Solar Panel Purchase
I'm in the market for an 80-85 watt solar panel. There are a number of options out there, I want a good quality, good performing panel that will free-stand beside my caravan. Thoughts on what brand and where from (= good price!) would be most appreciated. A nice bloke at Solar Express at Caboolture offered a Kyocera 85 watt panel, but I've not had one before, only BP Solar.
Reply By: Cruiser .- Friday, Aug 28, 2009 at 14:32
Grunter65
Check out Solar Steve who is an advertiser on EO
Cruiser
AnswerID: 380836
Follow Up By: Member - Ian W (NSW) - Friday, Aug 28, 2009 at 14:50
Ditto Cruiser.
Purchased from Solar Steve. Top quality product, awesome service, easy to deal with. Provides you with con note tracking number so that you can keep track of your delivery.
Steve despatched my two panels late Tuesday afternoon from Melbourne, they hit my front door early Thursday afternoon.
I have a further two panels on back order with Steve. More than happy to go around a second time.
NOTE! Steve has "mates rates" for EO Members.
Ian
FollowupID: 648266
Reply By: Member - Oldplodder (QLD) - Friday, Aug 28, 2009 at 15:12
If you want some one in Brisbane (southside), try ABR, also an exploroz supporter/advertiser.
Always had good service and good advice.
AnswerID: 380840
Reply By: Maîneÿ . . .- Friday, Aug 28, 2009 at 17:53
The thing you have to aware of with Solar panel specs is N0T the maximum ratings, but the average or low light performance characteristics.
Reason being, more hours are spent in low light than in PSH's and some elcheapo panels just don't perform in the low spectrum as well as some others do.
( I'm not knocking any panel - just making a general statement )
Find the panel you believe is the best suited for your own use, THEN seek the best price on only that panel.
Don't be swayed by 'sales' people as they switch-sell what they make the most profit from, which in itself is not wrong, but you may get conflicting information because they fail to mention the negative aspects of what they want to sell you, which is not telling a fib, just not telling you all the facts.
Check out the Current-Voltage characteristics of different panels at *various irradiance levels* if the low light specs are not available then you have to ask yourself 'why not' if the panel is so good, according to the 'sales person'
There's nothing wrong with the new Kyocera panels performance wise
Kyocera 85 Watt specifications
Maîneÿ . . .
AnswerID: 380862
Follow Up By: blue one - Friday, Aug 28, 2009 at 18:42
Make sure it doesn't fall over otherwise you will have to buy a new one. I've seen this happen a couple of times.
FollowupID: 648292
Follow Up By: wazzaaaa - Friday, Aug 28, 2009 at 22:27
mainey,
I wonder if you could tell me what would be wrong with these "Rich solar" monocrystalline solar panels on ebay for $4.99 a watt. Looks like good value for that price.
Wazzaaaalink
FollowupID: 648313
Follow Up By: Maîneÿ . . .- Friday, Aug 28, 2009 at 23:22
the Link you supplied states:
Max. power: 85 Watt
Max. power voltage = 18.2 Volts
Max. power current = 4.59 Amps
However I believe the Rich panels are:
Max. power: 85 Watt
Max. power voltage = 18.05 Volts
Max. power current = 4.71 Amps
So I would want to see who is responsible for the 12 month warranty ?
I don't believe a reseller can be held responsible as they are not the manufacturer
At $424 each with the numbers as they are, they appear to be a bargain to me
How are you *positive* they are Rich panels ?
Maîneÿ . . .
FollowupID: 648323
Follow Up By: wazzaaaa - Saturday, Aug 29, 2009 at 06:59
Mainey the reason I asked was as I have bought 8 x 65watt panels from this guy over the last two years and I can not fault them. Although I paid an average of $4.60 per watt they are branded "Rich Solar" and the quality of the panel appears as good as a friends sharp panels. The point I am making is just because they are cheap from china, and I suspect the panels from Solar Steve's Solar Power Shop are as well , doesn't mean they are no good. Originally because of the price I was prepared to take the risk, but after using them and comparing them with friends panels performance in identical situations I was very happy and bought more.
