Rooftop Camper Manual
Submitted: Monday, Aug 24, 2009 at 20:19
ThreadID: 71763 Views:2538 Replies:2 FollowUps:1
Just wondering if anybody had a manual for a Howling Moon Rooftop Camper. I haev to build a new mounting kit so was hoping it had the bolt sizes and dimensions.
Mat.
Reply By: Member - Mick O (VIC) - Monday, Aug 24, 2009 at 23:11
Mat,
I have the ARB Pilbara RTT (Roof Top Taj-Mahal) so basically identicle to the Howling Moon. Depending on just what I was mounting to, I just drilled new holes through the base of the tent and used stainless flat head bolts drilled through and seats made to suit the racks/bars I was attaching it to (Nylock nuts though). Old holes get filled with builders bod and sanded off. I've never used the aluminium cross bars at any stage. Usually mount direct onto a strip of single sided adhesive 25mm high density foam tape from Clarke Rubber.
Image Could Not Be Found
Cheers. Mick
AnswerID: 380358
Reply By: ando74 - Tuesday, Aug 25, 2009 at 00:49
Cheers Mick.
I was thinking of mounting it on some channel bar then staright onto the roof rack. Drilling new holes might make it easier
Mat.
AnswerID: 380369
Follow Up By: Member - Mick O (VIC) - Tuesday, Aug 25, 2009 at 17:44
Mat,
the floor of the tent should hold it just make sure to use a good sized washer and a flat headed bolt, preferably with a slot or phillips in it to facilitate tightening and removal (Always hard trying to tighten it using multi's to get a hold lol). You don't want a hex head sticking up as you'll feel it through the mattress The foam tape will cushion and reduce any possible vibration. I've carted mine over some bloody rough territory with no problems what-so-ever.
FollowupID: 647794
