Landcruiser 105 series
Submitted: Monday, Sep 14, 2009 at 18:00
ThreadID: 72260 Views:8046 Replies:4 FollowUps:4
I have a 1999 105 series GXL Auto FZJ105 with a 4.5 petrol in it.
Just got a price to get a 2.5 exhaust fitted from the cat back.
Trouble is, the mob who Quoted me, reckon that model didnt have a Cat.
I got under, and had a gander, I cant find one either, Does anybody know whats what
Reply By: Member - Donks1 (NSW) - Monday, Sep 14, 2009 at 18:28
Image Could Not Be Found
Donks1
AnswerID: 383130
Reply By: Member - DOZER- Monday, Sep 14, 2009 at 20:50
Dot waite your money...std is 2.25 inch and stainless....cut out the large muffler and replace it only with a long straightthrough muffler. Spend the rest on something nice
Andrew
ps no cat reqd in oz when vehicle is a lorry above 2000kg tare
AnswerID: 383167
Follow Up By: joff1 - Wednesday, Sep 16, 2009 at 17:52
my 105 zorst was not SS, maybe you are thinking about the 100 series IFS
FollowupID: 651023
Follow Up By: Member - DOZER- Thursday, Sep 17, 2009 at 22:55
Gday Joff
There is something good in it, its not shiney, but it doesnt rust either.
The biggest restriction is where the 2 engine pipes are squashed into the one larger pipe, cut that out and you are in front....extracters are very expensive ....all this work will get heat out quicker if running gas, but increasing power at revs on a 4.5 doesnt really help out much....unless you are towing heavy things around :) The other thiong worth mentioning here is be careful of noise, the 4.5 is a noisy motor, and replacing mufflers with straight throughs, will end up making it sound like a vl with a hotdog.
Andrew
FollowupID: 651259
Follow Up By: joff1 - Saturday, Sep 19, 2009 at 18:57
I fixed all the 1fz issues by hoiking it over my shoulder an replacing it with a 1hd-fte.
FollowupID: 651550
Reply By: Member - Tour Boy ( Bundy QLD) - Tuesday, Sep 15, 2009 at 08:07
No cat, and the std exhaust has a crushed section above the rear diff that causes the most restriction, just changing that will help.
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 383208
Follow Up By: joff1 - Wednesday, Sep 16, 2009 at 17:53
My 3" now threads between the crossmember and the panhard rod. No drama with 2" lift
FollowupID: 651024
Reply By: bass_straitener - Wednesday, Sep 16, 2009 at 15:07
G'day Greg,
I just had my exhaust replaced with a 2.5inch Redback system and Pacemaker Extractors as the original muffler had developed a leak.
There is no cat in a FZJ105. I had a number of quotes that had a hi flow cat quoted. Needless to say I didn't use them for the work.
Sounds good and does help a bit with top end power. Overall I'm really happy with it. Total price was $1300.
Regards, Bruce
AnswerID: 383372
