Lubricating roller bearings
Submitted: Friday, Sep 18, 2009 at 19:24
Member - Russler
After countless dusty trips I decided to clean the roller bearings on my fridge slide, as they were full of gritty grease. Any tips on which grease to use to re lube these roller bearings?
Reply By: Roughasguts - Friday, Sep 18, 2009 at 19:45
Silicone spray it won't attract the dust.
383678
Reply By: Richard Kovac - Friday, Sep 18, 2009 at 21:02
Russler
If they are sealed roller bearings, pick the metal or rubber seal out using a sowing pin (or seal pick) they not to damage the seal.
Clean bearing with thinners or a like, press some grease into the bearing rollers and cage, not to much you must leave an air gap.
Then re fit the seal ring, test by tying to spin the bearing, it should be firm, not tight and not loose.
Then refit it and all should be OK.
Richard
383695
Reply By: Member - Russler - Friday, Sep 18, 2009 at 21:48
Thanks, will try the spray.
And no, these aren't sealed bearings. And on a grander scale, we own a Patrol, so we figure we're doing a community service by sucking the dust into the back our our fourby to reduce the dust for the next poor devil :)
Richard, I do like the
campsite photo.
383705
Reply By: donk - Saturday, Sep 19, 2009 at 10:16
Try Dri Glide
Site Link
Regards Don
383746
Follow Up By: Lex M (Brisbane) - Saturday, Sep 19, 2009 at 11:22
Suggest you read the MSDS before you use it.
Lex
651463
Reply By: Member - Ed. C. (QLD) - Saturday, Sep 19, 2009 at 12:42
For a dry lube (which won't attract & hold dust), I like >>
Molybond 122L
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
383765
Reply By: Member - Russler - Monday, Sep 21, 2009 at 18:22
Thanks for the tips guys. Still haven't done anything about it, but will have to soon, as it makes a bot of noise whilst travelling
384090
