Will Gps units from Australia p/u signals in UK ?
Submitted: Thursday, Sep 03, 2009 at 10:43
Member - William B (The Shire)
Hello Ladies and Gentlemen,
I am off to the UK in October and was wondering if my Navman iCN 520 will work in the Northern hemisphere.
My thoughts are that a satellite is a satellite and it should make no difference.
Any thoughts please.
Will.
( not inland this year but Ickenham )
Reply By: MrBitchi (QLD) - Thursday, Sep 03, 2009 at 10:54
Yes it will pick up the signals and work out your position, might take a while when first switched on though, but you'll need to get the local maps.
381747
Follow Up By: Member - William B (The Shire) - Thursday, Sep 03, 2009 at 11:25
Thanks for the reply John,
I thought as much, but it always helps to check.
Especially on this
well informed
forum,
Will
649301
Reply By: landseka - Thursday, Sep 03, 2009 at 11:17
Yes it will work.
I am not familiar with that unit specifically but if it uses maps, like a tomtom for instance, then as said above, you will need the local maps.
If it is a straight gps like my garmin plus that is not necessary.
The gps uses all satellites that are visible to it, it may use 9 or 10 if they are seen to triangulate your position.
You may have to enter a Set-up phase to initiate it again so it knows roughly where you are. This is normal if you travel over 500 kms with it turned off.
Hope this helps
Neil.
381750
Follow Up By: Member - William B (The Shire) - Thursday, Sep 03, 2009 at 11:30
G'day Neil,
Thanks for that info.
The Navman uses a SD card system and I have the maps loaded on that.
Actually I use the Navman as a gps reciever and have managed to run tomtom mapping on it, which I find better than the navman version.
Will
649304
Reply By: TerraFirma - Thursday, Sep 03, 2009 at 12:09
You should send Navman an email asking them for access to the maps and instructions etc just to be sure
381758
Reply By: Flywest - Thursday, Sep 03, 2009 at 14:08
No,
It won't do it form here!
381778
Follow Up By: Member - William B (The Shire) - Friday, Sep 04, 2009 at 00:13
Funnily enough I was cursing the satnav the other day for not working, then I realised it was on the UK map.
Guess what?
It wont work from here. He He
Will
649440
Reply By: Member - Doug T (NT) - Thursday, Sep 03, 2009 at 14:48
Will
As others have said yes, you can get street nav' maps to upload to a unit, for this post I will refer to Garmin units, If you purchase a Nuvi 765 it will have all major roads and some minor already installed as part of the base map,
If you need street level Navigation for all of Europe check this link,
Mapsource City Navigator Europe
Image Could Not Be Found
381782
Reply By: The Explorer - Thursday, Sep 03, 2009 at 15:40
Dont forget to take a compass and a paper map as a backup :)
381791
Follow Up By: Ups and Downs - Thursday, Sep 03, 2009 at 19:38
Not to mention
the Spot, EPIRB, emergency food, safety boots etc, and don't go alone.
Just kidding, after the saga over hiking in the snow!
649399
Follow Up By: WBS - Friday, Sep 04, 2009 at 08:06
Make sure the compass(Magnetic not Digital) you take works in Europe because compasses (such as Silva) make different compasses for different regions of the world. Ones used in Australia may not be accurate in Europe. :)
WBS
649456
Reply By: mikehzz - Thursday, Sep 03, 2009 at 21:54
I've been all over UK and Europe using Tom Tom on a windows PDA/Phone with inbuilt GPS. I got the maps and loaded them on an SD card before I went. No different to using it here, just a different map.
As for using paper maps in Europe.....too many streets and towns with names longer than the alphabet. A piece of cake with the GPS.
381843
Reply By: Member - William B (The Shire) - Friday, Sep 04, 2009 at 00:08
Thank you every one for your informative replies and your humorous ones as
I think I will not travel to Wales using the Tomtom, I can image trying to find some of the road names.
I will have to see if I can download some taffie voices for when I travel there.
Come to think of it, I could personalise the voice I use for different areas.
Cockney rhyming slang for the East end, a Gordie voice for Tyneside, a Scottish broque, the mind boggles (& wanders) at the possiblities.
Thanks again,
Will.
(counting down the days to my first Brentford game in 5 years, go the Bee's)
381855
Follow Up By: WBS - Friday, Sep 04, 2009 at 08:09
God know how my Garmin Nuvi would go in Wales becaue it certainly makes a hash of street name pronunciations in
Melbourne.
WBS
649457
Follow Up By: WBS - Friday, Sep 04, 2009 at 08:11
Just like I made a hash of the spelling in the above FollowUp.
WBS
649458
