PWM Solar Regulators & HF Radio Noise
Submitted: Saturday, Sep 05, 2009 at 19:05
ThreadID: 72065 Views:4952 Replies:10 FollowUps:4
Has anyone with a solar set up & HF radio (espc an NGT) noticed if it creates any noise that causes interference to the HF radio reception?
I am contemplating a solar set up for long distance touring & camping. If I understand correctly (& I may not!) a PWM regulator is the same as a voltage switcher power supply which are notorious for creating electrical noise. Just wondering if anyone can share their experiences.
Thanks as always for any advice.
Ben
Reply By: blue one - Saturday, Sep 05, 2009 at 19:32
Nup,
Not over 7500kms just recently.
AnswerID: 382073
Reply By: BenDiD - Saturday, Sep 05, 2009 at 20:30
Thanks Blue One
Ben
AnswerID: 382089
Reply By: RV Powerstream P/L - Sunday, Sep 06, 2009 at 07:46
Swithchmode power supplies can vary and they are diferentiated by The (PFC) Power factor Correction.
PFC comes in two types Active and Passive.
Passive is the cheapest so the potential of EM radio interference with this type is greatest and the PFC is generally only to about PF 0.85.
Active PFC is more effective but is also more expensive so that should tell you something as it is generally PF 0.98 or better.
The main consideration is to ensure isolation of cables associated with your NGT to minimse the chance of any contamination from such devices.
I know of instances where interference could not be avoided so alongside the radio is a switch that turns off the charger while the radio is in use.
Ian
AnswerID: 382123
Reply By: BenDiD - Sunday, Sep 06, 2009 at 08:02
Thanks Ian,
Now I know which type of regulator to look for. The NGT & its cables are fairly well isolated / insulated as I am a bit paranoid about minimising interference - I have just seen so many posts with so many people having all manner of trouble. So far I have been OK and I'd like ot keep it that way!
Cheers again
Ben
AnswerID: 382125
Reply By: Ozhumvee - Sunday, Sep 06, 2009 at 11:19
After many years of installing HF's in all manner of vehicles from Prime movers to small cars I came to the conclusion a while back now that stopping electrical noise interference with HF in modern vehicles with all manner of electronics both OEM and aftermarket was nigh on impossible especially as the manufacturers stuff was the worst. TD5 Landies were a case in point, the electronic injection system overloaded the receiver on the HF to the point where the HF was unusable.
I no longer use the HF when mobile but only use it when stationary with everything turned off except the HF as even the GPS running can cause enough interference to stop it receiving a selcall.
Way to much work to try and stop the interference and it is all negated if the bloke next door has a fluoro light switched on.
AnswerID: 382148
Follow Up By: BenDiD - Sunday, Sep 06, 2009 at 16:13
Thanks Peter,
Yes, I have heard many stories like the ones you mention and so have been a bit overly careful when installing my NGT and since it went in, adding new accessories. I even read of one fellow who had to earth just about everything on is vehicle, see here.
So far I have been lucky and the NGT works well, even when driving (I have a TD Pejro).
Ben
FollowupID: 649720
Follow Up By: Ozhumvee - Sunday, Sep 06, 2009 at 18:54
I used to do that, earth every panel seperately, bonnet, all doors and even the exhaust front and rear, you end up with a very quiet vehicle electrically.
One of my troopies was an ex police comms vehicle, I reckon there was about 10 kilo's of 1" wide copper braid between all of the above and it was very quiet.
Funnily enough Pajero's were one that gave a lot of headaches to do with the EFI system on the v6's, you could stop the engine by hitting the autotune on certain frequencies.
Best trick was to drag a Paj of at the lights and as he pulled ahead hit the tune button, he'd get the staggers and slow down!
FollowupID: 649733
Follow Up By: BenDiD - Sunday, Sep 06, 2009 at 19:27
My first Paj (without A HF) was a V6 NP. So many people with that model seemed to have trouble with noise. Even the OEM radio was unlistenable on AM!
FollowupID: 649734
Reply By: mr fixit - Sunday, Sep 06, 2009 at 18:54
TD5 landrovers radiate so much RF they should require there own ACMA licence.
AnswerID: 382176
Reply By: Member - Mike DID - Sunday, Sep 06, 2009 at 19:30
Not all Switchmode Power Supplies are created equal.
I have a 12 volt 60amp supply that produces absolutely no detectable noise on HF - that's why I bought that one and it works !
AnswerID: 382184
Follow Up By: BenDiD - Sunday, Sep 06, 2009 at 19:37
hi Mike,
Can you point me in the right direction - brand etc?
Ben
FollowupID: 649737
Reply By: RV Powerstream P/L - Sunday, Sep 06, 2009 at 20:17
Ben
Mike knows.
What I told you was fact but get a supplier to tell tell you the difference and 99% would not know what they were selling and to top it off the ACMA has three mandated standards that is Cispa 11,Cispa 14.1 /14.2 and Cispa 21 and as long as you having testing to any of the mandated standards then you get a Ctick approval to sell.
The problem is that only Cispa 11 and Cispa 21 cover the emmission standards for radio interference where the interference sould be life threatening such as in a marine emergency so if you are Ctick approved under Cispa 14.1 you are legal but also rat bleep with HF interference so there are big holes in the compliance standards and HF is still the main emergency distress for yachts at sea.
So what I have told you is correct but prove it to be of benefit for your application.
Welcome to Australias beurocratic system of money first technology and safety later but dont worry we will get there but at what cost to the consumer with our pyramid building beurocracy that makes regulations on regulations to get pay increase levels and build their own defensive castle of safe employment.
Ian
Ian
AnswerID: 382187
Reply By: paulnsw - Sunday, Sep 06, 2009 at 21:02
have a Morningstar prostar 30a regulator 2m from HF radio and no interference
AnswerID: 382193
Reply By: BenDiD - Sunday, Sep 06, 2009 at 21:16
Thanks All
It seems that with this topic, like many covered in this forum, the more questions you answer the more you have!
Ben
AnswerID: 382196
