Engel Fridge
Submitted: Tuesday, Sep 22, 2009 at 14:44
Member - Ian F (WA)
Has anyone with a 32 litre had the 10 amp blade fuse blow. It is above the 240v and 12v plugs. It is only incorporated with the 12v inlet.
Thanks in advance,
Ian
Reply By: blue one - Tuesday, Sep 22, 2009 at 16:19
Ian,
I had the fuse blow in a 40ltr, replaced the fuse and all is
Steve
384207
Reply By: Outa Bounds - Tuesday, Sep 22, 2009 at 16:25
We had a fuse blow on ours, from memory it was a 32L special edition and had a temp gauge. Were wondering why the temp display wasn't working, replaced the fuse and all was
well since.
384209
Reply By: Member No 1- Tuesday, Sep 22, 2009 at 16:52
My engel had a thermal type fuse
did two things...
1>open circuited if fridge draws over amps
and
2>open circuits if high temp eg if plug gets hots....a lot of the fuses fail this criteria for no reason other than being faulty fuse....engel dealer told me to just replace fuse with standard glass type....
384214
Reply By: Member - Stephen L (Clare SA) - Tuesday, Sep 22, 2009 at 20:38
Hi Ian
The only time that anyone has come into our
shop and had blown a fuse, the person was very lucky. He had just purchased a brand new 40 litre Engel and wanted to do some fancy wiring in the back of his vehicle. He cut the main power lead, then connected it back up, but wrong polarity. When he plugged the fridge in, it would not work and came back in saying that we had sold him a dud fridge. One look at the fuse and the technician asked what he had done. That fused saved his bacon, and the person could not believe what he had done. New fuse and correcting the lead, the fridge is still running a charm 6 years later.
384253
