12volt fans for 3 ways frigs any good.
Submitted: Friday, Aug 28, 2009 at 15:35
Member - Scoof (SA)
I have a 3 way frig as you all maybe aware some of them are not that good in hot humid weather.
So I fitted a 12 volt fan and have yet to find out if it going to make a difference.
Have any of you
camping guru's already had any experience with this type of thing.
Hope I haven't been sucked in, but it sounded like a good idea at the time.
Cheers Scoof.
Reply By: kcandco - Friday, Aug 28, 2009 at 15:59
Hi Scoof
I did an experiment mid summer with my kmart 3 way fridge in a closed shed. In summer temperatures (33 ish) with no fan fitted it struggled to reach 14 degrees. This was in an enviroment with no breeze. With a small computer fan fitted to the rear forcing air up through the rear workings of the fridge, the temp dropped by 8 degrees. If the fridge was placed in an airy position the difference was negligible. So in summary yes it's good for example in the back of the car where their is poor air circulation. I also tried this experiment with a 12v Bushman fridge and found to my surprise no difference at all in the performance of the fridge. In this case I set the fridge to a constant 6 degrees and measured run time of the compressor to maintain that temperature over an extended period.
regards Kc
380845
Follow Up By: Member - Scoof (SA) - Friday, Aug 28, 2009 at 16:28
So it's going to work that's what I wanted to hear.
Thanks for the reply.
Scoof . :-)
648277
Reply By: Member - joc45 (WA) - Friday, Aug 28, 2009 at 16:30
Hi Scoof,
I think kc's answer says it. I have a compressor Autofridge which runs in an enclosed space, and I use two 100mm computer fans to shift air each side of the fridge (the fridge condenser in placed on each side of the fridge) and it makes it quicker in pulling down the temp. The fans were ripped out of old computer power supplies (turn off the computer first!).
As an aside, back in the late 60's, I was supplied with an industrial caravan on a work job on the Nullarbor and was despairing with the poor performance of the Electrolux 2-way fridge. It was poor on gas and wouldn't work at all on 240v. In the end, I managed to get the fridge out, and found that the ventilation around the fridge was almost non-existent, the installation almost contrary to the supplied install book, so I removed the top over the fridge. The other thing I found was the 240v lead just coiled up under the fridge, not connected to anything! An extension cord was arranged and after that, the fridge worked quite
well. And this was from a
well-known caravan mfr.
Gerry
380850
Follow Up By: Member - Scoof (SA) - Friday, Aug 28, 2009 at 16:55
Good news I can look forward to cold Beer this summer then.LoL
Cheers Scoof . :-)
648279
Reply By: Member -Dodger - Friday, Aug 28, 2009 at 17:09
I have 2 X 12v pooter fans blowing the hot air out the top external vent of the fridge and this has helped our fridge immensely.
They are controlled by a thermo switch that turns them on when the temp above the rear coils? workings gets hot.
380854
Reply By: piddlefimp - Friday, Aug 28, 2009 at 17:36
This post has been read by the moderation team and has been moderated due to a breach of The Inappropriate Rule
Forum Moderation Team
380858
Reply By: wazzaaaa - Saturday, Aug 29, 2009 at 07:10
Hi scoof,
This is info on how to fit fan's to a caravan 3 way fridge both internally and externally. I found it useful as it works
Thought it may be of interest.
Wazzaaaa
380903
Follow Up By: wazzaaaa - Saturday, Aug 29, 2009 at 07:13
Better add link
link
648328
Follow Up By: Member - Scoof (SA) - Saturday, Aug 29, 2009 at 09:36
Thanks Wazzaaaaaaa
The photos give me some ideas, thanks again.
Cheers Scoof . :-)
648338
Reply By: Butch58 - Saturday, Aug 29, 2009 at 08:16
HI Scoof,
have a look at this site, may answer all your questions,
Butch 58.
www.dreampod.net-boroma-fridgefan.html
380909
Follow Up By: Butch58 - Saturday, Aug 29, 2009 at 08:20
Sorry Scoof,
this is the same site as Wazzas above, cheers Butch 58
648331
Reply By: Ray - Saturday, Aug 29, 2009 at 08:38
I have installed a 4" computer fan in the top vent of our 3way and have seal the remainder of the vent with a piece of Perspex and installed baffles so air can only pass over the fins. Seemed to improve things a bit.