Wazzaaaa
FollowupID: 648327
Follow Up By: Maîneÿ . . .- Saturday, Aug 29, 2009 at 08:52
Wazzaaaa,
I never said Rich panels were "no good" I never even hinted they were "no good"
What I did say was:
Max. power voltage = 18.20 Volts
I was only showing the difference in specification numbers and wondering why the ebay seller would not use the manufacturers own technical specification numbers, when the Rich panel numbers are definitely rated at higher Amps ??
The Rich panels have a ( 5 ) *five year* warranty on materials and workmanship.
However the ebay seller is only offering ( 1 ) *one year* which is a bit confusing ?
Why would the ebay seller not offer the manufacturers full warranty, when 5 years is definitely available by the manufacturer ??
These are just some questions and I realise they are not your answers
However, I would look at the genuine Rich panels first to see if there is any physical difference, as there is a definitely a difference in technical specifications and also clearly a difference in the warranty time period available from the manufacturer.
Have you considered they may possibly be 'seconds' or 'rejects' from the Rich factory?
Therfore they get a lesser warranty, as I can think of no other reason to cut 4 years off the *5 year warranty* of a certified product than to sell it this way, it's your money - your happy with their performance so buy more of them, as they are about half price when compared to the certified manufacturers products ?
Maîneÿ . . .
FollowupID: 648334
Follow Up By: wazzaaaa - Saturday, Aug 29, 2009 at 10:34
Hi Mainey, sorry I misquoted you "no good" were my words, I know how passionate you are with solar hence the reasion I asked you to look at the panels I bought. As far as the specification numbers and reduced warranty go may be a question to the seller might shed some light.
I must say I don't have much faith in warranty on lower priced ebay items as it may be more hassle than it is worth and I was willing to take the risk for the price.
What I am saying is they have worked great for our purpose for a couple of years now and if steve was selling them I would support him as he is on this site.
Wazzaaaa
FollowupID: 648348
Follow Up By: Maîneÿ . . .- Tuesday, Sep 01, 2009 at 17:55
The same question applies to the ebay seller of Rich panels....
Why is he only giving one (1) year warranty when the manufacturer gives them a five (5) warranty ??
I would buy a panel with a 5 year warranty over a 1 year warranty any day.
Maîneÿ . . .
FollowupID: 648956
Follow Up By: wazzaaaa - Tuesday, Sep 01, 2009 at 19:35
Sent off a question to him and am awaiting a reply.
Wazzaaaa
FollowupID: 648984
Follow Up By: Maîneÿ . . .- Tuesday, Sep 01, 2009 at 19:47
Wazzaaaa,
surely the invoices you have recieved from the supplier or the box they come in or even the paperwork included with those panels you have previously bought, have stated the warranty information ?
His web page makes it clear that it's only 12 months
Maîneÿ . . .
FollowupID: 648987
Follow Up By: wazzaaaa - Tuesday, Sep 01, 2009 at 19:51
Mainey,
The question i asked was why he only offered one year as opposed to the five.
Here is a copy of the email
Hi, I have solar panels from you and am happy with them. A friend was looking and asked why warranty with you on Rich Solar panels is one year when their web site says five. Also specs. appear slightly different.
Wazza
FollowupID: 648989
Follow Up By: wazzaaaa - Tuesday, Sep 01, 2009 at 20:00
Mainey i just received the reply from bit_deals on ebay, copy below.
Hi wazza,
Specs are on the back on the panel - they are the real specs.
Warranty is given by us and not Rich Solar - if you're happy to send it back in China, then, you can do it anytime in the 5 years time.
Anyway, rest assured nothing will happen - these are real good quality panels.
