Saturday, Sep 12, 2009 at 23:05
Jon,
Had one of those OB's for quite a few years myself.
The above advice is spot on re the plugs and leads.
What i did find is this, because you run 2 stroke with oil in it thru the
fuel line from
Tank to OB, when not using it - the
fuel will evaporate out of the hose past the ball bearing type seals at each end. This leaves the 2 stroke oil behind in the hose, to form a hard buildup.
This happens especially up north in the heat & the more times this happens - the more oil crud builds up inside the hose.
Eventually - there comes a time when you either kink the
fuel hose or put the
fuel tank down on top of it - causing the hose to deform from round.
When this happens - the hardened dried up oil inside the
fuel hose comes away from the inside wall of the hose in small hard black flakes.
These flakes go into the
fuel bowl.
Under acceleration - load - they get sucked into the high & mid speed jets, blocking them - leaning out the mix, and causing misfires.
Often when you slow to idle - they will wash out of the top of the jet (being flat and hard they don't seem to actually permanently block the jet) and swirl around in the
fuel inside the carby bowl, - allowing the OB to idle fine.
The best practice was to drain the
fuel bowl of
fuel and get the flakes of hard 2 stroke oil out of the bowl.
Its something to think about when you have a 2 stroke and use it in remote creeks in crock country etc - something as simple as treading on the fueo line or kinking it can loosen that black oil residue thats hardened in the hose.
ONE way to avoid this is to fit one of those plastic Ryco type
fuel filters into the
fuel line, after the priming bulb & just before the actual connection to the outboard!
That will help ensure the paper cartridge filter traps any such flakes of hardened oil.
Now.
With that out the way.
There's another possibility - and that's
water in the
fuel.
Again humid
places like monsoonal north will get
water condensate inside your
fuel tank overnight and thus into your carby.
Solution?
Add a Racor brand
water separating filter into the back of the boat and run your
fuel line from the
tank to the separating filter then to the outboard.
That last solution solves all the p[reevious possibilities - yet so few boaters do it.
Mainly thoise of us who run fishing charters and need a RELIABLE outboard go to the trouble.
The rest spend their time on forums like this - asking what went wrong.
IMHO - it should be illegal to take any boat to sea, without a Racor
water separating filter in the
fuel line.
Then again who knows - it might be something else entirely! ;o)
382915
Follow Up By: happytravelers - Sunday, Sep 13, 2009 at 07:26
The oil hardening in the line after the
fuel has evaporated is something I'd never considered before, a very interesting thought. Even if it's not the cause of the problem it's still something that I shall bear in mind as the unit has long periods of sitting idle in the shed. Thank you for your input.
Jon
650534
Follow Up By: Flywest - Sunday, Sep 13, 2009 at 11:58
Just remembered, something else that would occasionally happen with
mine.
I'd had a lighting coil installed, to generate 12 volts to re charge trolling batteries and power running lights at night etc.
The earth strap and bolt for that lighting coil would work loose over time and cause the engine to misfire - until tightened - sometimes the bolt would fall out into the bottom of the cowl, and she;d stop until it was replaced and tightened.
I ran fishing tours with that engine on the Donnelly river for a number of years and despite the odd fault it really was quite reliable -but the
water separating filter was the key thing.
650583
