05 Nissan Patrol
Submitted: Wednesday, Sep 02, 2009 at 17:57
ThreadID: 71980 Views:5239 Replies:4 FollowUps:4
hi all
i am fairly new to caravanning only the last 2 years well anyway i have heard a lot about the engine problems with the gu patrol, i have a 05 3lt st Nissan and tow a 1996 Windsor windcheater do you know if nissan fixed the engine problems or can i expect some problems. Also would it be a good idea to fit a turbo timer and pyrometer as mentioned in caravan world. we are planning a 2 month trip to nt next year so i would like to be prepared
hope you can help tricky
Reply By: GUJim - Wednesday, Sep 02, 2009 at 18:37
Hi Tricky.
All the infamous ZD30 problems are considered (and pretty well proven) to be resolved by 2003 so yours should be pretty safe.
You should certainly consider fitting an exhaust gas temperature guage (pyrometer) as these are almost essential when towing to ensure the motor does not get too stressed. An upgraded exhaust system is also good value in assisting engine performance and (more particularly) getting heat away from the motor. Also if funds permit, a performance chip helps with better low revs torque and some fuel consumption gains.
You will find many entries on this and the Patrol forum (http://www.patrol4x4.com/forum/forumdisplay.php?f=10) referencing mods to the ZD30 engine, but I believe the best insurance for any tow vehicle is the EGT guage.
Hope this helps,
Regards,
Jim.
AnswerID: 381650
Follow Up By: Tricky Dicky - Wednesday, Sep 02, 2009 at 19:15
Hi Jim
thanks for your advice i will check out prices for the guages and also the performance chip and have them installed before i tow to far
Tricky
FollowupID: 649204
Follow Up By: Member - joc45 (WA) - Wednesday, Sep 02, 2009 at 23:00
Also suggested is a boost guage, as one of the problems with that engine is overboosting when the MAF sensor decides to do a wobbly.
FollowupID: 649244
Follow Up By: Kumunara (NT) - Thursday, Sep 03, 2009 at 07:17
Jim
I have a friend with a 05 patrol who would disagree with you. His motor exploded when the vehicle was 17,000 kms out of warranty. Nissan would not cover it. I guess the problem is resolved for Nissan if they can get the motors to last long enough to be out or warranty.
The new 2010 patrol will not have the ZD30 motor. I hope the new motor is more reliable.
Tjilpi
FollowupID: 649276
Reply By: Member - Ingo57 (NSW) - Wednesday, Sep 02, 2009 at 20:13
Agree with GU Jim however best to be safe than sorry. As already suggested ask this question on the patrol forum there are a lot of GU 3lt owners that have a wealth of knowledge on these engines.
AnswerID: 381664
Reply By: Member - Malcolm (Townsville) - Wednesday, Sep 02, 2009 at 22:54
Tricky Dicky
.......All the infamous ZD30 problems are considered (and pretty well proven) to be resolved by 2003 so yours should be pretty safe.......
HA !!Well let me say, they are NOT pretty well proven !! Your question is a good one and I would hate to see any Patrol owner go through the same drama I did.
If you do a search on this forum for "FOUR CRACKED PISTONS" you can read about the saga I had with my 2005 ZD30 Patrol. Short story is it exploded at 112K. That is when I learned about the ZD30 'problems'.
As stated check the patrol4x4 forum. That's where I gained most of my knowledge.
In summary: This is what I did and why: (in this sequence)
1. Fit a boost gauge 0-30 psi - to check for overboosting issues. 10-14 psi considered OK.
2. Block the EGR Valve - stops the dirty exhaust gases going back through the engine and contaminating the oil.
3. After 2. it may be necessary to adjust the turbo screw to LOWER boost.
4. Fit a pyrometer (EGT gauge) - allows you to check the exhaust gas temperature after turbo. Over 550 degrees is considered to be getting too high and you should change down a gear (increases RPM) or back-off a bit.
5. Clean (or replace) the MAF Sensor - oil mists on the sensor can send incorrect info to the ECU (computer).
6. Remove and clean all the crap out of the intercooler and hoses. (I even did my inlet manifold because I was repairing the engine at the time). A good degreaser will do the trick. SC $2 per can.
7. Fit a Provent200 Oil Catch Can between the PCV hose. Stops oil misting up in the air filter hoses.
8. DO NOT drive in overdrive under 80kmh. Some say not at all when towing e.g over 1 tonne. But I do - drive to the conditions.
9. Engine oil changes every 5000km. A lot recommend DELO 400 15W/40. Myself, I used Mobil1 Full Synthetic 5W30. At $18 litre it can be expensive but oil changes can be extended to 10,000km.
10. Only use genuine Nissan Air and Fuel Filters. So they say.
After you have worked your way through that list I would feel fairly confident with the Patrol. It's still a great vehicle regardless of what all the knockers out there say.
If you need any further info feel free to PM me.
Malcolm
(Now done 10,000km on rebuilt engine). ;-)
living the 'good life'
AnswerID: 381699
Follow Up By: Tricky Dicky - Thursday, Sep 03, 2009 at 14:46
Thanks Malcolm for all the advice as you said i will work my way through the list and keep my fingers crossed.
I have always driven in overdrive when towing the same as you so far no problems i never drive more than about 85ks and the van i tow is very light the patrol don't know its there.
Tricky
FollowupID: 649352
Reply By: Tricky Dicky - Thursday, Sep 03, 2009 at 14:47
thanks to all for your help
Tricky
AnswerID: 381781
