Can PMR Radio's register CB Radio frequencies?
Submitted: Saturday, Sep 12, 2009 at 23:03
AusTravellers
Hi all, my partner & I are interested in possibly buying a radio for our travels. We were wondering if anyone here can tell us whether or not PMR Radio's (aka walkie talkies) can pick-up CB Radio frequencies? For example, can we communicate with Truckies and other travellers using CB Radio's through a PMR Radio while we're on the road?
We are looking at a PMR Radio with the following details:
Doro WT87 PMR Two Way Radio Twin pack
Doro wt87 is a long range Walkie Talkie.
Great for outdoor activities and enabling conversations up to 5 km without paying license or subscriber fees. With over 300 channel/sub channel combinations wt87 offers plenty of privacy.
Features:
-Up to 5km range
-Over 300 channel combinations
-Voice activation (VOX)
-Auto power save
-Low battery indicator
-Headset outlet
-Belt clip
-Keylock
-Roger beep
Specifications Product Description:
Device Type: Two-way radio
Range: Up to 5km range
Talk time / Stand-by time: 120 min / 35 hours
Battery: Rechargeable NiMH
Channels: 8
Volume control levels: 8
Weight: 105g
Size (including antenna): 12 cm x 4.6 cm
Any comments and/or feedbacks would be much appreciated....
Thanks in advance!!
Tiffiny
Reply By: SteveL (WA) - Saturday, Sep 12, 2009 at 23:33
PMR radios have British frequencies around 446Mhz and are illegal to use in Australia.
382916
Follow Up By: SteveL (WA) - Saturday, Sep 12, 2009 at 23:53
They are illegal to sell in Australia and won't pick -up CB Channels.They operate on frequencies used by NSW
ambulance from memory.-Steve
650530
Follow Up By: Member - Graham H (QLD) - Saturday, Sep 12, 2009 at 23:56
If as the man said it wont work it probably wont.
If they are as good as the DORO telephones I wouldnt bother.
Get something that is common here and preferably a full car set in the car and
perhaps one hand held for backing in parks etc
Using a handheld in the confines of a metal box (car) seriously shortens range.
Nothing like a good UHF with an external aerial.
Dont take shortcuts It may come back to bite you at the worst possible time.
If you life is worth less than $500
well its up to you.
No offence intended, just a bit of hopefully helpful advice.
650531
Follow Up By: Member - Graham H (QLD) - Sunday, Sep 13, 2009 at 00:04
If you read the ad carefully it says they are FACTORY SECONDS.
Wouldnt bet my life on them Im afraid.
Bought a mobile phone that was a Second and it was terrible It turned out to be a phone that came from USA and had been originally bought in Germany.
Didnt like the Aussie networks at all and couldnt be flashed to make it work better here.
650532
Follow Up By: Hairy (NT) - Sunday, Sep 13, 2009 at 10:35
Gday,
"If you life is worth less than $500
well its up to you."
"Wouldnt bet my life on them Im afraid."
I wouldnt have thought a UHF was a life saving device? Convenient maybe...but hardley life threatning not to have one?
650569
Follow Up By: Member - Mike DID - Sunday, Sep 13, 2009 at 16:19
"PMR radios have British frequencies around 446Mhz and are illegal to use in Australia."
- no, PMR radios in Australia operate on many bands 70 to 85 MHz, 148 to 174 MHz, etc. all legal to use in Australia.
650618
Follow Up By: AusTravellers - Sunday, Sep 13, 2009 at 17:38
"- no, PMR radios in Australia operate on many bands 70 to 85 MHz, 148 to 174 MHz, etc. all legal to use in Australia."
Very good Mike. It's good to see that you actually know what you are talking about instead of talking a load of bulldust. People really shouldn't comment if they have no idea what their on about!
650628
Follow Up By: Member - ross m (WA) - Sunday, Sep 13, 2009 at 21:31
I would check on how people many use them.
Some of the PMR radios can be easily modified to transmit on emergency frequencies.
I dont think the authorities are too keen on these types
650649
Reply By: Fab72 - Sunday, Sep 13, 2009 at 07:57
Personally I wouldn't bother with them. Dick Smith sell really good Uniden handsets (quite often twin packs) that will do the job you've mentioned really
well. And just as cheap.
The Dick Smith units are usually only about 0.5watt output power, which is equivalent to about 5kms (bear in mind, what they don't tell you is that's 5kms direct line of sight - no good through hills etc). They have all the usual 40 channels (truckies, touring, local chat and emergency channel (does anyone actually monitor that channel????)
