Home made rear storage
Submitted: Monday, Sep 21, 2009 at 13:06
Gossy
More a "for you info" than a question:
always wanted to improve the layout of the back on my GQ but never had to confidence or skills for major wood working projects.
so, on the weekend I built a unit out of "connect-it" which is a series of aluminium poles of different lengths and all the knuckles you could imagine to connect them. bought from the local hardware store.
It's basically just like putting a jigsaw together - it's that easy. Very lightweight and very strong also!
For $100 I have built a solid until which fits around my fridge slide so now I can store stuff on top. I will be adding wooden sides and marine carpet but not necessary, just have the spare time to make it look nice also.
So for anyone who doesn't trust their wood work skills then give it a go. It's very cheap, very easy to put together (just need a hammer to slightly tap it all in place) and maybe an aluminium saw or cutter to make it to exact size.
http://www.rcr.com.au/index.php?option=com_content&view=article&id=37&Itemid=149
Reply By: Member - TonBon (NSW) - Monday, Sep 21, 2009 at 13:33
Gossy, thanks for the info. I was planning to build shelving out of timber for both the tray and the rear of the dual cab area on Miss
Turtle but was procrastinating due to the work involved. This, with a little bit of adaptation will be perfect. Cheers.
384042
Follow Up By: Gossy - Monday, Sep 21, 2009 at 15:38
It's great stuff. Very easy to work with.
651784
Reply By: Ozhumvee - Monday, Sep 21, 2009 at 15:23
Alcan/Capral have marketed it for years as Qubelock.
FWIW the Trayon slide on campers use it for the internal frame of the base section and cupboards and the outside sheets are then glued & pop riveted on.
384056
Reply By: Gossy - Monday, Sep 21, 2009 at 15:41
Yep, wasn't sure it was the same stuff. When I went down to the hardware store I was actually looking for the "Qubelock"
signage. This stuff looked exactly the same so just grabbed it anyway.
I was going to ask at the hardware store on the weekend the best way to connect wooden panels to the frame work (screw etc). Looks like glue and pop rivet is the way to go? Hope not or otherwise I will need to buy a pop rivet gun that I will only use once in my whole life :(
384059
Follow Up By: Sir Kev & Darkie - Monday, Sep 21, 2009 at 15:44
Gossy,
I am pretty sure
Ross H and Mark G have used the Quebloc stuff to make their drawers for their Missan Mavars.
Both with slightly different designs but both look pretty good.
Cheers Kev
| Russell Coight:
651785
Follow Up By: disco driver - Monday, Sep 21, 2009 at 17:23
Hi Gossy,
Don't worry about not using the pop rivet gun, it won't happen, you'll use it.
Believe me, once you have one, you will use it for all manner of build and repair jobs that you have been putting off for years..
Disco.
651809
Follow Up By: Tenpounder (SA) - Monday, Sep 21, 2009 at 17:30
Hi there. I wouldn't disagree with disco driver - I have found a rivet gun an absolute blessing, but, for your job, there's a lot to be said for a packet of self drilling, self tapping, flat head Tec screws, plus a decent glue, to join ply sheets to aluminium tube.
Have fun, knowing you have actually 'done it yourself' fro a fraction of the cost!!
651811
Reply By: Member - Rob - Monday, Sep 21, 2009 at 17:38
Gossy
Greta idea. Any chance of a picture the finished product.
Morto
384081
Follow Up By: Gossy - Tuesday, Sep 22, 2009 at 08:41
yep sure. Give me another week as I hope to finish off the product this weekend.
651887
Follow Up By: Member - Rob - Tuesday, Sep 22, 2009 at 10:57
Thanks Gossy> Look forward to it.
651907
Follow Up By: Member - Rob - Sunday, Sep 27, 2009 at 22:05
Hi Gossy
I suppose you dont happen to live in BrisVegas? I have tried Bunnings and Mitre 10 and they just look at me and go huh? Which stire did you get yours from.
Rob
652633
Follow Up By: Gossy - Monday, Sep 28, 2009 at 08:58
Adelaide.
It was in the section where all the fencing stuff was. The area where a home handyman would get all the bits and pieces to build a fence/
gate himself. Maybe it's there but the staff didn't know the name of it??
Also goes under a different name of Queblok:
http://www.capral.com.auhttp://www.capral.com.au/ProductsExtrusions-Qubelok/default.aspx#divInternalLinkProducts
Looks like the website a big bodgy at the moment but worth a call to them anyway.
Good luck
652663
Reply By: Muddy doe (SA) - Monday, Sep 21, 2009 at 19:19
I knocked up a basic box and shelf unit just out of scrap 12mm MDF from packing cases that I got for free. Used 38x19 pine to form the corners and screwed the sheets straight to the pine. I think the most expensive part was the screws. A large plastic crate sits under the box acting as a draw and there is a second shelf under the top shelf which forms a handy slide out workbench. The fridge just sits beside the box. While it doesn't slide out it is still pretty easy to get into.
I was mainly wanting to build the unit to a size and live with it a little while to make sure the sizing was right before rebuilding it properly out of 12mm ply and carpeting it. So far it has lasted 12 months brilliantly and I may just carpet what I have.
While my effort may look a bit agricultural it is very functional and beats the hell out of paying hundreds of dollars for the whizzy bang metal slide runner draws and stuff which I also think waste a lot of space anyway.
My old man promised me a nice set of Black Widow drawers and a fridge slide for the Prado for my 40th but we both did a double take when the quote was $2k plus.
I must however bow to EO member Willem as the undisputed MDF King for internal vehicle storage!
Muddy
384099
Follow Up By: Bonz (Vic) - Friday, Sep 25, 2009 at 18:29
Photo's please?
Did you really do this or did you make the cuppa's while Judy did the work?
652385
Reply By: Bob of KAOS - Monday, Sep 21, 2009 at 23:42
Gossy
I'm like you (lacking confidence and skills) so I made
mine out of aluminium angle and aluminium security mesh.
Closest thing to meccano, which I used to love.
384138
Reply By: Gossy - Tuesday, Sep 22, 2009 at 08:45
to be honest the home made jobs we have all done will never be as good looking as the after market products BUT the prices they charge are just crazy.
if we all cared about appearance over functionality then we would all be driving $100K 200 series leather everywhere Sahara landcruisers. We have our cars because we get them dusty, scratch them and shake them to bits. As long as our system holds together and does what it is intended to do I could never justify $2000 + for storage systems.
384157
Follow Up By: Best Off Road - Tuesday, Sep 22, 2009 at 21:20
Gossy,
$2000 and more is outrageous for a set of drawers. I was buggered if I would pay it. That was what eventually drove me into our cuurent line of business doing decent, professionally manufactured drawers for $950.
Of course, for the competent handy man, they can be made for even less.
Jim.
651987
Reply By: jackablue - Wednesday, Sep 23, 2009 at 09:10
Heres a picture of
mine I have been using for some years now. Very light to put in and out of the back.
384292
Follow Up By: Gossy - Wednesday, Sep 23, 2009 at 09:26
Nice!!
I'm surprised more people don't use this stuff I must admit. It's so easy to bang together, weighs nothing and very strong.
I'm assuming that only members can add photos??
652055
