Toyota HZ75 Clutch Question
Submitted: Friday, Sep 11, 2009 at 07:35
ThreadID: 72176 Views:2844 Replies:6 FollowUps:4
I have read all the threads I can find on Clutches and sorry if my questions below have been 'done to death' before.
I am about to replace my clutch (190k) - mostly due to bad vibes, and precaution for future trips.
Is there a better replacement clutch than the Genuine Toyota, for 'normal' touring etc? or is it simply not worth the money?
Many Thanks, Ian
Reply By: Member - Tour Boy ( Bundy QLD) - Friday, Sep 11, 2009 at 07:51
Terrain Tamer,
strong clutch an you shouldn't get the shudder of the OEM clutch,.
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 382722
Reply By: Rockape - Friday, Sep 11, 2009 at 07:51
Pay the extra and go genuine, unless you can source a clutch from the factory that make them for Toyota.
Toyota have a great reputation for quality parts, my old dear is still running the same uni joints after 20yrs and thats after 5yrs with the 6.5l trying to destroy them.
Rawnsley autos in Townsville is a supplier that source their parts that way.
Have a good one
AnswerID: 382723
Reply By: Ups and Downs - Friday, Sep 11, 2009 at 08:52
Ian,
I'm still on my original clutch at 360,000km so I am impressed with the genuine item.
Paul
AnswerID: 382728
Reply By: Serendipity of Mandurah (WA) - Friday, Sep 11, 2009 at 09:02
I was once told the clutch in the turbo model is better than non-turbo. Might be just a tale.
Also if you are getting a take of shudder, this is most often caused by a hot spot on the flywheel. You might already be onto this but just in case - you should always have the flywheel skimmed.
David
AnswerID: 382730
Follow Up By: Member - ross m (WA) - Friday, Sep 11, 2009 at 10:46
"I was once told the clutch in the turbo model is better than non-turbo. Might be just a tale"
Thats true ,but they are a different gearbox and flywheel. The non turbo is 275mm and the turbos are 300mm
FollowupID: 650349
Reply By: Member - ross m (WA) - Friday, Sep 11, 2009 at 10:48
Ive got an Exedy Sports tuff and I think its equal to or better than the factory clutch.
It really cuts down the grr grrr grrrr coming out of the corners
AnswerID: 382747
Reply By: Member - Rodney B- Friday, Sep 11, 2009 at 11:05
I fitted the Sports clutch to my 80 series at 180000 and the genuine was still in good order but the throwout bearing was goosed. Wish I had refitted a genuine one as the sports clutch is much harder to press down and in fact bloody uncomfortable to try and hold it down for any length of time. It won't slip though under any circumstances and has no shudder whatsoever so is good in this aspect but is just difficult to push down. Have done about 20000 with the new clutch and it hasn't got any easier. Go Genuine.
Rod
AnswerID: 382754
Follow Up By: Imstat - Friday, Sep 11, 2009 at 18:38
Thanks very much everyone - some very practical advice here.
The Excedy Safari Tuff seems a good prospect. It is about the same price as the Toyota Kit.
It's all a bit like buying milk ! So many options, but I gues you can't go wrong with an original manufactured.
Thanks, Ian
FollowupID: 650407
Follow Up By: Member - Toyocrusa (NSW) - Friday, Sep 11, 2009 at 20:28
Hi Rod. I saw an 80 series about 10 years ago that had a small booster (servo) unit fitted into the clutch fluid line. I think it was a PBR unit. The owner had an injured leg and it halved the pressure required to depress the clutch pedal. Regards, Bob.
FollowupID: 650430
Follow Up By: Imstat - Friday, Sep 11, 2009 at 20:38
My 60 Series (1987) had a servo booster fitted as standard (power clutch). My wife could drive it! Cheers Ian
FollowupID: 650431
