Sunday, Sep 20, 2009 at 17:52
Well what you do is up to you.
The figures I have posted were taken on just light throttle and even on a flat road applies.
There is a point where the car will travel in OD with not enough boot in it to make it change down.
It will however lug at about 1800-1900 and put the temps up.
I thought the same as you before I put the EGT gauge in and did drive it like that thinking thats what the Auto was for.
Since watching the temps under those same driving conditions I have revised my style to only tow in 4th.
Car is much happier it just sings along it doesnt use any more
fuel and I dont have to worry about when to change into 4th.
You would be surprised how hot they get at times.
Coming up from Batemans to
Canberra the exhaust temp got up to 500deg near the top of the last long
hill.
That is any amount hot enough as the cylinder temp would be close to 700deg.
This is getting very close to sensible limits.
The temp when I drop it into 5th when just cruising climbs up at least 75 deg starting almost instantly and would be up there within a k.
I am firmly convinced for longevity that staying in 4th is is the way to go.
It does of course depend on the weight you are towing but similar figures will be reached.
My rig is just over 6000kg all up fully loaded .
I have been thinking of putting a trasmission temp gauge in as
well and may do so yet.
651690
