Steca Solar regulator
Submitted: Wednesday, Sep 16, 2009 at 19:59
touringoz
Had fitted a Steca regulator and solar panel a few weeks back, also had the Van wired so I could run 2 batteries. I purchased 2 new batteries yesterday and had the Auto electrician replace my old Van charger and put in a Ctec 7000. This morning I connected the new batteries, I checked my Steca regulator and it had an error message No 7 (battery voltage to low) My question is would I just have to reset to factory settings to get the regulator back on track, any advice appreciated.
Reply By: justmyage - Thursday, Sep 17, 2009 at 03:13
hi i have just added a further 2 batteries to my van which also has the same reg when i connected it up again i also got the same error. just disconnected battery wires from the reg and then reconnected them . everything went back to normal . hope this helps
383466
Follow Up By: touringoz - Thursday, Sep 17, 2009 at 08:51
Thanks worked a treat, thanks for the info.
(You gotta love this
forum)
fergy
651103
Reply By: Rod - Thursday, Sep 17, 2009 at 18:55
Just be careful with the Steccas. They are a positively earthed controller. If you have a common negative earth between your panel, controller and battery, the unit will blow up when it goes to shunt any current.
Yes this is in the germlish instructions but not immediately apparent.
Great units otherwise.
383536
