power consumpsion from 100 amp battery
Submitted: Monday, Aug 31, 2009 at 23:41
ThreadID: 71943 Views:2575 Replies:2 FollowUps:2
I have changed all lights light to LED in the van, each light draws 160mA. two reading lamps,two over head lights, sink light, stove light and outside light, all LEDS.
Exhaust fan is 80mm computer fan, 60mA.
All the above would not draw much off an 100amp D.C. Battery. The only thing that draws high amps is the water pump that's only really used twice a day and not for long. Shurflow 12 lpm. 12v.
TV is lap top, so only recharges from car inverter.
I feel that i should get over a week with this set up.
comments please on my calculations.
cheers shane.
Reply By: MARIC - Tuesday, Sep 01, 2009 at 09:35
hi Shane, where did u get your globes/lights from?
ric
AnswerID: 381398
Follow Up By: Member - shane (SA) - Tuesday, Sep 01, 2009 at 19:53
Hi Maric,
I got them from Hong Kong when i was there. Pads off 40 Leds $2.00 each and pads of 50 Leds $3.00 each. they work great and are nice and bright.
Also bought 50 metres of heat shrink 8mm black for $10.00, here we pay around $5.00 per metre.
cheers shane.
FollowupID: 648992
Reply By: qubert - Tuesday, Sep 01, 2009 at 20:19
most draw would be from water pump statr up. probably 3 or 4 times the draw compqred to once its 'running'
AnswerID: 381513
Follow Up By: Member - shane (SA) - Tuesday, Sep 01, 2009 at 20:47
pump draws 3amps min and 7amps max, so with all the lights on i think its 1.44amps total so lights dont really come into it. If i use pump at minimum maybe two hours over a week there should be plenty.
cheers shane.
FollowupID: 649007
