Engine Fault Codes for LC100
Submitted: Monday, Aug 24, 2009 at 21:15
Inkbandit79
Hi guys I have an intermittant Engine Light the keeps coming on, every time it is booked in it seems to stop, and a week later it comes back on again and the merry go round continues. Its Really Starting to get to me I dont think it is any thing serious as I have not lost any power and the car runs like a dream. I have heard that there is a certain plug that you can jump in the diagnostics box and it will tell you the fault code by flashing the check engine light is this just a rumour or can it be done because the next time it comes on I would like to pull over and check it. I know it wont fix the problem but after cleaning and checking every terminal I could find it should send me in the right direction.
Reply By: Ian & Sue - Monday, Aug 24, 2009 at 23:14
Have you had a flat battery? On the Jeep the engine light will come on if the battery has been flat - my husband then has to connect it to a device he has that resets it.
380359
Reply By: Member - Toyocrusa (NSW) - Tuesday, Aug 25, 2009 at 07:08
Hi. Once the light comes on a fault code is logged in the computer and will stay there unless the computer power is disconnected. Most Auto Electricians and a lot of Mechanics will have a "Scan" tool that can be plugged into the diagnostics link to decifer the code/s. Bob.
380382
Reply By: Horacehighroller - Wednesday, Aug 26, 2009 at 01:07
Have you checked & cleaned the plug on the back of the alternator?
380508
Reply By: Member - Graham H (QLD) - Wednesday, Aug 26, 2009 at 14:10
I'll take pity on you Heres what to do
Ign off Trans in P or N
Turn IGN on but DO NOT START ENGINE
Jump pin 13 TC and pin 4 GC on the DLC connector under dash beside steering column
codes will flash on the engine check light.
Then post what it does and I will read them off chart in Gregorys Manual
To cancel code remove the ECD fuse from panel in engine bay for over 60 secs
The flashes start 4.5 sec after shorting the terminals and are on and off for .5 sec then gap of 2.5 sec for second part of code
380549
Follow Up By: Inkbandit79 - Thursday, Aug 27, 2009 at 22:28
Thanks Graham It turned out to be an abs sensor that had some grit in it I was driving past an auto elec when it came on and drove over two lanes to get in there while it was still on and problem solved thanks guys
648177
