these tyre pressure monitors....
Submitted: Friday, Sep 11, 2009 at 19:03
Steve
I'm thinking of the screw-onto-the-valve type. I think it was a JET that took my fancy. Question is, are they theft proof/lockable?.......and, I gather they pick up ambient temperature as much as actual tyre pressure. In other words, if you're heading north late afternoon, the driver's side tyres will be a fair bit cooler because the other side will have the sun on them. I can probably cope with that, I suppose the main thing is, that they show up any significant loss in air pressure which can lead to a blow-out. I've just about had my fill of them in recent years. Usually the same thing, one tyre has a fair bit of deflation and consequently blows during long run@ 90/100 ks. Shredded tyre. Last time it happened I severed the brake line as
well and ended up waiting outside Benalla for 7 hours to be towed in. Then waited all the following day to be fixed up. Maybe I could've been more vigilant but you know what it's like; blinkers on and not being retired yet have limited time to make a mile.
Reply By: Member - barry F (NSW) - Friday, Sep 11, 2009 at 19:42
Hi Steve, Go to the top of the page & enter into "Thread find" the thread number 69889 & you will get many & varied opinions. The variation comes from the individual need you need to weigh your need up against the available systems. Hoo Roo & good luck
382805
Reply By: Member - Mick O (VIC) - Friday, Sep 11, 2009 at 20:01
ISteve,
I have and operate both. Internal tyre units (senstyre) and screw-on type sensors (tyredog). If you're doing highway travel only, either will be fine. If you intend travelling on a dirt road, don't bother with a screw on type. They are very poor performers. If you're doing rough stuff, forget the screw on entirely. They are an incredibly poor option. I have posted this info before (Aug 09). Go any form of internal sensor if you want real time and acurate info while in the bush.
Cheers Mick
382807
Reply By: Member - Graham H (QLD) - Friday, Sep 11, 2009 at 22:56
Derek on here sells them for a reasonable price.
They are the screw on type.
I have a similar set and they have been fairly good. Have 8 sensors on car and van.
They do show the temp as it builds up and the tyres on the sunny side are usually about 3 deg hotter than the cold side.
Have saved me two tyres so far so have paid for themselves.
One minor prob the ones on the van cut out sometimes due to the amount of metal between the sender and receiver.
Fixed that by buyind a small amplifier that goes at front of van
Seems to have fixed the problem.
382830
Follow Up By: DIO - Saturday, Sep 12, 2009 at 09:55
You'll find Derek's products here at
ABR Sidewinder
650473
Reply By: Motherhen - Saturday, Sep 12, 2009 at 15:42
We haven't got ours yet, but favoured the Sensatyre over the screw on types. They have an additional advantage as they also monitor temperature which can alert you to all sorts of other trouble. Our need is principally for the caravan, so transmission is an issue. Sensatyre can be fitted with a monitor on the caravan, and hard wired to the car to avoid transmission problems. All are expensive, but so is a tyre and rim.
382871
Follow Up By: Steve - Sunday, Sep 13, 2009 at 09:41
We wrote a van off about 10 years ago. It was a fairly old model (our first) and travelling at 90kph, had a blow-out which resulted in the rim (single axle) heating up to such an extent that it sheared through the studs, spun off, the van fell on it's side, buckled the frame and they couldn't repair or replace as the parts were no longer available. Luckily, we were insured so all turned out
well but the inconvenience.............just shows what a blow out can do though.
650561
Follow Up By: Motherhen - Tuesday, Sep 15, 2009 at 19:41
Hi Steve
Glad it worked out OK for you in the end. One of the reasons my husband favoured four
wheels over two. However with four
wheels and the Simplicity
suspension, one can go flat and you won't know - no harm to the rig, but can be too late for the tyre and rim when discovered. Tyre monitors sound like a good idea for caravans.
650916
Reply By: xxx - Sunday, Sep 13, 2009 at 22:33
The Jette screw ons monitor temp and press. They have performed faultlessly in the very rough.
I previously had the Tiregards inside the tyre. Performed
well too but damaged during tyre removal.
383040
Follow Up By: xxx - Monday, Sep 14, 2009 at 13:41
Not Tiregard, Smartire I mean.
650702
Reply By: AdrianLR (VIC) - Wednesday, Sep 16, 2009 at 08:40
I've recently bought an AVE system off eBay. There are two sellers - one in Canada and one in Portugal. Both communicated very
well but the Portugese chap had better prices and much lower postage (the Canadian one wasn't ripping anyone off but postage from North America seems to always be expensive).
The system has internal sensors and will monitor 27 tyres. An external antenna is available but the sellers are confident that for a camper trailer this isn't required. I'll find out in a month or so when we get the camper out for the first time this season.
Everything works
well, display is clear, easy to fit (I had a tyre
shop fit it but if you have a beadbreaker it's very easy to do it yourself). A wheel balance is required afterwards.
As for after sales service, one of the sensors didn't register pressure. A new one was sent without questions and was in the letter box within a week.
The Canadian seller has a website and now supplies a second generation unit that allows different pressures on different axles. I didn't need this as the camper has similar tyres and similar axle loading so I run the same pressures.
All up was under $300 delivered with 7 sensors. Search ebay with the terms AVE and TPMS, include worldwide as an option. The Buy It Now item (1st gen) from the Canadian seller has recently been reduced in price (below what I paid :( ).
No affiliation etc. etc. just satifsfied.
Adrian
383324
