1999 GU PATROL CLUTCH UPGRADES
Submitted: Saturday, Sep 05, 2009 at 18:06
ThreadID: 72062 Views:2221 Replies:4 FollowUps:0
Hi out there,
can anybody tell me which clutch upgrade is the best for my patrol.
I am finding that it is hard going from 1st to 2nd when I first drive off, the gears chatter a bit and it is a little disturbing.
the other gears seem to be all right but some times are quiet hard to get into gear.
Is there a heavy duty clutch system that would be suitable.
Danny
Reply By: Member - MUZBRY(Vic) - Saturday, Sep 05, 2009 at 18:25
Gday Danny
Are you sure about the clutch? Have you had the oil changed in the box lately? Mine is the same but I am not worried about it as we have a new clutch and oil. I will put different type of oil next time it is due.
Murray
AnswerID: 382066
Reply By: Retirement - Saturday, Sep 05, 2009 at 19:13
Hi Murray,
Yes I have just changed to all NULON Products, one of them being 75w-90 Performance Smooth Shift Manual Gearbox & Transaxle Oil,
With no change.
Danny
AnswerID: 382070
Reply By: Rockape - Saturday, Sep 05, 2009 at 20:09
Danny,
is it the gears that chatter or is it that the clutch rattles when you let it out.
AnswerID: 382083
Reply By: ian zzr - Saturday, Sep 05, 2009 at 20:16
i have a 99 patrol 4.2td , fairly normal for these gear boxes to have cold shift baulking 1st to 2nd , within 1/2 km all is ok know matter if you use vmx 80 or multitrax which is 75/90 or the heavier 80/90 and slight gear chatter when gear changing at a low rev , feature not a fault , these are a notchy box but strong, just go a bit easy first couple of cold shifts .
if balking when warm there is a problem.
AnswerID: 382086