Michael
FollowupID: 648995
Follow Up By: Maîneÿ . . .- Tuesday, Sep 01, 2009 at 20:21
Wazza,
what are the "real specs" stated on the back of the panel, he's referring to ??
As I've stated above, I believe the 'quality' of Rich panels to be excelent, but when Rich gives their product a 5 year warranty I would expect it to be honoured by this reseller, afterall you can buy the exact same panel WITH the 5 year warranty elsewhere.
How would it be if your TV had a 3 year Manufacturers warranty and you were only given 6 months by the retailer?
Maîneÿ . . .
FollowupID: 648998
Follow Up By: wazzaaaa - Tuesday, Sep 01, 2009 at 20:34
Of course your right but who sells them in australia with the five year warranty?
As I said before, for the price I was prepared to take the risk with my first panel purchase and considered paying double for a name brand for the same size panel here, like buying a warranty. The panels surprised me by their quality appearence and performance there being the reasion for me buying more. I now have 6x 65w flat on the caravan roof and 2x 65w panels I have hinged and plug into the front of the van on a lead as well.
Wazzaaaa
FollowupID: 649002
Follow Up By: wazzaaaa - Tuesday, Sep 01, 2009 at 20:42
One thing I forgot to add, while fitting panels on the roof of the caravan my son (still don't know how he did it) droped one on its corner on the lawn from the roof of the van. To this day it looks and performes the same as the rest.
Wazzaaaa
FollowupID: 649005
Follow Up By: Maîneÿ . . .- Tuesday, Sep 01, 2009 at 20:44
Wazzaaaa,
In this same thread Steve Mandrake has posted:
" Yeah, its 5 years not 1 year .. "
he's a retailer I can point you to here and now and at about the same price too
Maîneÿ . . .
FollowupID: 649006
Reply By: Mandrake - Saturday, Aug 29, 2009 at 09:01
The panels I sell are from Rich Solar in China - I'm in Hawker currently but the specs are here Solar Panels
I think my specs are upto date with the newest panels which have the 35mm frame not the 30mm one ..
If the link doesn't work - sorry - but I am on a laptop in Hawker SA ..
Rgds
Steve - heading to St George - the slow way !!
AnswerID: 380915
Follow Up By: Maîneÿ . . .- Saturday, Aug 29, 2009 at 09:17
Steve
what's the warranty period you give with the Rich panels you supply ??
Maîneÿ . . .
FollowupID: 648337
Follow Up By: Mandrake - Tuesday, Sep 01, 2009 at 17:36
Sorry guys and gals - Just got to Coober Pedy and Internet access...
Warranty is 12 Months on the Physical panel , frame etc - 25 years on 80% output is the manufacturuers warranty ..
Mandrake 27 days from St George !!
FollowupID: 648946
Follow Up By: Maîneÿ . . .- Tuesday, Sep 01, 2009 at 17:51
Can I ask why you only give one (1) year warranty on the Rich panel ??
when Rich supply a five (5) warranty on their panels ??
Maîneÿ . . .
FollowupID: 648954
Follow Up By: Mandrake - Tuesday, Sep 01, 2009 at 17:57
Hey mate I'm in Coober Pedy on holiday ... Yeah its 5 years not 1 ..
See why I need a holiday !! LOL
Hooroo
Mandrake
FollowupID: 648957
Follow Up By: Maîneÿ . . .- Tuesday, Sep 01, 2009 at 18:23
Yes,
Steve, you definately NEED a holiday when you can't remember the 5 year
warranty on materials and workmanship of the panels you sell :-))
How in hell did you correctly remember the 25 years on 80% output warranty ?
""Warranty is 12 Months on the Physical panel , frame etc - 25 years on 80% output is the manufacturuers warranty .. ""
You need to get away more often and enjoy life, before you get too dam busy selling these (low cost) panels and you just can't leave the 'compound' because of all the new orders coming in for these panels with a 5 year manufacturers warranty
Maîneÿ . . .
FollowupID: 648960
