water tank quality
Submitted: Tuesday, Sep 22, 2009 at 21:07
Rockyg
Just wondered what PPL were doing to keep the
water in their caravan or CT tanks fresh. Do you store your tanks full or empty and do you add anything like purifying tabs?
Someone suggested I add a teaspoon of bleach per 15 ltrs of
water to keep it tasting fresh, but that sounds a bit extreme to me.
Rick
Reply By: Member -Pinko (NSW) - Tuesday, Sep 22, 2009 at 21:29
It hasn't rained for nearly four months and we are still drinking the
water out of it .
Stan
384262
Follow Up By: Member - Graham H (QLD) - Tuesday, Sep 22, 2009 at 22:29
Filled ours in Alice early May and still using some of it
Must be Ok still alive and better than a lot of the
water of the west coast.
652002
Reply By: Witi Repartee - Tuesday, Sep 22, 2009 at 22:35
I cleaned
mine out with a bleach solution just after I had bought the van. Had no problems and then I holed the
water tank when
well and truly off the beaten track in a National
Park..so I took it out, mended it and gave it a quick soak with bicarb or soda solution. After 2 years we are still alive and healthy and have been
drinking water from all over Aussie and the outback. We don't even filter or treat it.
Cheers Gerard
384264
Reply By: Fiona & Paul - Tuesday, Sep 22, 2009 at 23:26
G'day Rick
We generally just keep topping up the
tank as we travel around and when at home for a couple of months during the hotter weather I give the
tank a quick flush and refill. I use bicarb when each trailer was new and probably once a year when we flush it out.
We do watch the
signage when we top the
tank up, but I certainly would not put bleach in
drinking water.
Paul
384267
Reply By: guzzi - Wednesday, Sep 23, 2009 at 06:55
I drain
mine when I get home from a trip and leave it empty until the next trip.
No problems over 3.5 yrs.
Works for me.
384273
Reply By: Ozhumvee - Wednesday, Sep 23, 2009 at 07:33
Just top it up on our travels with whatever is available, usually
bore water in the centre and west. If it still has
bore water in it when we get home I drain it and put fresh tap
water in it, never treat it and never put anything in the
tank except
water. Now been using the
tank for 18 years with zero probs.
We drink out of it on the road filling
water bottles every morning.
384276
Reply By: ozjohn0 - Wednesday, Sep 23, 2009 at 08:53
I alway drain ours after a trip away, then flush and refill before leaving on the next trip. NOTE: Use only quality 'Food Grade" hose to fill the
tank.
Ordinary Garden Hose will give you foul tasting
water.
If you can't get rid of the bad smells or taste then you'll need to sterilise your
tank. The most common methods are of sterilisation are:
# A cup of household bleach (Non Scented like lemon) to a
tank of
water.
# A Half packet of Bi carb Soda to a
tank of
water.
# A Half Bottle of 'Miltons" baby Bottle Sterilisation fluid to a
tank of
water.
# There are also a few propriety brands of
tank cleaning fluids available.
Allow the mix to stand in the
tank for a day or two then drain the
tank and and refill with fresh
water. allow to stand again. Then flush and refill a second time with a Food Grade hose. If this doesn't fix the problem, repeat the process.
Along with most van dealers I've always found bleach does the job quite
Good luck.
ozjohn.
384288
