touch ups a cinch and it doesnt look too bad with a low gloss.
647502
Follow Up By: Member - Timbo - Monday, Aug 24, 2009 at 12:49
Might be okay for a quick tidy up but unfortunately the spray can paint is not usually very robust and scratches/chips quite easily.
647562
Reply By: Member - Mark G Gulmarrad - Sunday, Aug 23, 2009 at 20:48
Craig
you could also try painting it with that hammer finish paint.good thing about it you cant see your mistakes in it if you put it on a bit thick and it runs :-(((
you get it in either a spray pack or a tin,either way it comes up a treat on bullbars,cheers.
380193
Reply By: Flywest - Monday, Aug 24, 2009 at 01:41
Yeah - hard to touch up powder coat!
380220
Reply By: vk1dx - Monday, Aug 24, 2009 at 06:49
Mine is aluminium bit I would say the process could be very much the same.
Cean up the rust with some wet and dry. make it nice and smooth so as the rust "holes" do not show through. Fill any holes you don't like with body filler.
Make sure the whole bar is cleaned properly. Use a cleaner that is compatable with the paint you are going to use. See the man at the "saturday" store. Spray all of it with at least couple of coats of spray etch and then a few coats of the colour you want. Use what they recommend cleaner and don't use the cheap cans.
This way you have the goods to touch it up later. Or you could give it to a
shop and get them spray or powder coat it for you.
I did the top and "back" where the lights shine in flat black touch up paint. Stops that bit of glare. Admittedly we are not terribly worried about the colour not being a "designer" match with the bonnett but this is a bush car not a Toorak tractor.
Did it over a weekend when the weather was fine and NOT wind. Don't forget to cover EVERYWHERE that you do not want sprayed. Be meticulous with this. Nothing worse than getting overspray off the windshield let alone that white bonnet with black spots everywhere. Watch out doing it in an enclosed space. Its bad for your health and especially the garage where the fumes can find their way into the house. I bet the "boss" will kill you if they do.
Don't be worried. Its is quite easy and you can even get a thrill out of it if you are thus inclined.
and not a mark on it after our last trips. Seems even the stones and bugs did not chip this painting method. take your time and apply the coates as printed on the cans. I know what "us blokes" are like hen it comes to instructions HaHa.
380226
Follow Up By: vk1dx - Monday, Aug 24, 2009 at 06:51
Whoops I did not look further down the page. Too early in the morning I think (6AM).
647527
Reply By: Stu & "Bob" - Monday, Aug 24, 2009 at 13:42
Sand it back and spray it with a "Kill-Rust" epoxy. Hard as nails coating, but easy to touch up when necessary.
Clean up with turps or similar.
380266
