Problems with dual fuel
Submitted: Saturday, Sep 05, 2009 at 17:54
brizmatt
I have a Bravo 2600 on dual
fuel, Have been trying to get it running properly for about three months. It runs perfectly on LPG but on petrol idles all over the place, hiccups when you accelerate and stalls. It also did the "airflow meter" which was expensive and was told this may have been caused by the problems. Two mechanics have had a go with no luck. It feels like it is getting air in somewhere. Throttle body has been off but appears to be sealing ok. I am at wits end, any ideas other than just using LPG!!! I need the petrol for trips.
Matt
Reply By: oldpop - Saturday, Sep 05, 2009 at 18:06
Matt
Get the injectors cleaned common prob with duel
fuel cars
Oldpop
382063
Follow Up By: brizmatt - Saturday, Sep 05, 2009 at 18:38
I'll give it a go.
649641
Reply By: Member - Christopher P (NSW) - Saturday, Sep 05, 2009 at 22:10
soapy
water all the joints and connections, worth a try. I stay
well clear of BOMBS IN THE BOOT!
Yeah i know narrow minded. but gas scares me.
382104
Reply By: kcandco - Sunday, Sep 06, 2009 at 13:16
Hi Matt
Is your
fuel old and possibly on the stale side? If so you may need to remove
fuel tank, clean and add new
fuel and possibly filter.
Has your
fuel pump been checked for correct pressure?
Injectors could need cleaning.
Fuel rail may need attention, ie
fuel pressure regulater or damper.
I know your frustration. Had similar problems myself and ended up selling car still with miss.
GOOD LUCK
regards Kc
382156
Follow Up By: brizmatt - Sunday, Sep 06, 2009 at 19:28
KC,
I took for a hard run today on petrol with my thinking being might clear injectors. No change- rotten at idle and low revs butruns great over 1500 rpm. Hadn't thought about
fuel quality, may give that a go and then flll up with premium.
Was advised that
fuel rail is approriately pressured and
fuel pump ok.
It runs perfectly on LPG but need to fix petrol for trips away when LPG is scarce. It will send me crazy!!
Thanks for your response.
Matt.
649735
Follow Up By: brizmatt - Sunday, Sep 06, 2009 at 19:30
and I'll get the injectors cleaned this week.
649736
Follow Up By: KennyBWilson - Sunday, Sep 06, 2009 at 21:48
There is a section that also needs to be cleaned, usually they soak the part in petrol for a few days , I just can't remember the name of that section , it's where everything inside is black ( carbon build up )
649753
Reply By: ozwasp - Tuesday, Sep 15, 2009 at 20:25
Air might be getting in past the air filter and sensor. If this happens then the oxygen levels won't match up, causing it to run badly - I know as it's happened to me with my Hilux when the system has backfired and punchered the airbox.
383282
