12 Volt Water pump flow rate and psi?
Submitted: Monday, Sep 21, 2009 at 18:20
ThreadID: 72440 Views:16532 Replies:6 FollowUps:8
Hi i am looking to buy a 12 Volt pump to hook up to the sink tap on my camper. I am want to run the water through a filter on the sink side of the pump. Does anyone have any suggestions of a recomended psi and a flow rate for this kind of application. I will only be feeding one tap but the filter will take some of the pressure and flow out of it i guess. cheers dave
Reply By: Dennis Ellery - Monday, Sep 21, 2009 at 18:54
Dave I assume you're in WA. Camec in Welspool Perth have these pumps - ring them or go and have a look at their pump specs. Regards Dennis.
AnswerID: 384096
Follow Up By: blueriderwa - Monday, Sep 21, 2009 at 19:15
Thanks Dennis i am not in WA i am in brisbane thanks anyway
The Wa in my name is from when i lived in WA a few years ago
I guess i was hoping someone on here might be able to tell me which pump they are using to give me an idea of what i need
cheers dave
FollowupID: 651826
Follow Up By: guzzi - Tuesday, Sep 22, 2009 at 06:36
There is a Camec in Archerfield west of Brisbane.
Boat places also carry suitable pumps as does BCF.
I'll be watching this thread, a pump in the camper trailer is on the to do list.
FollowupID: 651871
Reply By: Member - Malcolm (Townsville) - Monday, Sep 21, 2009 at 18:56
Hi Dave
I've just gone through the exercise of checking my KK. The pump is 3.8 lpm (which is quite adequate). Connected to a small in line filter it takes a bit more effort for the pump to push the water through (noisier) but still works.
Larger pumps (Shurflo IIRC) are used in caravans.
Malcolm
living the 'good life'
AnswerID: 384097
Follow Up By: Member - Malcolm (Townsville) - Monday, Sep 21, 2009 at 19:06
I meant to add ..... shop around. There is some real ripoffs out there.
Better looking at ag sites rather than RV.
Here is the first hit I tried on a Google searchclick here
Malcolm
FollowupID: 651823
Follow Up By: blueriderwa - Monday, Sep 21, 2009 at 19:20
Thanks Malcolm do you think the 40psi option would be better through a filter? I am assuming you have the 35 psi option. cheers dave
FollowupID: 651827
Follow Up By: Member - Malcolm (Townsville) - Monday, Sep 21, 2009 at 20:42
Yes, mine is 35 psi. I'm not qualified to answer the Q. Just that 35psi still seems adequate through the filter. (just noisier - compared to no filter).
Malcolm
FollowupID: 651844
Follow Up By: mazcan barry - Wednesday, Sep 23, 2009 at 17:29
hi
i have a 12v flojet pump on my camper trailer that i removed from my ex farm sprayer unit it delivers 5.8ltrs/min and has an adjustable pressure valve it was 12 yrs old when i transfered it to the camper all i have ever done to it was cleaned out the valve housing and valve seats that was two yrs ago it worked long and hard on the farm and parts are still availuble for it if needed as i checked before installing it in camper
i can highly recommend it i only have a 50 ltr tank and a tailgate sink with a small tap it works a treat and is more than ample to fill the billy and also run a shower head off an external tap on the outside of camper hope this is of help
mazcan barry
FollowupID: 652125
Follow Up By: mazcan barry - Wednesday, Sep 23, 2009 at 17:35
hi
it also has an inline filter between tank and pump which is an absolute must to protect pump valves or they will fail at the first entry of dirt or dust that's a golden rule for any brand of pump
mazcan barry
FollowupID: 652126
Reply By: Rockape - Monday, Sep 21, 2009 at 19:34
Mate,
if you are lopoking for a good reliable pump used in both marine and caravan
applications, Shurflo have a great reputation for reliability.
AnswerID: 384101
Follow Up By: blueriderwa - Monday, Sep 21, 2009 at 20:50
Yep i know about Shurflo thanks but i need to know which pump is best for the job as there are quite a few variables. cheers dave
FollowupID: 651845
Reply By: Geoff (Newcastle, NSW) - Monday, Sep 21, 2009 at 21:32
Either this one,
Parmax 2+ Then go into the Parmax range, look at Parmax 2+.
Or this one,
Shurflo
This one may be a better option as you can use a domestic style tap to regulate flow and it'll slow down or speed up to maintain a constant pressure,
Jabsco Sensor Max VSD Then go into the Sensor, Dual and Ultramax Range, look at Pressure Max VSD.
The lowest flow rates appear to be around that 10.0 l/sec mark. The Sensor Max should throttle back to stop the pump short cycling.
Geoff
Geoff,
AnswerID: 384116
Reply By: Ozboc - Tuesday, Sep 22, 2009 at 06:19
I have one hooked up in my Jayco - permanently hooked up through the plumbing and the 12v system with a momentary switch via a relay.. I got the pump from ebay
similar to this - http://cgi.ebay.com.au/NEW-12v-35PSI-Water-Pressure-Pump-4-3Ltr-Min_W0QQitemZ320425814607QQcmdZViewItemQQptZAU_Home_Tools_Pumps?hash=item4a9addea4f&_trksid=p3286.c0.m14
Can draw you a simple diagram if you need - switch and relay i got from Jaycar - also available at any dick smiths
as i dont agree with the MODSQUAD ON THIS FORUM and the stupidity of them - i am posting this message in the hope it makes its way to your email as i have no interest in helping this site whilst these MODSQUAD's hide like gutless hall monitors net policing every word
Boc
AnswerID: 384144
Reply By: paulnsw - Tuesday, Sep 22, 2009 at 07:38
Flojet Triplex Pump 50psi built in bypass control to prevent cycling and dont need accumulator. Use JohnGuest plumbing and fittings from same website push together never leak. Only requirement cut tubing square with sharp box cutter.
AnswerID: 384153
