HJ47 seats
Submitted: Wednesday, Sep 02, 2009 at 14:52
gezza100
Hi All,
Wondering if anyone has any experience with fitting up spec seats in the old cruiser ute? Are there any that bolt straight in from another model or any other toyota seats that fit? Trying to avoid spending big dollars on
aftermarket seats if possible.
Many thanks
Gezza
Reply By: Member - Anthony G (ACT) - Wednesday, Sep 02, 2009 at 17:20
Most car seats will fit. All you have to do is match them to the current
seat bases.
Once you start changing bases, they have to be fitted by an authorised installer.
I changer both seats in my old 47 Troopie with no hassles.
381635
Reply By: Member - William H (WA) - Wednesday, Sep 02, 2009 at 21:26
Good evening........Gezza100.
I have fitted two VP commodor
seat's into my HJ47 tojo, and it was easy to do,i will take some photo's for you and send them to you.what is your email address.......Cheers for now...William H...Bunbury...WA
381688
Reply By: gezza100 - Thursday, Sep 03, 2009 at 09:00
Thanks to both of you for your advice. So the vp seats fitted straight onto the existing bases? my email is oldmtsamson03@yahoo.com.au
Thanks for your help, most appreciated.
Gezza
381726
Follow Up By: Member - William H (WA) - Thursday, Sep 03, 2009 at 10:18
gezza i also put the left
seat on the right and the drivers
seat on the left with the adjusters in the middle then the seats can go right to the side and fit ok.easy to adjust fwd and back.
Cheers for now...William...h...Bunbury...WA.
649297
Follow Up By: Member - William H (WA) - Thursday, Sep 03, 2009 at 10:19
will take the photo's now and send to you.
cheers from Williamh...Bunbury...WA.
649298
Reply By: gezza100 - Thursday, Sep 03, 2009 at 14:18
Thanks William,
So was it as easy as a bolt out bolt in install? I spoke to the wreckers as they said that vp, vr, vs all run the same seats so any should be fine, does that sound right to you?
Thanks again
381779
Follow Up By: Member - William H (WA) - Thursday, Sep 03, 2009 at 14:46
You need to make a frame from some angle iron and flat bar.....see the email i sent to you and the photo's.
Cheers for now...Williamh...Bunbury...WA.
649351
