Anderson Plugs
Submitted: Monday, Aug 31, 2009 at 14:35
new boy
Went away on the weekend with the local Caravan Club I,m not convinced I need a genset for my style of travelling but the above was mentioned and raved about best thing he had done . I was unable to ask my question so to the learned member of this
forum I ask.
1. How long would the van battery take to recharge in traveling time 1,2 or 3 hrs
2. Will the van battery charge by attaching the car and allowing to idle again for say 1 or 2 hrs
The van battery will only be running lights and maybe a 12 volt TV for couple of hours a night ,
Reply By: Notso - Monday, Aug 31, 2009 at 15:06
Heaps of stuff you need to say before anyone can help.
What size and type of battery is in the van.
What size wire and connector type is used from the tow vehicle to the van battery.
Most original installations in Tow vehicles use wire that is too small and the connections between the van and the tow vehicle are not heavy enough to carry enough current to charge the van battery correctly and fully.
381272
Reply By: Crackles - Monday, Aug 31, 2009 at 15:16
Alot of variables with your question being size/type of the battery, alternator & cabling & exactly how much draw the lights & TV will use.
As an example if you ran 16mm leads through the Anderson plug to a 100ah AGM battery in the van, it would take a modern car around an hour of driving to charge it from 30% to 90%. It may take a further 2 hours to get it near full charge.
Charging at idle is less efficient although leaving to run for an hour may very
well replace the small amount of power you would use with the lights alone.
A 100ah battery could last as long as a week with your setup so running the engine when stationary may not even be required. Ideally with the addition of a single solar panel your power needs would be met entirely without starting the car.
Cheers Craig.............
381273
Follow Up By: Ianw - Monday, Aug 31, 2009 at 19:31
NOT going to happen !!!! 1 hour to charge 60 ah ???? Need a dedicated 60 amp charger to do that !!!! A car alternator has no hope !! You would need at least 6 - 7 - 8 hours of driving to put that much power into a battery. A 15 amp charger run from an inverter will put more power into a van battery than a direct connection. 4 hours for 60 ah.
Ian
648748
Follow Up By: Ianw - Monday, Aug 31, 2009 at 19:50
Lets be realistic here !! a 12V TV draws at least 5A. Lights draw at least 1A each. 2 hours TV = 10 Ah + 4 lights x 4 hours = 16 Ah. Total 26 Ah per night. Not advisable to go below 50 % charge so max 2 nights available. Then you will need a full days travelling to replace it. Direct charging by Anderson plug is over rated. It only works if you travel for a full day each day.
Ian
648756
Follow Up By: Crackles - Monday, Aug 31, 2009 at 22:36
"Lets be realistic here".............
Ian my example of a 100amp battery been charged via the car feeding lights & a TV comes from my dads van which is set up exactly like that. When just using the lighting it does run for a week & with 1 to 2 hour of driving it does successfully recharge the battery enough to use the TV for a couple more days. It was latter fitted with a solar panel to avoid the need of starting the car at all which when not cloudy or parked in the shade keeps up with power usage.
I suppose the variables to argue over would be what size globes are fitted & how long one watches TV in the bush, factors to be considered when designing any system.
Cheers Craig..............
648808
Reply By: Member - Mike DID - Monday, Aug 31, 2009 at 17:15
Yes, Anderson Plugs are definitely the best way to ensure reliable charging of the van battery.
381293
Follow Up By: redeye141 - Monday, Aug 31, 2009 at 17:37
Have to agree Mike,
Also when the battery reaches 11.8 volts turn everything off and go to sleep.
Redeye
648728
Follow Up By: V8 Troopie - Monday, Aug 31, 2009 at 23:23
"Also when the battery reaches 11.8 volts turn everything off and go to sleep.
Turn everything off but the battery charger. You ought to recharge the battery immediately if it has been run down to below 12V.
648818