Realsitically, they're nothing more than a glorified toy. Having said that, we have a couple that we take away with us so the kids can be called when lunch is ready etc.
They're no substitute for a base/vehicle mounted unit which, for less than $200 will get you a respectable unit. Most base units run an output of around 5watts (10 times the power of your handheld jobs). Some naughty people run base units at up to 25watts....but that's illegal so I'll shut up ;)
Hope this helps.
382930
Follow Up By: Fab72 - Sunday, Sep 13, 2009 at 10:14
Nothing really other than the fact that the Doro units (being imported) will not replicate correctly on Aussie frequencies. In other words, the preset frequencies will be different. As an earlier poster stated, some of the frequencies may interfere with NSW ambos which is VERY illegal. To have them recallibrated would cost around $200 per unit.
Other examples will be that the frequencies will be "off" channel. Example...here in Aus, our car radios on AM frequency go up in multiples of 11kHz, in the Middle East they go up in multiples of 10kHz making a Aus car stereo unusable in the Middle East if wanting to listen to the AM band. So in terms of the Doro sets, out of 40 channels, (without doing the math) you might end up with 2 usuable channels. Which ones is anyone's guess.
For person to person (between the two handsets) communication will work fine, but forget trying to talk to truckies, emergency
services, tourers, roadhouses etc. Likewise, forget trying to access any repeater stations which is where you gain your best long distance communication from.
Seriously and in all honesty, unless you just want them for person to person communication, you'll find two tin cans and a length of string as a better option and far cheaper. Don't waste you money.
My opinion only, but would hate to see you get caught out.
650567
Follow Up By: Gone Bush (WA) - Sunday, Sep 13, 2009 at 11:23
Fab, it doesn't lessen the overall intent of your post but AM car radio freqs in Australia are stepped by 9 khz, just nit-picking.
650575
Follow Up By: Fab72 - Sunday, Sep 13, 2009 at 11:36
Yep...you're right GB. I realised that just after I hit the submit button. I was hoping no one would notice my error.
Glad to see someone was paying attention....LOL.
650578
Follow Up By: Member - Mike DID - Sunday, Sep 13, 2009 at 16:16
"here in Aus, our car radios on AM frequency go up in multiples of 11kHz,"
- no, in Australia the AM channel spacing is 9kHz.
650617
Follow Up By: Fab72 - Sunday, Sep 13, 2009 at 20:34
Yep...thanks Mike. Gone Bush caught me out on that one too. (See previous follow up 5 of 7).
Simple maths is not so simple early on a Sunday morning after spending a night with the Bundy Bear....hehe.
Cheers.....Fab.
650645
Reply By: MEMBER - Darian (SA) - Sunday, Sep 13, 2009 at 09:00
Seems to be no point to the exercise ? UHF radios compliant with ACMA regs will do everything you want and more - for a very reasonable dollar. Prestige Communications (online supplier) have very keen pricing - might be a place to start.
382944
Reply By: obee1212 - Sunday, Sep 13, 2009 at 09:10
no such thing as a long range uhf that you can depend on sending a long distance. They can be as high as 5 watts same as the onboard radios but will tend to drain a lot more from the little battery if you work them.
For the price of that Doro, you could add a few dollars and get something with a warranty. I would go for something that uses replaceable batteries so you can carry a couple of spares for when the thing runs flat.
Bought in Australia means it is legal and will get all the uhf cb channels.
I saw a hand held working recently in a vehicle and it works fine. Just a cheapy it was too running one watt.
Anyway the the channels can get pretty busy now without being able to pull in signals from too far away so be happy with a reasonable distance. There are plenty of repeaters out there if you really need it.
owen
382945
Follow Up By: Member - Tony V (NSW) - Sunday, Sep 13, 2009 at 10:42
obee1212, AusTravelers,
Your statement that "if it is sold in Australia its is legal" is not quite right.
I live in NSW, I can purchase a vehicle Radar Detector from Prestige Communications in West Australia, just having it in my car in NSW or Victoria is illegal.
650570
Follow Up By: Member - Graham H (QLD) - Sunday, Sep 13, 2009 at 10:59
Why buy a factory second that obviously has a reason for being such.
You can buy a first grade model with a warranty locally for not much more.
650572
Follow Up By: Gone Bush (WA) - Sunday, Sep 13, 2009 at 11:26
Graham, he seems determined to buy his Doro, let him buy it.
