winch experts
Submitted: Thursday, Sep 17, 2009 at 17:27
ThreadID: 72323 Views:3548 Replies:8 FollowUps:8
goodday all
have had my ironman winch installed and installer said try not to stack cable across cable how do you do this without standing at the front of the car feeding it onto the winch drum
steve
Reply By: Member - Shane D (QLD) - Thursday, Sep 17, 2009 at 18:29
You will have to put tension on the new cable as it's fed onto the drum.
I live on a slight hill so i hook up my wife's car and dragged it up, just enough weight on the wire, but not enough to "load" the winch and guided the live cable by hand wearing heavy duty gloves.
This was only to feed the cable evenly on the drum, and was a lightly loaded, NEVER do this while doing a recovery, thats asking for decapitation.
I found that the cable MUST go on evenly or it wont fit on the drum without fouling, by evenly I mean that smooth straight layers right across the whole drum
Shane
AnswerID: 383528
Reply By: Sir Kev & Darkie - Thursday, Sep 17, 2009 at 18:33
Steve,
Wait till you get to St George and you can recover Jo when she gets stuck, that will put enough tension on the winch cable when it goes back on the drum LOL
6 sleeps to go ;)
Cheers Kev
Russell Coight:
AnswerID: 383530
Follow Up By: Member - TonBon (NSW) - Friday, Sep 18, 2009 at 14:57
AAARRRGGGHHHH i cant stand it!!!! I WANT TO GO TO St George!!!!!!
FollowupID: 651344
Follow Up By: Sir Kev & Darkie - Friday, Sep 18, 2009 at 17:07
Well what is stopping you?? hehehehe
Just finished work and now just have to pack and we are on the road to St George LMAO
Russell Coight:
FollowupID: 651363
Reply By: Atta Boy Luther - Thursday, Sep 17, 2009 at 18:53
Put the cable on under a slight incline the first time as said . When doing a recovery if its going to overlap then there is not much you can do . After the recovery you need to fix it up though using a slight incline again . Check the cable for broken strands as you respool it on .
AnswerID: 383535
Reply By: Traveller - Thursday, Sep 17, 2009 at 20:05
Now waddya going to need a winch for, young fella?
I have never been able to roll the cable on correctly and have given up trying over the past 20 years or so. It is not that important. A prefectly wound cable is only for aesthetics. As long as the cable doesn't snag, you will be OK. Then again....if you have nothing to do.................
AnswerID: 383548
Reply By: reversemulletman - Thursday, Sep 17, 2009 at 20:29
Hi all
First time poster so excuse any mistakes.
I think what your installer is reffering to is when the cable is wound on willy nilly, making what my mother would refer to as a "birds nest". As others have said you need run out the cable and wind it back on under tension before you use it. This is true. Doesn't have to be much, just be on a slight incline. Its best to secure to a fixed/stationary object and winch your vehicle towards it and I'll explain why.
Start with at least five turns of cable already on the drum, then take up the strain. If the cable is attached to the left side of the drum, you'll want it to spool across to the right, the second layer will spool across to the left, then right/left/right and so on until you run out of cable.
To do this aim your vehicle off to the left (or the right, depending on what side it's fastened to the drum) so the cable feeds in at about 15-20 degrees off centre. This will roll the cable on hard up against the previous roll. You know if your doing it properly as your should hear a slight ping sound as the cable seats firming up against itself. If you steer to hard left the cable will just overlap itself. Once the cable spools to fully across the drum, turn the vehicle to the right and it'll spool back the other way. Do this back and forth until it's all the way in. What you should be left with is several layers of nicely seated cable from one side of the drum to the other. This is best done with someone in the drivers seat, and you outside controlling the winch and pointing directions to the driver.
Of course this is never going to happen when your dragging yourself out of a bog hole, and more often than not the cable will wind on any old how, resulting in the "birds nest". This leaves several layers of cable crossing each other at different angles and under tension this can result in pressure and pinch spots on the cable, reducing it's life span and causing potential weak points.
After a week end of off roading, it only takes 15 minutes when you get home to drag out the cable and spool it back on neatly (and once again under tension) and gives a good opportunity to check for damage.
Hope this helps (and makes sense)
Brett
AnswerID: 383554
Follow Up By: Best Off Road - Thursday, Sep 17, 2009 at 20:33
Welcome to the the forum and an excellent response Brett.
Sure taught me a bit.
Thanks,
Jim.
FollowupID: 651231
Follow Up By: Geoff (Newcastle, NSW) - Thursday, Sep 17, 2009 at 20:49
Straight to the pool room Jim??
Being serious, thanks for the answer and welcome young Brett.
Geoff
Geoff,
FollowupID: 651235
Follow Up By: Member - TonBon (NSW) - Friday, Sep 18, 2009 at 14:59
Great response Brett, as somone who is looking to purchase his first winch soon, that was great info. Cheers.
FollowupID: 651345
Reply By: Atta Boy Luther - Thursday, Sep 17, 2009 at 21:43
Your wire rope should be what they call aircraft grade which means it has a galvanised wire core not a nylon core . I use a mix of one third engine oil and two thirds diesel and spray it on the rope to keep it from rusting up . You want to respool the wire the first time to get any twist out of the wire as well as tightening it up on the drum . I have seen woeful wire rope on old winches , rusty , kinked , broken wires etc . If there is even one broken wire at the thimble end you must replace the rope . If you get a kink in the rope i would suggest replacing it . Dont get a replacement from a 4wd shop but go to a specialist wire rope business and they will make it up for you for at least half the price . Every week i suggest to put the hand controller on and wind the rope in and out a few meters a couple of times . Always wear riggers gloves when handling wire rope . I suggest if you do beach travel than a prt sand anchor is the way to go . I have one and they work great . Some people have said on forums they break but thats because they are not used properly . The cause being too steep angle into the sand with the prt . A shalow line is whats needed . I suggest a snatch block , a tree protector and two shackles and a dampener for the wire rope .
AnswerID: 383574
Reply By: River Swaggie - Friday, Sep 18, 2009 at 09:45
I tied my wire to a concrete telegraph pole (in a friends court area) and put the handbrake on and wound the Hilux in !
AnswerID: 383620
Reply By: Member -Paul M (WA) - Friday, Sep 18, 2009 at 14:08
throw wire rope away fit a Synthetic Winch Rope
www.4x4xplor.com/ORO-XLine
AnswerID: 383647
Follow Up By: Member - Stuart P (WA) - Saturday, Sep 19, 2009 at 00:20
nice thought but without heat protection for the first spool ,on all electic winches the spool heat will melt the synthetic rope
FollowupID: 651417
Follow Up By: Member -Paul M (WA) - Saturday, Sep 19, 2009 at 10:07
• 21,000 lb minimum breaking strength
• Rope heated and pre-stretched to it's optimum strength.
• Resists abrasion better than regular synthetic ropes
• Includes protective covering on first 10 feet to protect against heat on drum
• Includes 3' long movable rock guard
The Masterpull Superline XD® rope
FollowupID: 651459
Follow Up By: Member - Stuart P (WA) - Saturday, Sep 19, 2009 at 23:29
pity that all works in theory . i have seen how many i have had to replace under warranty at a real expense to my business. the plasma works real well on hydraulic winches , not though on electric ones. even with the first 10 feet of insulation . my work is to fit out emergency vehicles
FollowupID: 651593
