Tuesday, Sep 22, 2009 at 07:56
"12.6v Cranking battery - 10.6v Auxilliary 100ah DC battery - Combined Voltage is N0T (numerical number) 11.6v but would be ~11v or possibly less in many cases "
Maybe we need a new thread here on the "two batteries connected together will equalise their charge" myth.
If you connect a 100% charged battery to a 0% charged battery they WILL NOT equalise in charge. You need more than 13 volts to charge a battery - a fully charged battery only puts out 12.8 volts.
Here are the results of an ACTUAL WORST CASE TEST.
I connected a fully charged new AGM 80 Ahr battery to a good fully discharged (to 10 volts) wet-cell starting battery. The MAXIMUM current that flowed for a few SECONDS was 32 amps, but reduced to 7 amps after 1 minute.
The total charge transferred from AGM to Wetcell was only 10.7 ampHours after being connected for 2 HOURS, this will not affect the AGM's starting ability !
Keep in mind this was a worst-case test for charge transfer - a fully charged AGM has an open-circuit voltage of 13.0 volts but a wetcell only has a 12.6 volt open-circuit voltage, so less charge transfer would have occurred. You would get LEAST charge transfer if you had a charged wetcell connected to a discharged AGM.
The voltage on the two connected batteries ended up at 12.7 volts because the charged battery still had 90% capacity. The discharged battery would have charged to less than 10%.
The voltage did NOT drop below 12 volts - if this happens you have a faulty battery.
651882