You can lead a horse to
water,,,,,,,
650576
Follow Up By: Fab72 - Sunday, Sep 13, 2009 at 11:45
This post has been read by the moderation team and has been moderated due to a breach of The Foul Language Rule
Forum Moderation Team
650579
Follow Up By: Member - Graham H (QLD) - Sunday, Sep 13, 2009 at 11:49
Yep seems so
Not much point asking if your mind is made up and all the advice given here is logical and probably correct.
650580
Follow Up By: AusTravellers - Sunday, Sep 13, 2009 at 13:57
Gone Bush: firstly, if you haven't gathered, i'm a "SHE" not a "HE" so please excuse WOMEN being DUMB about radio frequencies!
Secondly, I think we have all gone off the main point of this topic. If you refer back to my original posting, the question was "....We were wondering if anyone here can tell us whether or not PMR Radio's (aka walkie talkies) can pick-up CB Radio frequencies? For example, can we communicate with Truckies and other travellers using CB Radio's through a PMR Radio while we're on the road?"
Starting from Steve's abrupt comment of "PMR radios have British frequencies around 446Mhz and are illegal to use in Australia." followed by "They are illegal to sell in Australia and won't pick -up CB Channels.They operate on frequencies used by NSW
ambulance from memory.-Steve <<< which might I add for the 3rd time in a row that your comments did not answer the main question I asked.
Anyways, thank you for all your comments (and insults).
650594
Follow Up By: Gone Bush (WA) - Sunday, Sep 13, 2009 at 18:48
Settle petal,
Most of the responses have been trying to impress on you that there is a better alternative. Look at these for example:
Image Could Not Be Found
Currently selling in Dick Smith stores for $199.
With these there is no guessing as to whether you'll be able to talk to fellow travellers.
You can talk to truckies on CH40.
Caravanners in convoy on CH18.
Use repeater Channels to extend your range by several kilometres.
Listen to road maintenance teams.
Talk to truckies who use other than CH40 on specific roads like the Pacific Highway and the Woodie Woodie Rd.
Use the emergency repeater on CH5
Use recommended 4WD channels like on the CSR.
If you want private channels use the CTCSS facility.
Why not buy something that is guaranteed to do what you want it to do instead of buying something that will leave you guessing.
Good Luck. I may or may not be able to talk to you while you are travelling, depends on what you buy.
650633
Reply By: Member - Mike DID - Sunday, Sep 13, 2009 at 14:27
PMR stands for Private Mobile Radio - i.e. they have fixed channels as opposed to the shared channels in Trunked or GRN radios.
A PMR radio could be operating on just about any frequency band and are used by all sorts of
services - Rural Fire Service, Police etc.
A PMR radio could be a walkie talkie, a vehicle mounted radio or a fixed radio.
PMR generally means complying with the specifications for commercial radios, so yes, if you programmed the radio with UHF CB channels, it would be legal to use it.
382974
Follow Up By: AusTravellers - Sunday, Sep 13, 2009 at 15:18
Hi Mike. Thanks for your feedback. It has given me more of an understanding to what PMR actually means. I have also just received an e-mail back from the supplier of the product I listed and Ch. 40 is in fact programmed into this radio. Thanks again. Tiffiny.
650605
Follow Up By: AusTravellers - Sunday, Sep 13, 2009 at 15:23
The most direct response I have actually gotten.
650607
Follow Up By: SteveL (WA) - Sunday, Sep 13, 2009 at 19:52
Mike is of course correct,but PMR walkie talkies such as these (with only 8 channels)
are British spec. and usually programmed for so called PMR 446 Band. See:
http://www.superiorsignals.co.uk/pmr446.htm
650639
Follow Up By: Fab72 - Sunday, Sep 13, 2009 at 20:46
Hi Tiffany...just be sure that their channel 40 is the same, or shares the same frequency as at least one of our Australian UHF channels.
As a suggestion, perhaps ask them what frequency is their channel 40 and compare that to a list of Australian UHF channels to see if there is a match up.
Assuming there is a match and you're happy to get by with potentially only 1 channel, then go for it.
One last thing....if they come with a desktop charger, check that the mains power supply is compatible with the Aussie mains power. I guesss you'd need an adaptor plug also.
Best of luck, and let us all know how you get on......
Fab.
650646
Reply By: AusTravellers - Monday, Sep 14, 2009 at 08:41
Can someone please explain to me what the difference in W is? eg. 0.5w to 5w?