380911
Reply By: furph - Saturday, Aug 29, 2009 at 11:26
Our van came with 2 x 70mm computor fans on brackets behind the top vent to blow air out. Controlled from a thermo switch on the R/H end of the condenser fins with a master switch to switch off. (why that, I dont know?)
However, the way the boiler flue is ducted, with an open ended T piece (lower than the outside end) flue gas was sucked back in and across the condenser fins then blown out through the main vent whilst the fans were running. The setup which in theory is good did not work as
well as I thought it could. I reckoned the condenser was not getting as cool as would be optimum.
On days above 35deg. the cabinet temp would creep up to around 5, the freezer remaining at -15/18.
My modification could be seen as "overkill", but I removed the 2 fans/brackets and made a frame to fit directly below the condenser fins with the fans blowing up and through. I also fitted an additional fan making 3 in a row. I then blocked off any other gaps in front and sides of the fans so that all cooling air has to pass through the fans, even when not running. I also changed the switch so that I can switch the fans on, over riding the thermo switch
The effect was immediate. No longer is the boiler flue gas going past the fins, it all comes out through the outer vent. Condenser fins remain cool, the cabinet temp. has not gone over 1.5deg. even at 37deg. ambient. (that was running the fans 24/7 which I have been tending to do). Thermostat setting on 2.
The slight noise heard inside the van is not distracting, and at around 0.4a./hr. is a usage of only 9.6a.hrs./day, easily managed.
For anyone interested I can email photo.
furph
380934
Follow Up By: Member - Scoof (SA) - Saturday, Aug 29, 2009 at 12:48
Thanks, so fans sound like a good idea if mounted correctly.
Cheers Scoof . :-)
648371
Reply By: piddlefimp - Saturday, Aug 29, 2009 at 18:54
Using a thrmo switch like the 50 degree Jaycar model is one way to control the fan, but it is either on at full load, or off.
Another way to do it is to use a Thermistor, the t/mistors resistance changes with temp. so the fan would start very slowly and speed up as required.
Check out the circuit here www.technonogystudent.com/elec1/therm1.htm
For any of you
young turks out there you will see that the LED in the circuit could be replaced with a 2n3055 transister which could carry the load of a small fan, the circuit would need some minor adjustments and would only cost a few $s
Have a look at the circuit and tell me what you think.
piddlefimp
380975
Reply By: piddlefimp - Saturday, Aug 29, 2009 at 19:34
Oops,
www.technologystudent.com./elec1/therm1.htm
piddlefimp
380983
Follow Up By: furph - Sunday, Aug 30, 2009 at 07:46
Most interesting, piddlefimp.
Obviously the type of setup used in some multi stage battery chargers for cooling purposes.
I will conduct some experiments here, ie, the thermister may keep the condenser coils at a more optimum and even temperature by it varying the fan speed to suit.
The actual location of the thermister may be the critical factor. I do not have much knowhow on things electronic, but I can grasp the principle here.
furph
648483
Reply By: greenant - Sunday, Aug 30, 2009 at 13:34
Hi Scoof
I have just finished fitting fans to my electrolux 3 way in my camper.
I shrouded the condensor with minimal gaps and used one fan to suck the air thru rather than blow air thru. On
mine the heater flue and condensor air used the same exhaust point and hot flue gas could travel accross to the condensor fins so I put in a divider between the two. As I dont use
mine on 240 volt I have disconnected the power lead and use the thermostat to control the fans
and the cool down time has been greatly reduced Hope this makes sense.
If you need any info call me on 0409725793
Greenant
381099
Follow Up By: Member - Scoof (SA) - Sunday, Aug 30, 2009 at 23:46
Hi greenant
I have a 3 way electrolux in my camper as
well. Do you have any photo's you can post.
Is yours the dark blue frig freezer chest type.
Cheers Scoof . :-)
648627
Reply By: greenant - Monday, Aug 31, 2009 at 18:03
Scoof
No
mine looks like a bar fridge with a front opening door built in to make a bench on top of it. With
the bench top off I can get to all the controls etc
Greenant
381300
