GAS Prob's
Submitted: Monday, Sep 14, 2009 at 16:26
ThreadID: 72255 Views:2391 Replies:5 FollowUps:1
Got a FJ62 F3 Fuel/gas
got it in a couple of weeks ago, started her up on gas like I always do and I heard a loud pop ( thinking it was the air filter lid fitting up again ) not, will run on gas but wont idle, runs on fuel OK and does idle.
Any ideas to what it could be, its going to take me some time to have it repaired due to NO work
Was hoping it maybe a easy fix, thinking a flange blew in the gas conveter, I have no idea, but any ideas could bring me to fix it cheap...
Karl
Reply By: snapper49 - Monday, Sep 14, 2009 at 16:48
Had a backfire and you have blown a vacum hose off somewhere
Check all your hoses
AnswerID: 383116
Follow Up By: sweetwill - Monday, Sep 14, 2009 at 17:36
yea mate.
vacuum hose blown off for sure.cheers bill.
FollowupID: 650738
Reply By: Member - redust..... (SEQ) - Monday, Sep 14, 2009 at 17:13
Hi tt, you will find it is drawing air as stated before from a popped hose or more likely if it has the long straight tube from the air cleaner to the mixer there are purpose holes there to absorb the explosion some times has a stubby holder around them, check that out & if so just twist it around to cover the hole or replace it (the stubby holder) not a repair you can't do - just find where it is sucking the air in. see ya
AnswerID: 383118
Reply By: Fab72 - Monday, Sep 14, 2009 at 19:11
Normally I'd say it sounds like you blew up the MAF sensor (Mass Air flow sensor), but I think I've been hanging around fuel injected engines for too long.
In the case of the 3F engine, I'd agree with the others...Vacuum leak.
Easiest way to diagnose where exactly it's coming from, if it's not audibly obvious, is to spray small amounts of WD40/CRC around the area of the suspected leak. If the idle improves, then you've found the source.
Be careful not to spray the gear near a hot exhaust manifold.
Fixing it could be as simple as refitting the hose, pluging the hole or wraping a bit of old inner tube around the source and securring it with a band clamp or the like. Creativity is no boundry here....just be sure what you use won't get sucked in to the engine. You'd hate to give the ole girl heartburn.
AnswerID: 383137
Reply By: tommytomato - Friday, Sep 18, 2009 at 14:44
Cant seem to find any air leaks at all
Where's the PCV valve on a Land Cruiser
karl
AnswerID: 383650
Reply By: That Troopy Bloke (SA) - Friday, Sep 18, 2009 at 17:52
I used to have a dual fuel FJ62 that backfired through the carby a few times.
The gas bloke I used to take it to for repairs reckoned it was "blowing out the diaphragm in the gas mixer".
The only way to prevent it happening was to feed it new plugs, points, and leads every 6 months. That got old real quick, and threw the economic benefits of running on LPG out the window. The unreliability of the LPG, together with the loss of cargo space due to needing 2 gas tanks to get any sort of a worthwhile range out of it, saw me trading it in on a diesel troopy. Never looked back.
The fact that yours "runs on fuel OK and does idle" suggests to me that perhaps it has not been tuned properly to run on LPG....mine could be tuned to run sweetly on either gas (but poorly on petrol), or petrol (but poorly on LPG), but never both :-(
Good luck getting it sorted.
Glenn
AnswerID: 383668