383056
Follow Up By: Member - Mike DID - Monday, Sep 14, 2009 at 09:11
W stands for "watts" - how much power the transmitter puts out, which affects the range.
0.5w is half a watt.
Keep in mind that you would have to increase power by four times to double the distance - i.e. a 2 watt set would get twice the distance of a 0.5 watt set.
Increased power increases distance you will reach, but also increases battery consumption greatly.
I will only uses sets that use AA batteries - they have three times as much power as AAA batteries - but for virtually the same cost.
650671
Follow Up By: AusTravellers - Monday, Sep 14, 2009 at 09:17
Thanks Mike.
650672
Follow Up By: steved58 - Monday, Sep 14, 2009 at 11:28
Another one to keep in mind my uniden handhelds are 1 watt but can be reduced to as low as 0.1 watt when the distance is not needed this saves on batteries considerably and the batteries are rechargable
Steve
650687
Reply By: AusTravellers - Friday, Sep 18, 2009 at 09:21
Against all controversy with the Doro WT87, I bought the radio and have finally received it. The unit itself is tiny in comparison with some other portable models on the market. Stylishly built and of high end quality. It is programmed to Australian compliance and also picks up Ch 40. Communication with my unit to other Ch 40 users is clear and POSSIBLE! The range for communication is still to be tested however so far, we seem to be picking up communication from trucks passing by from inside our caravan with the main road being approximately 500 m away.
383615
Follow Up By: AusTravellers - Friday, Sep 18, 2009 at 15:30
We have today tested the distance for the Doro WT87 we purchased, within the confines of the Port of
Townsville. My partner switched his cb radio in the to Ch 39 and I did the same with the portable unit. Communication between the cb and portable was clear to a range of approximate 1 km before it started becoming a bit distorted on his cb. However on the portable his communication was coming through really clear. Why is that? Also, stupid us, forgot to test Ch 40. However, once we left the Port, we tried communicating with other users of Ch 40. Sometimes we would hear them reply really clearly, but other times the communication would come back distorted. Why is that? Is it because we are in a built up area? We are now back at the caravan
park which is 17kms South of
Townsville. We have both portable units programmed to Ch. 40 for monitoring. And without actually communicating with anyone, the communications also come through very clearly at times, and sometimes distorted. Is this because it is clear when they are close to my location and distorted when they are far away? What methods are available to increase the clarity of the voice transmissions??
651351
Follow Up By: Member - Gary J (NSW) - Friday, Sep 18, 2009 at 15:49
AT, why not ask Doro?
651352
Follow Up By: AusTravellers - Friday, Sep 18, 2009 at 16:00
Gary, I suppose its because I'm after responses from experienced CB radio users and not responses from some Sales Chick behind a counter.
651353
Follow Up By: Member - Gary J (NSW) - Friday, Sep 18, 2009 at 16:26
AT,
With respect, you received honest, free and heartfelt advice from experienced CB radio users on this list and then bought the original prioduct from the supplier who you won't ask help from.
No further comments your honour.
651354
Follow Up By: AusTravellers - Friday, Sep 18, 2009 at 16:41
Once again we have yet another member who is confusing the issue with this posting!!
If you refer back to my original posting Gary, the whole point of it was
"Hi all, my partner & I are interested in possibly buying a radio for our travels. We were wondering if anyone here can tell us whether or not PMR Radio's (aka walkie talkies) can pick-up CB Radio frequencies? For example, can we communicate with Truckies and other travellers using CB Radio's through a PMR Radio while we're on the road?"
It has absolutely nothing to do with the product I listed or anything anyone else on this posting has said. The only people who actually answered directly to my question was Fab and Mike.
And again I'd say the whole confusion started with Steve.
Members, if you're going the reply, disregard anything anyone else has said and READ READ READ the whole point of this posting!
651356
Follow Up By: AusTravellers - Friday, Sep 18, 2009 at 16:48
Oh, and please only reply if you know what you're talking about. 1 says no, 2 says yes, and 1 agrees with the first just because he said no. which is it? and if we're refering to the product in question, it is now already a proven fact that steve is wrong and mike is right, because the portable DOES work!
651357
Follow Up By: AusTravellers - Friday, Sep 18, 2009 at 16:58
And in response to your answer Gary, it is not a matter of "wont" it is simply a matter of opinion. I simply chose to choose the response that came from whom I felt was an "Experienced CB User". And let me stress again, the product has nothing to do with the whole point of this posting.
651358
