76 series engine knock cold
Submitted: Friday, Sep 11, 2009 at 21:51
V8 Grunt
Hi guys , just wondering if anyone has any feedback on the 76 series wagon badly knocking when cold,i have done alot of research and keeps pointing to the injectors being faulty,it has done it since new and has got louder,now having 43000 on the clock,otherwise goes great.I took it into toyota the other day for the secondtime in 12 months,this time stating my case about the injectors etc and it came back with nothing is wrong all injectors are within spec and cant do anything.They said it is normal and should be ok.My reply to the half smart service advisor was if it blows an engine out of warranty i will tow it through his front door.Can anyone shead some light on this please.
Reply By: mowing - Friday, Sep 11, 2009 at 23:10
Hi, If you do a search of past threads I think that you will find that this has been raised before.
Mark
382832
Follow Up By: V8 Grunt - Saturday, Sep 12, 2009 at 07:15
Hi mark,i have searched and read all the past threads,like i said everyone seems to point to an injector overfueling noise,iam not convinced that toyota have checked properly,it really does knock away cold,you would swear a rod is about to throw.The say it is fine and have to live with it,the question i ask is why out of 90% of the people with this problem have had an injector replaced and
mine is normal,cant be right.I just have to cross my fingers that when it runs out of warranty next year that it does cost me a fortune,i can just feel what is going to happen.Should i take it and get a second opinion somewhere?
Wayne
650453
Follow Up By: Member - Scoof (SA) - Saturday, Sep 12, 2009 at 09:43
Would it by worth getting a second opinion from a diesel injection specialist rather than a the manufacturer that just fobs you off.Just a thought.
Cheers Scoof . :-)
650471
Follow Up By: oz doc - Saturday, Sep 12, 2009 at 10:01
Hi V8G, has the dealer actually heard the noise himself? Just wondering if it would be worth
parking it in their yard overnight, and starting it up in their presence the next day and let them hear the noise. If they heard the nosie and persisted in saying it was fine, then I would insist that they put their comments in writing. doc
650474
Follow Up By: V8 Grunt - Monday, Sep 14, 2009 at 06:31
Thanks guys for your suggestions,yes it has been left overnight at the toyota dealership and they have heard the knocking sound and admit there is one but still persist that it is normal.I think i will take it to a diesel specialist and see what comes out of that.It knocks when cold and as revs get higher so does the knock,it does go away after about 15 minites (approx) when it warms up.Toyota said they have tested all the specs on the injectors and they are all within spec.Look iam just trying to get to the bottom of this before end of warranty next april,i can live with it if the engine goes forever with that typr of knock but everyone else that had a similar problem seems to have had it fixed.
Will let everyone know how i go in the near future.
Wayne
650658
Reply By: Member - Kevin B1 (WA) - Saturday, Sep 12, 2009 at 11:22
I am a Diesel mechanic and what you have explained points directly to a leaking injector. A knock like you state when cold is NOT NORMAL and it appears you are being fobbed off. The injector can not over
fuel as that is controlled by the injector pump. An injector must have an airtight seal that will only deliver
fuel at the correct instant and is atomised into the combustion chamber enabling an even burn. What causes the knock is the injector leaking a solid drop of
fuel into the combustion chamber causing a detonation. As the engine heats up the heat in the combustion chamber will help to overcome most of this detonation and the noise will be less prevalent. The detonation in time will get worse and can cause damage to the engine. As suggested take it to a diesel
fuel injection specialist and have them check it out, but don't ignore it or it will cost you sometime down the track.
382859
Follow Up By: ob - Saturday, Sep 12, 2009 at 12:39
Agree with what you say to a point. My undertstanding is that the v8 diesel is a common rail design and the timing and duration of injection is controlled by a solinoid which is an integral part of the injector. The
fuel pump on these engines only supplies
fuel under pressure to all injectors at a reasonably constant pressure and rate. If one injector has a crook nozzle or solinoid then one cylinder can malfunction.
Cheers ob
650485
Follow Up By: donk - Saturday, Sep 12, 2009 at 12:46
Kevin
The comments you have made are not relevent to a Common Rail Diesel as the supply pump only delivers pressurised
fuel to the 2 injector rails on the V8 (one for each bank) & the injectors are operated by the electronics depending on the needs of the engine
With common rail toyots's the operation of the injectors can be checked as the engine is operating with the intellegent tester 2 (toyota's diagnostic tool) & if the injectors are in specification in theory everything should be ok
If you are concerned (and if the dealer hasn't actually heard the engine on cold start ) leave it there overnight & let them start it in the morning (with you there) with the IT connected & take a snapshot of the data while it is rattling & if it is out of spec (or if they believe the noise on cold start is abnormal) they can than send the data to toyota (this may have already been done though)
The common rails also have what is called a pilot injection noise when cold & this is normal
Good luck & let us know how you go
Regards Don
650487
Follow Up By: Member - Kevin B1 (WA) - Saturday, Sep 12, 2009 at 13:17
Sorry about that, my mistake. I thought you were talking about the 6 cylinder not the V8
650491
Follow Up By: dbish - Saturday, Sep 12, 2009 at 14:19
With comon rail injection be it diesel or petrol there is too mutch faith in electronic diagnosic equipment & i have used them. They may tell you the injectors are ok but only electronicly or turn of individual injectors to check if cylender mises. This does not tell you if injectors are dribling. They turn out mechanics which rely on diagnostic equipement & have lost basic diagnostic skills.
650495
Follow Up By: V8 Grunt - Monday, Sep 14, 2009 at 06:35
Thanks don for your thoughts,i might just do that,take it back to toyota after a second opinion and get them to snapshot it and i will get it sent to toyota.I know what will happen if i dont get to the bottom of this.
Will let you know how i go.
Cheers wayne
650659
Reply By: Member -Pinko (NSW) - Saturday, Sep 12, 2009 at 13:23
Are we talking about a definite knock that can be singled out as a knock that is in sync with engine revs or the engine rattles till it is warm ?
Mine rattles when cold and quietens down when it gets warm.
Stan
382868
Reply By: Member - Flynnie (NSW) - Sunday, Sep 13, 2009 at 11:21
My V8, a 79 series trayback, has started in minus 6 to minus 9 many times with no issues. It was on winter diesel at that time. Doubt that "cold" is the problem.
As others have said would take it to a good diesel mechanic.
382961
Reply By: Member - Tour Boy ( Bundy QLD) - Monday, Sep 14, 2009 at 08:57
My hilux has the same issues,
I have had 2 injectors replaced under warranty. They need to put it on the computer when it is cold not just listen to it. This will bring up any cold faults. It can be prudent to have them hook it up when it is hot the day before as
Take it to another dealer.
Dave
383059
